ZX9R + Full titanium Akrapovic...
Discussion in 'UK Motorcycles' started by eric the brave, Mar 27, 2005.
  1. eric the brave
    Bear says...
    Lozzo, Mar 27, 2005
  2. eric the brave
    Salad Dodger Guest
    I wouldn't want one, even if I got paid £5 every time I rode it.
    | ___ Salad Dodger
    |_\_____/_| ..73542../..18203.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 1 Pts: 10 Miles: 147
    Salad Dodger, Mar 27, 2005
  3. eric the brave
    Salad Dodger Guest
    I had a little go on Champ's a while back, and while I will concede
    that it goes like greased buggery, and handles like a dream, I just
    couldn't get on with the ergonomics.
    It felt like I was sitting on the headstock, and everytime I touched
    the brakes, I thought I would fall off the front. I did try sitting as
    far back as possible, and that helped, a bit.
    Simply put, I'm not Gixxer Thou shaped.
    The Blackbird, in comparison, is wonderful. If it had the gixxer's go,
    and handling, it'd be brilliant. Then again, it's no slouch.
    | ___ Salad Dodger
  4. Yes indeed. I used to jig bore barrels to match the pistons. IE get a worn
    set of of +20 thou pistons. Turn them down to say +13 or untill they where
    clean, then jig bore the barrels to match the pistons. IE 2 thou clearance
    or whatever.
    eric the brave, Mar 28, 2005
  5. Better not start on the properties of Spheroidal Graphite cast iron, High
    Carbon spring steel, Engineering chromium and other plating and things
    like Wear-Resistant Amorphous and Nanocomposite Steel Coatings then :)
