Yamaha tw 125 trailway carb question
Discussion in 'Motorbike Technical Discussion' started by CJ, Apr 21, 2007.
  1. CJ
    CJ Guest
    IToday I broke the sensor on the carb (with two wires feeding it,on
    yellow and one black. Yellow wire is on top),the sensor is on the
    right hand side of the carb. Since I broke it, when the bike is
    revved, the revs seem to take a while to come down to tickover (the
    revs hang at 3/4 to 2 time the usual idle speed for a few seconds,
    then they die down to tickover)
    The bike's year is 2000 (W reg)
    Does anyone know what this sensor does?
    Thanks in advance.
    CJ, Apr 21, 2007
  2. CJ
    Albrecht Guest
    That model isn't sold in the USA. You might try googling for online
    mail order catalogs in the UK that have parts fiches which customers
    can look at and perhaps figure out what the sensor does by its
    description. Your engine seems to have a Teikei YP24 carburetor,
    according to the only English website that I found with specifications
    for the TW125.
    Maybe your sensor has to do with shutting off fuel to the idle
    circuit. Your high RPM at idle indicates that the throttle butterfly
    is too far open for idling at the specified speed. The transition
    ports are uncovered by the edge of the throttle butterfly, so the
    engine is getting excess fuel at idle and it takes several seconds to
    idle down.
    An engine is supposed to idle smoothly with the smallest amount of
    throttle opening and with the idle mixture screws turned out the
    fewest number of turns possible.
    I have read about carbs with throttle position sensors that will shut
    off the fuel supply if the position of the throttle twist grip
    disagrees with the position of the throttle butterfly or slide.
    This is supposed to protect newbies from having a motorcycle run away
    with them clinging on for dear life.
    Other electrical devices on carburetors operate a little valve in the
    side of the carburetor that shuts off an air passage. This is
    necessary when coasting on closed throttle to keep the engine from
    backfiring.
    But that is usually done with a vacuum sensing rubber diaphragm on the
    left side of the carb.
    Albrecht, Apr 22, 2007
  3. Ask a Yamaha dealer?
    The Older Gentleman, Apr 22, 2007
