ZX6R J1 carb icing
Discussion in 'UK Motorcycles' started by Chris, Dec 3, 2005.
  1. Chris
    Chris Guest
    One other thing.
    I currently have a ZX-6R J1 that is icing up even in temperatures as
    high as 5-6 degrees, which seems to be a bit odd (although in fairness
    the days were foggy, so there was a lot of moisture in the air). The
    dealer's checked/serviced the carbs and says everything's fine.
    Any thoughts? Are J1s especially prone to icing (my ex-G1 was fine)? Any
    magic cures? Failing that, where can I get hold of industrial
    quantities of Silkolene FST?
    Thanks in advance.
    Chris
    Chris, Dec 3, 2005
  2. Chris
    That's exactly the sort of weather that brings about carb freezing.
    You prolly don't need 'industrial' quantities: a litre goes a long
    way. If you have trouble sourcing it, we found Wynn's Dry Fuel to be
    just as good, but also just as expensive.
    Pip, Dec 3, 2005
  3. Chris
    Kiran Guest
    That's perfect for carb icing.
    No. My J1 carb iced like a bastard. The J1 has a carb heating system, which
    draws water from the rad to the carbs. It has a small in line filter so you
    check to make sure that isn't blocked. From recollection it's under the
    front right of the tank.
    This works. As Pip said, the 1l one will do, pop it under the seat and add a
    bit each time.
    Kiran, Dec 3, 2005
  4. This is what you need:
    <URL>http://cgi.ebay.co.uk/Isopropyl-Alc...QcategoryZ88433QQtcZphotoQQrdZ1QQcmdZViewItem
    Should keep you going :)
    Or a 500ml tin for 5 quid
    eric the brave, Dec 3, 2005
  5. I suspect Dry Fuel to be nothing more than methanol. Dirt cheap.
    Grimly Curmudgeon, Dec 3, 2005
  6. My E1 9r did the same thing if that helps. I think its just Kawasaki`s
    water heating method around the carbs that simply don't work.
    Chris
    Chris Bedford, Dec 3, 2005
  7. Chris
    Chris Guest
    Sounds about right. Just found this:
    http://www.silkoleneoil.com/techtip7.htm
    "Pro-FST (Fuel System Treatment) was developed in 1992 following an
    unofficial request from Kawasaki Motors (UK) Ltd., for something that
    would deal with the particularly British problem of carburettor icing in
    damp, cold weather. "
    Chris
    Chris, Dec 3, 2005
  8. Chris
    Chris Guest
    Indeed...it just took me by surprise a bit since none of my other bikes
    have suffered until it's a bit colder. So I will check that
    filter...call me paranoid.
    When I say 'industrial' I'm only really talking about a 5 litre can of
    the stuff which should last me into March! :)
    Ta for the tip about Wynns.
    Chris
    Chris, Dec 3, 2005
  9. Chris
    fish Guest
    My naked B12 k1 suffers really bad its fine untill I have run it for 1.5
    miles same place every trip when its cold then if i stop reving it it
    stalls. Any bright ideas? Will the sillkolene work?
    Ken
    B12
    fish, Dec 3, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, fish
    Christ on a crutch.
    Here, have some basic punctuation:
    Scatter them around a bit, I think you'll like the effect.
    Wicked Uncle Nigel, Dec 3, 2005
  11. Chris
    fish Guest
    fa,nk.s
    ,Ke.n
    ..B,1,2
    fish, Dec 3, 2005
