XT350 flywheel/Mag removal help needed.
Discussion in 'UK Motorcycles' started by Benny, Aug 31, 2006.
  1. Benny
    Benny Guest
    I am trying to remove said flywheel and have removed center bold. Screwed in
    flywheel puller, tightened up and the bastard will NOT come off no matter
    how much hitting with rubber mallet/copper hammer etc will do anything.
    Anyone have any [1] suggestions if im missing something here. Is there only
    the center bolt to remove (can't see anything else). Angle grinder and
    welding gear are standing by.
    Ok, its a 91 model, but other flywheels I have removed in the past have come
    off easier. Its cooled down so is warmish, maybe when cold?
    This is driving me nuts and it has to come off cos the crank seal has gone
    behind it.
    Benny
    '91 XT350 with leaks
    [1] Sensible (ish)
    Benny, Aug 31, 2006
  2. Benny
    Kenny Guest
    What sort of puller is it? If its quite substantial then a good tap on the
    puller bolt, and then a go with an air nut gun should remove it.
    If it still wont move, then the flywheel key may have been lose in the
    keyway, and be jamming the flywheel on the taper. You can get round this be
    carefully drilling down into the keyway, and getting rid of the jammed key.
    If you do start using angle grinder or welding gear, make sure you can get
    another flywheel.
    k
    Kenny, Aug 31, 2006
  3. Benny
    snip>
    Idiot.
    Andy Bonwick, Sep 1, 2006
  4. Benny
    Yeah we all know to get a MAPP torch onto the alternator until it glows
    cherry red then hit the puller with a sledge hammer with moderate force
    Hog, Sep 1, 2006
  5. Benny
    He's an idiot for suggesting trying to drill out a flywheel key. I'd
    sooner **** the flywheel by giving it too much stick with a hydraulic
    puller than **** up the crankshaft keyway with a pistol drill.
  6. Benny
    Aren't those keys hardened, just a little bit?
    Pip, Sep 1, 2006
  7. Benny
    Nope. Keys aren't hardened because that way they'll shear rather than
    the crankshaft performing an expensive party trick.
    Without seeing a drawing I can't be sure but I wouldn't be shocked to
    find that the key is a woodruff key or an enclosed one rather than an
    open ended keyway on the crank and unless someone has developed a way
    to drill square holes then you just can't drill them out.
  8. Benny
    ginge Guest
    ginge, Sep 1, 2006
  9. Benny
    Did you really waste time googling for that?
    All he has to do now is scale it down so it'll cut small enough holes
    and make it capable of cutting steel just to add to the fun. The XT350
    will have been dead for a long while before that happens.
  10. Benny
    Could do spark erosion I suppose but it will just fall off if he does
    the fucking thing properly!
    Hog, Sep 1, 2006
  11. Benny
    I don't know why I waste my time explaining why kenny the kunt is
    wrong but it's too easy to resist.
  12. Benny
    ginge Guest
    Yep, all of 2 seconds.
    It's dead now, it can stay dead.
    ginge, Sep 1, 2006
