Yamaha Ownership Lesson 1
Discussion in 'UK Motorcycles' started by Mr. Fantastic, Sep 8, 2006.
  1. Mr. Fantastic
    OH- Guest
    A friend of mine used to have a Quota and his had the same appetite.
    Might it be possible to use a generic part rather than the shit
    that the Guzzi purchase managers uncle (or his cousin?) sells?
    OH-, Sep 9, 2006
  2. Mr. Fantastic
    Yeah. I did consider looking in Halfords, specifically at those parts
    used on Fiats. I also have an oil pressure gauge, but mounting it
    would involve cutting holes, which I'm loathe to do. I was also
    worried as to what would happen if the capilliary were to fracture...
    Pip Luscher, Sep 10, 2006
  3. Mr. Fantastic
    Scraggy Guest
    So, lets see
    http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-55_941.pdf
    Page 4 is full of the standard warnings
    Then on Page 3-2 is all the information, including a picture of the
    instruments for the hard of thinking and a paragraph for the less cerebally
    challenged.
    This is precisely *why* one gets a user handbook. 10/15 minutes of light
    reading or a fucked engine? Tricky choice.
    Perhaps less playing , more reading.
    Even if it is too much trouble to read the manual, IMO anyone who fails to
    check the sight glass before a long trip is ...... you fill it in, you seem
    to know everything else.
    Scraggy, Sep 10, 2006
  4. I think you're taking this too seriously, and anyway that's the wrong
    manual.
    Except that wasn't the choice. All I did was mistake the oil level
    light for an oil pressure light.
    Actually I did check the oil level before I set off, as I do at regular
    intervals. Like I said, it seems it's probably just a knackered
    sensor/relay.
    Mr. Fantastic, Sep 10, 2006
  5. Mr. Fantastic
    They're not warnings, they're reasons to buy.
    sweller, Sep 11, 2006
  6. Mr. Fantastic
    My T3 gets through them at quite a rate too. I use cheapy pattern parts
    for a Peugeot.
    As others have said it's a bit pointless as it simply tells you your
    engine is now toast. I've got the charge light to tell me I've left the
    ignition on.
  7. Mr. Fantastic
    It doesn't seem to make any difference if you do, IME.
  8. Mr. Fantastic
    Modern ones tend to be electric.
  9. Mr. Fantastic
    sweller says...
    On RD200s the charge light is known as the seize light. It only comes on
    in normal use when the engine has seized.
    Lozzo, Sep 11, 2006
  10. Mr. Fantastic
    Cab Guest
    My 'old' Megane did (from 2005).
    Cab, Sep 11, 2006
  11. Mr. Fantastic
    Cab Guest
    Here, have a "not"
    Cab, Sep 11, 2006
  12. Dave's Modus has one - 2005 cage. He never bothers checking the oil as a
    result, which I think is not sensible. But then, I had an Avensis which had
    a catastrophic engine failure.....
    Ali
    Alison Hopkins, Sep 11, 2006
  13. Mr. Fantastic
    The Fuglypla has the same. As did the Citroën XM, from 1990.
    platypus, Sep 11, 2006
  14. Mr. Fantastic
    This one ain't modern. I had originally fitted it to my old Austin
    1100.
    Pip Luscher, Sep 12, 2006
  15. Mr. Fantastic
    My charge light only comes on when it feels like it. On both the
    recent occasions that the alternator has fried itself, the only
    warning I got was the tacho needle drooping, followed by the
    indicators going too dim to see.
    I'm impressed that the FI kept going after these symptoms appeared.
  16. It did? Mine never came on - unlike the hydraulics warnings which used
    to come on all the time..
    Especially when our XM rear ride-height adjuster disintegrated and
    dumped the fluid all over the road - from full to zero in about 5
    seconds.
    Driving a car with no suspension, no brakes other than the
    parking-brake and no power assist on the steering was.. interesting.
    In a "this car needs an enema" style of interesting.
    Phil
    Phil Launchbury, Sep 12, 2006
  17. Asking for trouble then, fitting an ancient capilliary gauge to a bike.
    Much better to go electric - the electric OP sensors are reasonably
    small and light nowadays.
    Grimly Curmudgeon, Sep 12, 2006
  18. Mr. Fantastic
    Well like I said, I don't want to cut mounting holes, so it's
    academic.
  19. Mr. Fantastic
    There was something like a gauge which would show oil level when the
    ignition was turned on, then dropped to zero or had another function (poss
    temp) when the engine started. It might not have been on all models, and I
    no longer have the reference. I was never crazy enough to actually buy an
    XM.
    Heh. Done that on a BX, more than once.
    platypus, Sep 12, 2006
