Yet another DT175MX question... (Mikuni carb)
Discussion in 'Classic Motorbikes' started by Dr Ivan D. Reid, Aug 5, 2005.
  1. Thanks to a certain Pip of this Parish, I now have a Hayne's BoL
    for the DT. And I'm still puzzling over why the carburettor needs the
    idle screw screwed in to the last micrometre for the bike to idle; the
    needle clip is in the middle position, and removing the bodged knitted-
    cloth air filter makes no difference, so that's not over-restrictive.
    The slide is open by several mm, so it's no wonder that the idle mixture
    screw has no effect.
    But, I've blown out all the orifices, and poked fine copper wire
    through 'em, so there is no obvious air or fuel blockage in the idle
    circuits. It still won't run that far down (he says, realising that he
    hasn't actually _tried_ it; it just dies as the screw is outwound).
    Clutching at straws, what if the float level is wrong? Ah, the BoL
    gives the float height spec -- but not how to measure it! I know this
    varied between bike manufacturers, but I'm not sure if a Yam Mikuni uses
    the same criterion as a Suzuki Mikuni -- and it's been so long that I'm
    not sure exactly how Suzuki defined it anyway (upper limit of the float
    body to the _alloy_ sealing surface of the float bowl?).
    Anyone know?
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
  2. Dr Ivan D. Reid
    Dan L Guest
    ISTR you can download a complete Mikuni manual for free from their website.
    Alternatively I have a copy here I can email over if you'd prefer.
    We found it useful when fiddling with the TS50's micro-carb.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Aug 6, 2005
  3. Ah, thanks! I hadn't thought of that route, focussing more on
    "Yamaha" than "Mikuni". I've been a tad preoccupied with work this week...
    Thanks, but I appear to have found it on the Web-site.
    Wahay, the first illustration is a Yamaha carb -- Suzuki didn't have
    the removable cap over the main jet.
    Cheers.
    Dr Ivan D. Reid, Aug 6, 2005
  4. Dr Ivan D. Reid
    Guest Guest
    Been wondering whether to ask... is the exhaust system free-flowing (or
    at least as good as it can be)?
    Surely float height wouldn't make any difference to it idling?
    Regards,
    Simonm.
    Guest, Aug 6, 2005
  5. Dr Ivan D. Reid
    Dan L Guest
    Glad to have been of service.
    Does this mean that I can no longer consider myself a newbie then? [1]
    [1] Mr Blaney reckons you're the arbiter of newbiness.
    Dan L (Oldbloke)
    Dan L, Aug 6, 2005
  6. At first sight, yes. I can feel individual puffs coming out the
    spark-arrestor so I know there's not a _complete_ wasp's nest up there. :)
    Well, I'm trying to work out why it appears to be getting no fuel
    through the idle circuit. The Mikuni book should help (but it's generic
    and doesn't give the method of measuring float height either...) but
    I'm off tomorrow for a conference in Oxford[1] so further investigation will
    have to wait until next weekend.
    [1] Any recommended bike shops near the centre of Oxford, by the way?
    It'd be a chance to buy a few bibs 'n' bobs.
  7. Scratch that, it does tell how. I missed it scrolling through the
    document on-screen.
  8. once had a blocked baffle thing in a H100 'zorst, and the main differnce was
    that a slow bike became even slower. small bit of soot in a critical hole,
    was all it were.
    Austin Shackles, Aug 7, 2005
  9. BTDTGTTS! I did get the carb off again last night -- and everything
    is infuriatingly nominal. All the removable jets etc have the sizes given
    in the BoL; float height is specced at 21 +/- 1.5 mm & I measure 21.04 ...
    I think I'll put it back on with the idle screw where *I* think it should
    be, and see if I can get it to run. It's been so high that I think the bypass
    was not functioning in idle mode (where air is blocked by the slide and
    enters the vertical hole to help drag fuel from the pilot jet and out the
    downstream hole). I'm going to have to drag out my copy of the Two-Stroke
    Tuner's Handbook, but I think Jennings may have taken a lot of his description
    from this Mikuni handbook anyway.
    If that fails, yes it's exhaust- and timing- time.
    Dr Ivan D. Reid, Aug 7, 2005
  10. Dr Ivan D. Reid
    Guest Guest
    Large cork & caustic soda seems to work fairly well. But I don't know
    what you do about the exhaust...
    Regards,
    Simonm.
    Guest, Aug 7, 2005
