Firstly thanks to all who offered advise, especially Mike Olson & Kaybear. I still have the smoking problem. Lots of white smoke, immediately from startup. I'll go over what has already been done, and wait for any other suggestions. I am about to give up and do what I have been avoiding from the begining. i.e. Give it to a workshop : ( 1) Bought the bike (with smoking problem) with 600 km since re-bore & new 1st oversize pistons & rings. 2) Had a spare cylinder head professionaly done as "my" engineering shop was not happy with the original work. Replaced the head with the original pistons/rings (600km). 3) Was not happy with compression, so checked valves which were not set correctly. Lapped valves, re-shimmed (removed shim stock!! Kaybear) I HAVE OPENED AND CLOSED THE MOTOR 4 TIMES. ONE TIMING CHAIN LINK LEFT. I'll have to order more. : ( All the above was not wasted, as the compression is now very good and consistent accross the 3 cylinders. Problem thru all of the above:- Immediately from startup, a continuous huge cloud of white smoke comes out the exhaust. This is when in idle, cold or hot. I know I have asked this a couple of times, how should I go about troubleshooting? What should I do before opening up again! If I need to replace oil rings, can I get these on their own or must I get a new set? Angelo 1979 XS750
