Yamaha RS200
Discussion in 'Classic Motorbikes' started by mups, Oct 8, 2003.
  1. mups
    mups Guest
    Ok, for silly reasons best kept to myself I've gone and bought a 1983 Yam
    RS200. This weekend I'm planning on doing a bit of top end strip down. I'm
    not expecting any nasties as it runs really nice, but just in case does
    anybody know if the pistons, rings and little end bearings are the same as
    a RD200?
    BTW anybody know what the top speed of this thing is meant to be.
    mups, Oct 8, 2003
  2. mups
    mups had a fit and wibbled.....
    They should be exactly the same parts.
    About 75 to 80ish IIRC
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 8, 2003
  3. mups
    mups Guest
    Cheers Loz, I had a feeling you might know the answer to that one. :)
    I did try but felt such a prat lying flat on that tank at 70 that I gave
    up.
    mups, Oct 8, 2003
  4. They are. The porting may be different, but all the parts are
    interchangeable. I have some RD200 gasket sets, too, I think.
    About 75. Nice little bike, in its way. The early ones had a single seat
    and a topbox fitted as OE, IIRC.
    The Older Gentleman, Oct 8, 2003
  5. mups
    Ballistic had a fit and wibbled.....
    Get the timing checked properly, it's often neglected by people who
    can't afford the kit/services. It's vital that it's right or it *will*
    hole pistons or seize.
    A good RD200 should be hitting about 85/90 on the clock.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 8, 2003
  6. mups
    Och away man, mine did *well* over a ton uphill into a headwind two up. Ah
    had spannies on it y'ken
    Hog, Oct 9, 2003
  7. <Hopeful>
    An' ace bars?
    The Older Gentleman, Oct 9, 2003
  8. mups
    Shit, I forgot them. Oh and Prism tape.
    Only leaves one thing to say.
    Riffler Files.
    Hog, Oct 9, 2003
  9. mups
    mups Guest
    Heh, I reckon there's space in the frame for an RD250/400 motor. Wonder if
    anybody will notice...
    mups, Oct 9, 2003
  10. mups
    YDS7, 'Ahbody known the auld 'un was far faster
    Hog, Oct 9, 2003
  11. mups
    Paul - xxx Guest
    Hog tried to scribble ...
    And the knowledge to use them sparingly .. ;)
    Paul - xxx, Oct 9, 2003
  12. mups
    That old saying comes to mind.
    Faster than a piston skirt up a port.
    Hog, Oct 9, 2003
  13. mups
    WorkTOG Guest
    *Chuckle*
    I likes that, I does.
    WorkTOG, Oct 9, 2003
  14. mups
    There was a magic ratio of port to solid cylinder wall but it elludes me
    now.
    Hog, Oct 9, 2003
  15. No it weren't, you senile old fool.
    RD250E/F was the fastest of the lot, I reckon.
  16. mups
    Why not just buy an RD400?
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 9, 2003
  17. mups
    The Older Gentleman had a fit and wibbled.....
    Correct. The YDS7 felt faster by virtue of it being piston ported,
    giving a much sharper power delivery. The 250E/F topped out at just
    short of a ton, if you had a good one. The YDS7 peaked at about 95 IIRC,
    though there are wildly exaggerated claims of 110mph ones out there.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 9, 2003
  18. mups
    Paul - xxx Guest
    mups tried to scribble ...
    It's likely that 'plod' will. Many police bikers are actually enthusiasts
    as well, and many, amongst the dingbats, are actually quite knowledgable
    regarding bikes - not to mention the MOT station.
  19. mups
    Is that a *Whoosh*?
    Hog, Oct 9, 2003
  20. mups
    mups Guest
    I was thinking about the Furt run. :)
    mups, Oct 9, 2003
