ZZR-250 parts compatibility '93 and '07 models
Discussion in 'Australian Motorcycles' started by Brad W, Feb 13, 2008.
  1. Brad W
    Brad W Guest
    Hi all,
    I'm considering taking a whole bunch of parts from an '07 ZZR-250
    (written off) and bolting the good bits onto a '93 ZZR-250. As far as
    I can tell everything should "just work" (same shop manual for both
    etc) however I'm not 100% sure and I figured asking around can't hurt.
    Is anyone aware of any potential issues/incompatabilities? The wreck
    will cost me some $ to attain so I'm hoping to find out if this is
    doable prior to it becoming available.
    On a somewhat related note, does anyone have an idea what pressure
    level/force would be required to break the chin guard on a full-face
    Shoei helmet? I have one here I managed to total in the same accident
    as the ZZR above. There's a rather large full-length crack in the chin
    guard which goes all the way through the shell.
    Thanks all,
    --Brad
  2. Brad W
    CrazyCam Guest
    About the ZZR-250s, dunno.
    The Australian Standard covering crash helmets, doesn't actually have
    any definition of the strength or robustness of the chin piece of a full
    face helmet.
    The fact that it cracked, and you are still about to post shows that it
    did it's job.
    The force involved would have been surprisingly little, assuming you
    haven't got a broken neck.
    regards,
    CrazyCam
    CrazyCam, Feb 13, 2008
  3. Brad W
    The 2007 model may have slightly different carburettors with de-icing
    pipework connecting them to the engine's water jacket (I saw a
    relatively late-model GPX250 with that fitted a few years ago).
    Lots. Did you break your nose in the process? I did.
    BT Humble, Feb 13, 2008
  4. Brad W
    Brad W Guest
    I'm hoping to take the entire engine and most of the other mechanicals
    across wholesale: the wreck only had 1700K on it. Hopefully any
    differences will be small ones which don't impact on the plan. The whole
    thing will be a learning experience (mechanically minded? Who me?) but hey
    I have the time right now if nothing else.
    Not my nose no, thankfully. I did manage fractures/punctures/tears to left
    occipital condyle (neck); base of skull; lower back; 12 or 14 ribs; 2
    lungs; LeFort I and II (face); subdural haematoma; liver and other
    assorted abdominals and a bunch of other things.
    I don't think much of that came from the fall... rather from the semi-
    trailer running over my head and chest a second or so later. I'm pretty
    sure that's what snapped the helmet chin guard and am trying to figure out
    how much force was applied. Pics of the helmet for those who are
    interested:
    http://picasaweb.google.com.au/Bradley.Webb/AccidentTheAftermath
  5. Brad W
    You win.
  6. Brad W
    Yeebers Guest
    Youch. take the opportunity to get a Nolan N102.. ? :)
    So if someone ever asks if you got hit by a truck, you can say yes ?
    Yeebers, Feb 13, 2008
  7. That is exactly the same as my helmet. I'm feeling much better about wearing
    it now that I know it can handle a truck running over it.
    Fraser
    Fraser Johnston, Feb 14, 2008
  8. Brad W
    Brad W Guest
    Not the entire truck, just the rear wheel bogie on a trailer attached to a dump
    truck. Similar to the trailer seen here:
    Had I gone under the front (vis "use ya mirrors" video) or had the truck been
    loaded, I'm pretty sure the helmet would have either collapsed or been rendered
    moot anyway.
    --Brad
    Brad W, Feb 14, 2008
