Yamaha TW200 2006
Discussion in 'Motorbike Technical Discussion' started by Broderick Crawford, Apr 17, 2007.
  1. Well, logic is an essential part of a technical discussion, wouldn't
    you agree.
    Let's see, now.
    Any engine wears out faster, the harder it's used. Correct?
    Therefore an engine which is run continually at maximum revs will wear
    out faster than one that isn't, correct?
    Therefore, to advise someone to run their engine flat out all the time
    is to advise them to wear out their engine prematurely, correct?
    So get a decent newsreader.
    No, your inaccuracies tend to undermine your ineffectivity with the
    newbie.
    You're sounding paranoid, sweetie.
    chateau.murray, Apr 19, 2007
    #41
  2. Broderick Crawford
    John Johnson Guest
    John Johnson, Apr 19, 2007
    #42
  3. It is not bogged down in fifth at 20mph, goes to 55 just fine.
    Broderick Crawford, Apr 19, 2007
    #43
  4. I'd expect that, to be honest. Nice soft little 200cc dirt bike, with
    lowish dirt bike gearing.
    Bear in mind that revving an engine to the redline in neutral is not
    the same thing at all as running it on the road at the redline. In
    neutral, there's no load on the engine - on the road, it will be at
    maximum load, which will of course, if done continually, reduce its
    lifespan.
    #44
  5. There is no load going down hill and backing off the throttle.
    Broderick Crawford, Apr 20, 2007
    #45
  6. Broderick Crawford
    Gene Cash Guest
    Gene Cash, Apr 20, 2007
    #46
  7. Broderick Crawford
    Albrecht Guest
    Broderick, you can waste your time on Usenet, arguing with nut cases
    like TOG and Gene Cash, or you can go to a nice web based forum where
    the people behave themselves.
    To answer your question about why there is a redline on your
    speedometer at 55 mph, Yamaha has been using that same speedometer
    since 1982, when the national speed limit was 55 mph. The redline has
    nothing whatever to do with engine RPM.
    If you go to http://tw200forum.com/forums/3619/ShowPost.aspx you can
    read about some very satisfied people who ride their stock TW200's up
    to 70 mph, and regularly make 50-mile round trips at 60 mph.
    Albrecht, Apr 20, 2007
    #47
  8. Broderick Crawford
    Gene Cash Guest
    I'm mentioned in the same sentence as TOG! W00T!
    I don't remember arguing with Broderick, though...
    -gc
    #48
  9. Nor did you.
    The Older Gentleman, Apr 20, 2007
    #49
  10. Of course there isn't.
    #50
  11. Now that's a good idea. Why don't you follow your own advice?
    #51
