ZZR250 bits compatability.
Discussion in 'Australian Motorcycles' started by Nigel Allen, Feb 5, 2008.
  1. Nigel Allen
    Nigel Allen Guest
    Salutations!
    Having started to work on the ZZR250 that some toe rag tried to steal
    from my daughters garage, I've discovered that the manuals are like
    rocking horse droppings.
    Does anyone know how compatible the ZZR250 is with the EX/EL/GPX/GPZ 250?
    In particular I need a new ignition switch (butchered with screwdriver
    combined with massive stupidity) and before I start ringing around the
    wreckers I want to make sure whatever I get will fit.
    Also any recommendations for a Kwacker wreckers? I'm on the northern
    beaches of sydney but anywhere around town is fine.
    TIA
    Nigel.
  2. Nigel Allen
    JL Guest
    <paging BTH !>
    In the interim, I'll give you a half baked answer ! Engine wise
    they're pretty near the same as a GPX, different frame, different
    rims. I wouldn't be surprised if the electrics and switchgear were the
    same - they share a lot of parts but no guarantee. GPZ is different on
    the trim so I doubt it would be. EL - yeah maybe. I suspect your
    wreckers would know...
    JL
    JL, Feb 5, 2008
  3. In aus.motorcycles on Tue, 05 Feb 2008 13:34:38 +1100
    metropolitan motorcycle spares in Silverwater have a fair range of
    stuff, worth a try anyway.
    They are pretty good about you showing up with a battered part in your
    hand and saying "mind if I have a rummage to see if I can find
    something like this?"
    Zebee
    Zebee Johnstone, Feb 5, 2008
  4. Nigel Allen
    So far as I can tell, the only difference between the ZZR and GPX
    engine is in the colour of the casings and the location of the oil
    filler hole (due to the different fairings).
    Dunno, but the ZZR mufflers bolt right onto a GPX.
    Possibly, but my memory is getting a bit hazy now. The GPZ motor has
    different internals in terms of valve sizes, etc. It's supposedly a
    bit higher compression, too.
    If you need a service manual, I put together one from scans of my
    GPZ250+GPX250 supplement a few years ago. Google for
    "GPX250Manual.PDF" and you'll probably find it - about 30MB.
    BT Humble, Feb 5, 2008
  5. Nigel Allen
    Matt Palmer Guest
    Nigel Allen is of the opinion:
    EX == ZZR (marketing name vs internal model name); GPx ~= ZZR (as covered
    elsewhere); EL/GPz I've got no direct experience with.
    There's very little difference in ignition barrels between most kwakka
    models. I took one from my badly mangled ZZR250
    (http://www.hezmatt.org/bikewreck/) and fitted it to an '82 GPz750 (wot a
    classic!) without a hassle. I'd say any 80s-90s road-going Kwakka will have
    a compatible barrel/plug. What will be less compatible will be the fuel
    tank and helmet locks; for that, my only known compatibility is between the
    ZZR250 and ZZR600 fuel tank cap -- moved the above-mentioned 250's cap to my
    600 after the keys for it got stolen and I decided it was a bad move to keep
    the existing locks on it when some toerag had the keys (and knew where it
    lived).
    Being 'gong side, I only know that the wrecker at Warrawong has all manner
    of interesting parts.
    - Matt
    Matt Palmer, Feb 5, 2008
  6. Nigel Allen
    Say, is that the bike I bought the mufflers off a few years ago? They
    would have gotten to me via Johnnie5.
    I never used them, but they were still nice and shiny. ;-)
    BT Humble, Feb 6, 2008
  7. Nigel Allen
    Matt Palmer Guest
    BT Humble is of the opinion:
    I'm fairly certain those would have been the ones. Wouldn't have been from
    me directly, though, they were stored in James' garage at the time.
    Yeah, the bike only had 20,000km on it when it got squished. Near new.
    <sob>
    - Matt
    Matt Palmer, Feb 6, 2008
  8. My mate chucked his down the road the other day and it is a writeoff. All the
    bits you want are intact though. Email me for his number. One problem, he is
    in Perth.
    Fraser
    Fraser Johnston, Feb 6, 2008
  9. Nigel Allen
    Nigel Allen Guest
    Thanks for the offer - went and got one today.
    N/
    Nigel Allen, Feb 6, 2008
  10. Nigel Allen
    Did I bring them down from James Mayfield in Parramatta?
    Knobdoodle, Feb 6, 2008
  11. Nigel Allen
    Matt Palmer Guest
    Knobdoodle is of the opinion:
    Aye. Them's the ones.
    - Matt
  12. Nigel Allen
    Geoff Guest
    GPZ/GPZ 250 manual:
    http://home.swiftdsl.com.au/~tenoq/GPX250Manual.pdf
    http://pdftown.com/Kawasaki-GPX250-Service-Manual.html
    There is a zzr250 supplement
    http://www.eightballmedia.com.au/zzr250/ZZ-R250 service manual supplement.rar
    also skim through
    http://kawasaki248.tripod.com/
    Kawasaki publish the parts fiches online as well, which is very handy.
    Geoff
    Geoff, Feb 8, 2008
  13. Nigel Allen
    Nigel Allen Guest
    Nigel Allen, Feb 8, 2008
