z500... advice sought from the old farts
Discussion in 'UK Motorcycles' started by deadmail, Oct 26, 2007.
  1. deadmail
    deadmail Guest
    Gents, you know who you are...
    So the Z500 (with sidecar) needs to be in fine fettle for the
    Elephantentreffen in January.
    I've sorted out the issues with the sidecar, serviced the engine
    including replacing the coils/condensers/points. However, on occasion,
    when I give it throttle WFO for some time, say 2 or 3 minutes, it
    sometimes loses power; probably only one cylinder. Throttling off seems
    to address this.
    What's this likely to be? I don't think it's ignition due to the new
    coils/plugs/condensers/plug caps/points. So is it crap in a carb?
    damaged diaphragm?
    I really don't want to strip the fucking carbs if I can avoid it since
    they're prolly welded in place with 27 year old rubber...
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    You can even do the left hand pot from the comfort of the chair, IWHT.
    Honda GL1000K2 (Fallen apart)
    Suzuki TS250 "The Africa Single" Honda ST1100 wiv trailer Norton 850 Commando
    Kawasaki GTR1400
    Wicked Uncle Nigel, Oct 26, 2007
  3. deadmail
    deadmail Guest
    New coils, the old ones had damaged leads (cracked) and one of the coils
    was cracked. You're right about the leads being fixed to the coils.
    Done all of the above with the sole exception of the shims. Am a little
    reluctant to do this 'cos I'm lazy. Suppose it would make sense to have
    a look at the cams etc. but to be honest it all sounds fine.
  4. deadmail
    **** off.
    Sounds like fuel starvation. Is there a fuel filter involved anywhere?
    platypus, Oct 26, 2007
  5. deadmail
    He's waiting for you to lose patience and come over and just do it for him.
  6. deadmail
    deadmail Guest
    Don't think so unless it's one of the mesh types in the tank. Will try
    it with the tap turned to "prime". Simon Batey may have hit the nail on
    the head about the vacuum tap. Could also look at the breather in the
    cap I suppose.
    deadmail, Oct 27, 2007
  7. deadmail
    deadmail Guest
    Oh, I'm sure they are but:
    1) There's already damage in that area caused by the fecking muppets
    overtightening a too-long screw in the cam cover casing.
    2) All the rubber bits will be trash.
    It's on the list; together with (possibly) rebuilding the fuel tap,
    balancing the carbs and er... getting it MOTd.
  8. deadmail
    Oil and filter is a given but shims? I wouldn't - unless they're making
    a horrid noise now.
    sweller, Oct 27, 2007
  9. deadmail
    It's the tap, tap filter or one of the needle valves is running slightly
    slow.
    You may want to chop the plugs when it starts running off - I'm pretty
    sure the carb giving trouble will run weaker.
    Airline on the fuel inlet may blast the shit out. Same on the tap in the
    may save rebuilding it.
  10. deadmail
    Dan L Guest
    If it's the tap filter wouldn't it be easier to cut the fucker out and
    fit an inline one (or would that risk gunge-ing the tap innards up with
    shite from the tank)?
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Oct 27, 2007
  11. deadmail
    Good point.
    It's only a Kwack anyway - I'd probably risk it.
  12. deadmail
    deadmail Guest
    wrote in message
    Well, today's 300 mile training run suggests it's the vacuum tap.
    Moving it to "prime" removed the problem on two occasions.
  13. deadmail
    The Trophy had a couple of tiny hidden filters in the T-pieces of the fuel
    lines. Once cleaned of rusty gunk, the fuek starvation symptoms went away.
    platypus, Oct 27, 2007
  14. deadmail
    Lady Nina Guest
    <shout>
    I've booked my ferry crossing. [1] Now I have to make the Benly fit
    for purpose. Can someone take it away and bring it back when it is
    done please?
    [1] The combined powers of alcohol and Bonwick are formidable.
    Lady Nina, Oct 28, 2007
  15. deadmail
    Bring it here and we can fit new sprockets.
    platypus, Oct 28, 2007
  16. deadmail
    deadmail Guest
    Hmm.. UK leg; 206 miles to Harwich ferry, then 900km to Thurmansbang.
    Double it... so that's about 1500 miles.
    Well it'll certainly build my shoulders up. Whilst the outfit doesn't
    pull on a level surface, throw in a bit of slope or camber and I'm
    constantly making adjustments. Yesterday was quite hard work; must
    spend more time in the gym. Alternatively I wonder if a steering damper
    would make much difference?
    Regarding recovery, I'm afraid if it dies then it's likely to be left
    where it falls.
    deadmail, Oct 28, 2007
  17. deadmail
    Her sights and sounds; dreams happy as her day;
    And laughter, learnt of friends; and gentleness,
    In hearts at peace, under an English heaven.
    sweller, Oct 28, 2007
  18. deadmail
    deadmail Guest
    Heh. I think the earlier line should read
    "In that rich earth a richer rust concealed" though.
