XT 550 crankcase oil "pumping" into air box
Discussion in 'Motorbike Technical Discussion' started by Stick, Aug 12, 2003.
  1. Stick
    Stick Guest
    I just bought an '82 XT 550 that had been sitting for a number of years.
    The bike is clean and drives well on the streets with no problems.
    When I drive it on the freeway for more than 10-15 minutes it begins
    to lose power and eventually starts smoking. It appears that the crankcase
    is venting oil back into the air filter....lots of oil. After driving on the freeway
    I stopped and removed the air filter and could see the oil "pumping" into the
    air box. It wasn't just venting, it was pumping oil..you could watch it at idle
    literally pumping oil out. After letting it cool down it seems to go back
    to normal. Does anybody have any ideas what would cause this?
    TIA,
    Daren
    Some BMX trick rider said: "Bones heal and chicks dig scars."
    http://homepage.mac.com/dsefcik
    Stick, Aug 12, 2003
  2. Stick
    Slikboy Guest
    I had the same problem with my 1980 maxim. It was because the rings were so
    worn that the compression was leaking past and pressurizing the crankcase,
    causing oil to literally "pump" into the airbox. Try a compression check
    and see if any (or all) cylinders are low. If they are then that is the
    problem, they are worn or, as Charlie says, stuck.
    Good luck
    Jim
    Slikboy, Aug 13, 2003
