Z650 spare engine
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Jan 13, 2007.
  1. Started pulling it down this afternoon - for one thing, I want the
    shims.
    The cams are absolutely *perfect*. They look new. I was going to flog
    'em, but now I might keep 'em just in case. What I want to know is that
    with the Z650, does one need to replace head and cams as a unit? I
    suspect not, but it's worth asking.
  2. The Older Gentleman
    chrisu Guest
    cam caps only need to go with the head I believe
    chrisu, Jan 13, 2007
  3. Ah, ta for that. I had a feeling that here was something that had to be
    kept together.
    Head & caps, not cam & caps or head & cams. Thanks again.
  4. The Older Gentleman
    Moon Badger Guest
    As the caps ( and head )run without a shell insert[1], it may be worthwhile
    getting some plastigauge or hiring/borrowing a bore micrometer to check for
    ovality. If it is out, it isn't hugely expensive to get them built back up
    and line bored.
    [1] It has been over a decade since I furtled with one, so memory tricks may
    deceiving me here. I can't remember seeing a shell.
    Moon Badger, Jan 13, 2007
  5. No shells. And the cams are superb in every respect, so yeah, the head
    and caps belong together.
    <Fires up Ebay>
