Zephyr fun and games
Discussion in 'UK Motorcycles' started by dwb, Aug 1, 2004.
  1. dwb
    dwb Guest
    Isn't for if you run out of fuel?
    dwb, Aug 1, 2004
  2. dwb
    Oldbloke Guest
    Carbs went back on. Bit of a bastard of a job, but not too bad, the trick
    was to locate the intakes in the airbox rubbers with the connectors to the
    head off, and then wedge the connectors into position. All went well untill
    we dropped one of the bolts, which fell down the gap under the starter
    motor, meaning that the front sprocket cover had to come off.
    Anyway, carbs on, new inner cable and nipple positioned on carb, so off to
    the front of the bike to do the twist grip end. Mullered the new nipple,
    and busted off part of the twist grip where the nipple locates. New nipple
    fabricated by drilling through a bolt then dremmelling off a nipple sized
    portion and soldering on the cable. Unfortunately the broken bit of twist
    grip wont stick back on with superglue, or araldite, or melting with a red
    hot nail (or a combination of all three).
    So I need to get hold of a replacement twist grip, are these generic or bike
    specific?
    Oh, nearly forgot, having reassembled she started first time, which was a
    bonus.
    Aso, my fuel tap has 3 positions, on, reserve and prime, but no "off". At
    the ristk of asking an onvious question, what purpose does the prime
    position serve?
    Dan L (Oldbloke)
    My NEW bike 1996 Kawasaki ZR1100 Zephyr
    My old Bike 2000 Honda CB500 (for sale)
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Aug 1, 2004
  3. dwb
    Mark Olson Guest
    Correct, and since the OP probably still doesn't know why you'd need
    a prime position... the prime position on a vacuum petcock lets fuel
    flow without the application of engine vacuum to the petcock. The
    petcock needs the engine running on the reserve and on positions for
    fuel to flow. If you run the carbs dry, it is difficult to develop
    enough engine vacuum simply from cranking the starter to allow fuel
    to flow, hence the prime position.
    Mark Olson, Aug 1, 2004
  4. dwb
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Oldbloke
    In the 'On' and 'Reserve' positions fuel should only flow when there's a
    vacuum in the other pipe that goes to the tap. In the 'Prime' position
    fuel will flow regardless. So you use 'Prime' if you've run out of fuel,
    to allow the carbs to refill without having to crank the engine.
    Nigel Eaton, Aug 1, 2004
  5. dwb
    Oldbloke Guest
    That's what I thought, but it started fine today having had the carbs off
    and emptied, so I am not so sure.
    Dan L (Oldbloke)
  6. dwb
    Petel Guest
    Sort off.
    The fuel tap is a vacuum type, you`d notice a small pipe going from the tap
    to the carbs or manifold.
    Fuel only flows when there is a vacuum when switched to on or reserve, bit
    on prime it runs on gravity so if you drain the carbs or run totally out of
    fuel the prime..er..primes the carbs without needing the engine running.
    When not in use just leave the tap switched to the on position.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Aug 1, 2004
  7. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Oldbloke"
    The carbs filled up then while the petcock was in the 'on' position
    without a vacuum. There may be a rubber gasket inside the petcock which
    is fubared and allowing fuel flow in all positions.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 1, 2004
  8. dwb
    Elly Guest
    **** me, I thought he had a real Zephyr.
    Still, a 1/8 Zephyr is still better than a wholly imaginary R1, I
    suppose.
    Elly, Aug 1, 2004
  9. Heh, it's not an I- Bike ta very much.
    Anyway, as you are a man who knows, can you advise me of the following:
    What oil should I put in it.
    Where the bloody hell does the oil filter go (I have bought a new filter but
    cant see the small drum shaped cannister as per the Honda.
    Who does a manual for it (can't see it in either Haynes or Clymer listings)
    New twist grip ordered today, more fun anticipated next weekend.
    oldbloke at work, Aug 2, 2004
  10. dwb
    I'm not Pip or Elly, but I'll have a go.
    Any decent 10W40 or 20W50 multigrade
    Is it an external cartridge type filter (metal thread on thing), or an
    internal paper type. The older Kawasaki designs used a paper filter,
    held in a chamber accessed by a larger round over in the sump. You
    need to get right under the bike and look - it'll have a 17mm bolt at
    the centre. If it's an external filter it should be fairly bloody
    obvious!
    Champ, Aug 2, 2004
  11. Cheers Champ,
    There is no (visible) external cartridge (on the Honda this sticks out at
    the front of the engine). A cursory glance underneath hasn't so far
    revealed any other likely candidate, so a closer look is needed.
  12. dwb
    Do you have a replacement filter in your hand? What does it look
    like?
    Champ, Aug 2, 2004
  13. Not at the moment (it's at home in the shed), but the box is quite small, so
    I would guess it's a paper type one.
    I have, however just ordered a Kawasaki Workshop Manual for the bike though
    (£45) which should be with me by the end of the week, together with a new
    twist grip and pair of new mirrors, so a more organised approach to
    fettlement should be possible next weekend.
    Hopefully this shaky start to my relationship with the Zephyr is just a
    blip.
    In the meantime I am being hassled by my lad (and SWMBO, strangely) about
    getting him a 125 for when he's 17 in November. If we get something for him
    fairly soon there'll be 4 bikes at home (is this how TOG and Sweller started
    collecting bikes, I wonder). I really must seriously try selling the Honda
    very soon (I was offerred £1400 PX against a 2003 NSR125 @ £2500, but have
    decided not to go down this route, for now at least).
  14. dwb
    Eddie Guest
    Normally a pink-ish[0] colour, four fingers[1], one opposable thumb.
    [0] Some variation in colour may be apparent, depending on racial
    hereditary.
    [1] Some variation in number of fingers may be apparent, depending on
    degree of fen-ness and family in-breeding.
    Eddie, Aug 2, 2004
  15. dwb
    You silly sod :)
    Or if one's been working on a motorcycle over the weekend, escpecially
    if spray painting bodywork in Kawasaki green [2]
    Or clumsiness and stupidity when cleaning/oiling a chain.
    [2] and, if you do this without wearing a mask, you end of with really
    *bright* green bogies.
    Champ, Aug 2, 2004
  16. dwb
    Eddie Guest
    Somebody had to do it.
    Tch. Latex gloves, that's what you want.
    I was thinking more of extra fingers, but yes.
    Purest green?
    Eddie, Aug 2, 2004
  17. dwb
    I've got loads. Just kept forgetting to put them on.
    Dayglo. Do you think there's a market for snot coloured jewelry?
    Champ, Aug 2, 2004
  18. dwb
    Eddie Guest
    Heh, *whoosh*, and...
    "Oh, Edmund, can it be true, that I hold here in my mortal hand a nugget
    of purest green?"
    Eddie, Aug 2, 2004
  19. dwb
    **** off is it a whoosh
    To which Edmund replies, later, to Percy "You think there's a big
    market for jewelry that looks like snot, then?"
    Champ, Aug 2, 2004
  20. dwb
    Eddie Guest
    D'oh. It's been one of those days.
    Eddie, Aug 2, 2004
