Z650 main jet size check please
Discussion in 'UK Motorcycles' started by BORG, Nov 7, 2006.
  1. BORG
    BORG Guest
    Can anyone confirm the size of the main jet in the Mikuni slide carb
    range, not the one with the accelerator pump.
    I have a Haynes but I like to double check these things.
    Must be a 1978ish version.
    Thanks
    www.ratrodz.co.uk
    XJ900 Trike ** GS850 Trike
    XV1000 TR1 Chop
    [Rot 13 it]
    Some people are like slinkys....
    no real use but it makes you smile when they fall down stairs!
    BORG, Nov 7, 2006
  2. I've got a pukka Kawasaki factory manual. According to that, the main
    jet is a 102.5R. Needle jet is 0-8, pilot jet 15, air screw two turns
    out plus or minus a quarter.
    hth
    The Older Gentleman, Nov 7, 2006
  3. BORG
    BORG Guest
    hth[/QUOTE]
    TY , yer that helps.
    they are fitted with 125 main at the moment*, the Haynes book of lies
    says Main 100 Needle 0.8 and pilot 16. Slightly different.
    * well 3 are, one has what looks like a jet that someone has tried to
    drill and borked it up,
    www.ratrodz.co.uk
    XV1000 TR1 Chop
    [Rot 13 it]
    BORG, Nov 7, 2006
  4. BORG
    BORG Guest
    Is the needle position the center grove as standard as well ?
    www.ratrodz.co.uk
    XV1000 TR1 Chop
    [Rot 13 it]
    BORG, Nov 10, 2006
  5. Doesn't seem to say.
    The Older Gentleman, Nov 10, 2006
  6. BORG
    BORG Guest
    Doesn't seem to say.[/QUOTE]
    Dam, can't see it in the Haynes or the Clymer book either
    www.ratrodz.co.uk
    XV1000 TR1 Chop
    [Rot 13 it]
    BORG, Nov 10, 2006
  7. In the absence of hard info, I've just used the centre position as a
    starting point and done plug chops if needed.
    Grimly Curmudgeon, Nov 10, 2006
  8. The Older Gentleman, Nov 11, 2006
  9. BORG
    BORG Guest
    "The 4 is the groove number for the clip"
    Doh. Got the same manual, same page, and I missed it.[/QUOTE]
    4th from the bottom then I take it
    www.ratrodz.co.uk
    XV1000 TR1 Chop
    [Rot 13 it]
    BORG, Nov 11, 2006
  10. BORG
    BORG Guest
    Many thanks
    www.ratrodz.co.uk
    XV1000 TR1 Chop
    [Rot 13 it]
    BORG, Nov 11, 2006
  11. 4th from the bottom then I take it[/QUOTE]
    <Examines schematic closely>
    Yes.
