Ye cannae change the laws o' physics
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jul 30, 2009.
  1. Unless you're flying a model 'plane
    Pretty fucking amazing, IMHO.
    go and talk to the Catholics.
  2. The amazing thing was near the end when he dove towards the ground... and
    then hit REVERSE!
    Andrew Halliwell, Jul 30, 2009
  3. Wicked Uncle Nigel
    Simon Wilson Guest
    Just a reversible leccy motor, Shirley?
    Simon Wilson, Jul 30, 2009
  4. I'm not sure propellers work like that...
  5. Wicked Uncle Nigel
    Tosspot Guest
    Was it? I assumed it was just a stepper motor, never thought it might
    be variable pitch.
    Tosspot, Jul 30, 2009
  6. Wicked Uncle Nigel
    Simon Wilson Guest
  7. Wicked Uncle Nigel
    David Toft Guest
    Its done by strings from the ceiling
    David Toft, Jul 30, 2009
  8. Wicked Uncle Nigel
    Lucifer Guest
    Pah :)
    Lucifer, Jul 30, 2009
  9. Wicked Uncle Nigel
    Tosspot Guest
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, steve auvache
    Christ, but you don't half talk some bollocks... I was about to say
    "sometimes", but then I realised.
  11. Wicked Uncle Nigel
    Derek Turner Guest
    I know I'm going to regret asking this but...
    how does a fixed-wing plane fly upside down? AIUI the shape of the wing
    reduces pressure on the upper surface and increases it below, creating
    lift. When the wrong way up why doesn't it create 'drop'?
    Derek Turner, Jul 30, 2009
  12. Wicked Uncle Nigel
    Tosspot Guest
    'Cause the lower surface replaces the upper surface after the
    transition on a temporary, "lend us a tenner" sort of way, and does
    the relevant sucking.
  13. Wicked Uncle Nigel
    It's all to do with the angle of the wing to the direction of travel.
    When in a normal orientation the wing is sloped up at the front so as
    the fuselage moves straight forward the wing presents a given angle of
    attack to the wind; when flying upside down the fuselage is angled
    even more up wrt the direction of travle, so the wing's angle of
    attack is about the same. Sure, they're designed to work best in their
    normal configuration, but the shape of the upper and lower sides of a
    wing aren't _that_ different.
    Ace, Jul 30, 2009
  14. Wicked Uncle Nigel
    Colin Irvine Guest
    I imagine the plane points slightly upwards, so the force exerted by
    the propeller has a vertical component.
    Colin Irvine, Jul 30, 2009
  15. Wicked Uncle Nigel
    Symmetrical aerofoil or simply make up for poorer perfomance inverted
    by increasing the angle of attack.
    Pip Luscher, Jul 30, 2009
  16. Wicked Uncle Nigel
    David Toft Guest
    Watch at the very beginning, before take off when he does final checks,
    the whole wing moves as well as the flaps
  17. Wicked Uncle Nigel
    Oh right. Yeah, if you're talking about toy planes, then sure. I was
    assuming the question was about real ones.
    Ace, Jul 30, 2009
  18. I've seen a live display of a SUKHOI and the thought crossed my mind:
    To stop the pilot blacking out his G suit must have squeezed his balls
    up around his ear lobes.
    Mick Whittingham, Jul 30, 2009
  19. Wicked Uncle Nigel
    Or German accent, through blistered lips.
  20. Wicked Uncle Nigel
    Big river in africa.
    Ace, Jul 30, 2009
