XX hoops
Discussion in 'Australian Motorcycles' started by Dave E, Aug 9, 2006.
  1. Dave E
    Dave E Guest
    Hey all,
    That time has come again to re-tyre the 'Bird. I may be able to get a
    pretty good deal on Michelins (pending some enquiries) but am wondering
    whether I should go up on the standard rear size (if only to satisfy some
    ridiculous vanity on my part)??
    Is there any advantage to be gained from a wider rear (tyre)? I seem to get
    about 5k out of a rear though a recent track day has reduced this to about
    4k for the current one. I wouldn't take the near illegal front out in the
    wet at the moment so now is a good time to change both back to Michelin if
    there is an advantage to be had.
    So really 2 questions:
    - if I can get a cracking price on Michelins (say 40% off), should I return
    to them (from 020s),
    - should I look at a wider rear?
    The majority of use is split between commuting 30%, highway 65% and the rest
    track.
    Any thoughts on the matter? Appreciation in advance. :)
    Cheers,
    Dave E (Sydney)
    Dave E, Aug 9, 2006
  2. Dave E
    FuTAnT Guest
    Pilot Powers are good, but you already knew that.
    Anyway, not really my point for this. Seeing as you are getting ... well ..
    ok but average mileage, especially out of the 020s, I was wondering what
    suspension modification has been made (if any) to the Bird. Seeing as even
    revalving the front end and getting the back end massaged doesn't cost too
    much but increases tyre wear, I reckon it's a more than a great idea on all
    fronts. Err yeah, so have you had anything done or is it all stock? Thought
    about an Ohlins/Elka/WP/Penske or something in the back? Had it shimmed up
    atleast at the back or not?
    Cheers
    Cam
    FuTAnT, Aug 9, 2006
  3. Dave E
    Boxer Guest
    A larger rear tyre will affect handling and turn-in, stick with the standard
    size, sufficient wank value was designed in by Honda.
    Boxer
    Boxer, Aug 9, 2006
  4. Dave E
    john doe Guest
    bigger rear tyre will make it slower on turn in.
    if you want it too turn like a 600 go for a narrower taller tyre!
    JD
    john doe, Aug 9, 2006
  5. Dave E
    alx Guest
    Dave, we seem to be wearing out our rubbers at the same rate.
    Need a new fat rear too...nice big black mutha.
    Pirelli's for me.
    alx, Aug 9, 2006
  6. Dave E
    Dave E Guest
    Well you always insist on an even split - right up the middle (as it
    were...).
    Sounds like a black bird I once knew (not so big though...). :)
    Not with Michelins at 40% disc't! hehe
    Cheers,
    DJE :)
    (Waaaay overdue for a beer mate)
    Dave E, Aug 9, 2006
  7. Dave E
    Dave E Guest
    Nothing has been done other than the preload has been wound up at the back.
    Riding it around EC recently 2-up it felt like a bloody marshmallow compared
    with the new 'Blade. I suppose that's to be expected. I know what I'd
    rather be riding over a full day!
    I had considered Ohlins or something - still a possibility I suppose.
    Thanks for responding. :)
    Cheers,
    PS. did you mean 'increases tyre wear' or 'decreases...'??
    Dave E, Aug 9, 2006
  8. Dave E
    J5 Guest
    look at Pilot roads a more modern tyre than 020's
    a power or race on the front ;)
    J5, Aug 9, 2006
  9. Dave E
    Dave E Guest
    Sure - probably not a handling characteristic I want to add.
    As for 'wank value' - the other day I almost couldn't believe it when
    someone actually walked over and looked over my bike. This doesn't happen
    every day and I was very excited until he almost bashed into my RHS pipe
    with his walking frame.
    Cheers,
    Dave E
    Dave E, Aug 9, 2006
  10. Dave E
    Dave E Guest
    Soooo much harder to eliminate chicken strips - I'd have to hand over the
    bike to Crazy Cam or Alx again! :)
    Cheers,
    Dave E
    Dave E, Aug 9, 2006
  11. Dave E
    J5 Guest
    should be decreases tyre wear
    properly working suspension reduced tyre wear
    the cost of getting the suspension sorted is covered in a couple of tyre
    changes
    J5, Aug 9, 2006
  12. Dave E
    Dave E Guest
    Indeed - also very interested in a better riding experience.
    Cheers,
    D
    Dave E, Aug 9, 2006
  13. Dave E
    justAL Guest
    Metzeler Z6's. Give em a go.
    justAL
    justAL, Aug 9, 2006
  14. Dave E
    FuTAnT Guest
    Yer, sorry about the confusion. Sorted suspension reduces tyre wear and
    gives a much better ride as well as more confidence on the bike. Also means
    you have more capacity to deal with "shit" when it "happens". Perhaps try
    just a front fork job and a rear shock massage to start with, buy an
    aftermarket shock later if you feel the need. Shouldn't cost more than $800
    to start with.
    Cam
    FuTAnT, Aug 9, 2006
  15. Dave E
    DonR Guest
    A wider tyre means you'll have to lean over further to take a corner at the
    same speed as with the narrower tyre. Then again you've got more grip to
    play with. So says Tony Foale anyway (page 2-17, Motorcycle Handling And
    Chassis Design, the art and science).
    Rgds,
    Don
    DonR, Aug 9, 2006
  16. Dave E
    alx Guest
    it's all the booze you cart around in the panniers.
    alx, Aug 9, 2006
  17. Dave E
    JL Guest
    Michelin Pilot Power are great. Better than the 020's(1) that were on
    the Raptor from the factory. Well worth a try.
    Wider rear, no, not unless you're having a lot of trouble with it
    spinning up on corner exits and in a straight line. It will increase the
    effort required to turn it in, and is unlikely to improve your wear rate
    unless you never lean more than 5 degrees (2)
    JL
    (1) I'm pretty sure that was what it shipped with, but I could be wrong,
    could have been 010's
    (2) In which case you *might* get a wear rate improvement if the tyre is
    dual compound and hence is harder in the middle
    JL, Aug 10, 2006
  18. Dave E
    Nev.. Guest
    No. When I bought this XX it had a pretty bald rear tyre and I had an
    almost new 190 rear tyre which had been on my ZX12R (going from a 200 to
    190 on the 12R really improved the turn-in). The 190 on the XX really
    did make it turn like a tank.
    Nev..
    '04 CBR1100XX
    Nev.., Aug 10, 2006
  19. Dave E
    Big Bird Guest
    Stick to factory spec tyre sizes.
    A larger width tyre will throw out the handling as the tyre profile will
    change due to the smaller rim.
    Big Bird, Aug 10, 2006
  20. Space the primary out and whack a 280 on, Dave!
    Pisshead Pete, Aug 10, 2006
Similar Threads
Loading...
