Yamaha AT3 Ignition
Discussion in 'Motorbike Technical Discussion' started by crachau, Jul 17, 2005.
  1. crachau
    crachau Guest
    Would the Ignition coil for a Yamaha AT1 work on an 1973 Yamaha 125cc
    AT3?
    Thanks in advance.
  2. Do both models have ignition points? If so, the AT3's primary coil will
    probably not be too powerful for the AT1 coil. You could get into
    problems with models that had so-called CDI systems that generated 100
    volts from the primary coil.
    Check the parts fiches on this site to see what the parts numbers were:
    http://www.yamaha-motor.com
    krusty kritter, Jul 17, 2005
