XT600 Tail-pipe Removal
Discussion in 'Australian Motorcycles' started by GB, Feb 26, 2005.
  1. GB
    GB Guest
    Hi all,
    How many bolts hold an XT600 exhaust silencer in ?
    Perhaps there are more holding it in than just the Allen's bolt in the end.
    Didn't seem to want to come out.
    All the local grannies will be shaking in their rocking-chairs, when I
    rocket along the street.
    I wonder if leaving it out will improve performance ?
    Thanks in advance.
    GB.
    GB, Feb 26, 2005
  2. There's just that one bolt but unfortunately, unless you remove it regularly,
    the baffle will get rusted in there & be just about impossible to remove.
    It'll make a hell of a lot of noise & definitely give it a bit of 'pep', much
    more responsive to throttle. Many years ago I did a lot of experimenting &
    found that a home made baffle using a 38mm * 125mm pipe & suitable mounting
    hardware kept the 'pep' & made the noise 'almost' legal (back then anyway).
    '84 Yamy XT600, Still goin' strong!
    www.cobracat.com (home of the Australian Cobra Catamaran)
    http://groups.yahoo.com/group/cobra-cat/
    Stan Blazejewski, Feb 28, 2005
  3. GB
    GB Guest
    anyway).
    It must be rusted in. might be tough to get out.
    GB, Feb 28, 2005
  4. GB
    GB Guest
    I didn't say that. An imposter, apparently.
    G
    GB, Feb 28, 2005
  5. Obviously.
    He's a lot funnier than you.
    Postman Pat (Still smarting over the Volley issue)
    Pat Heslewood, Mar 1, 2005
  6. GB
    Rod Bacon Guest
    Should only be 1 screw/bolt, bus as has already been stated, it's
    likely to need a big hammer and a screwdriver to break the rust seal.
    Just be careful in removing it. My TT600 (same engine) has had the
    baffle removed. While it does sound wicked, and give a boost to top-end
    power, it will sacrifice a little bottom-end (although you've got
    plenty 'o that) and may result in your mixture being a little up the
    spout unless you rejet.
    As a minimum, you'll probably need to adjust your needle clip position.
    Rod Bacon, Mar 1, 2005
  7. GB
    GB Guest
    Oi! Shaddup! You're in my killfile!
    Yes, you're clearly quite P'd off about it.
    GB
    GB, Mar 1, 2005
