XS650 - it lives, it breathes
Discussion in 'Classic Motorbikes' started by Hog, Jun 25, 2006.
  1. Hog
    2 new inlet valves
    new tappets
    4 recut valve seats
    de-coked
    new cam chain
    new chain guides
    new cam bearings x4
    fresh 20-50
    carbs balanced
    new silencers fitted
    New rear metzeler
    Everything polished/de-rusted/greased
    Now TOG *this* is how an XS650 should sound! no tinny ringing from the
    top end, engine almost completely silent in fact and not audible above
    the exhaust note.
    Fitting those mufflers wasn't straightforward because of the double skin
    downpipes. Shagging hassle in fact but it's done and it sounds great.
    Took it for a ride tonight keeping the revs down to 4k and everything is
    spot on. Everything is shiny and gleaming. Shall get some pics and post
    them up when I find a tuit.
    Hog, Jun 25, 2006
  2. Hog
    Shep© Guest
    Shep©, Jun 26, 2006
  3. Hog
    Shep© Guest
    Respect.
    And I may not know much but I know which two bikes out of your sig
    give you the greatest pleasure ;-)
    Shep©, Jun 26, 2006
  4. Nice.
    The Older Gentleman, Jun 26, 2006
  5. Hog
    Right, trouble at mill.
    Everything was fine, I've done over 50 miles since the rebuild and it
    was sweet as a nut. Heading over to my garage last night and it gets a
    little hard to start. I was going to check the camchain tension and
    tappets as they should have bedded down.
    By the time I got there it was running like a dog, very hot on the left
    and smoking like a diesel on the right (there is no crossover pipe now).
    The plugs are both black. It pops and bangs at tickover on the right
    too.
    When I first saw the smoke I though "oh ****, a ring". On reflection if
    I had broken one on assembly it would have smoked from the start. If it
    had broken later it wouldn't cause all this wierd running.
    I know it's almost impossible but I'm haunted by thoughts of the
    camchain jumping and the valve timing having moved out and kissed the
    pistons. Realistically I think if you wound the adjuster right off the
    chain run is still too tight to jump even 1 tooth. I re-checked it
    anyway and it had only settled by half a turn on the adjuster anyway.
    The smoke could be a valve stem seal but then again if it was nipped on
    assembly it would have gone quickly I feel and once again it wouldn't
    account for all the wierd running.
    I'm left thinking about ignition and carbs. I *think* the CDI on these
    is pretty good. If I have a major fuelling problem it would account for
    the rough running and the smoke *could* be heavy over enrichment. It's
    not white smoke mind, but still. The black plugs both sides would tend
    to support fuelling.
    Ideas and comments (other than YTC)
    Ah well, at least if the engine comes out again it will be two hours
    quicker than before. No ridiculous crash bars with rusted up brackets
    and no rusty exhaust balance pipe. Most of the reassembly time was spent
    fabricating and fitting the new mufflers.
    **** and double ****, I'm desperate to get this shit out of the way and
    get the RD400 done.
    Hog, Jun 28, 2006
  6. Back to basic checks to start with. Valve clearances, comp test, static
    ign timing, ign strobe, colourtune to see what's happening inside the
    cyls.
    I wouldn't be at all surprised if the carbs have become all wibbly
    inside with vibes - fucked needles, jets, floats. Probably the shock of
    being attached to an unfucked engine.
    Glutton for punishment?
    Grimly Curmudgeon, Jun 28, 2006
  7. Can't be ignition, not really. CDIs either work or they don't. I've got
    a spare unit you can have for nowt if you need one, anyway.
    Smells of valve clearances to me. Dunno why, but it does.
    The Older Gentleman, Jun 28, 2006
  8. Hog
    Yeah it was probably more black smoke than blueish. I don't mind
    stripping the carbs, I shall be well humpty if the engine has to come
    out again. I blame that TOG I do.
    Hog, Jun 28, 2006
  9. Hog
    Well it had the carbs stripped and cleaned. The valve timing was spot
    on. The tappets had settled a little but not much. The sparks were weak
    but then the plugs were black and gungy. It *still* ran badly.
    Quick word with the local shop, the mechanic there has another XS and
    they immediately suggested fuel. Now it's not something one generally
    has to worry much about but they reminded me in NI fuel smuggling is as
    big as drug trafficking. I had looked at the fuel and the smell was ok
    but they suggested that modern white diesel can be heavily contaminating
    the petrol yet be difficult to spot. Sure enough a flush through, new
    plugs and it immediately ran sweetly again.
    Naturally there is a problem. The right hand pot is burning oil now. Why
    does this remind me of Rope? I guess it has broken or damaged a ring
    (hopefully not the bore) or the valve stem seal really didn't like the
    contamination. Compression test and engine out.
    I know where the fuel came from but I'm not kidding myself there is
    *any* chance of pinning them down over it.
    Hog, Jun 29, 2006
  10. Shit. The cunts.
    Grimly Curmudgeon, Jun 30, 2006
  11. Oh, for ****'s sake.
    Bastards.
    Um, I know they 'clean up' red diesel and smuggle white diesel over the
    border, but what's with putting diesel into petrol? I don't get it.
    The Older Gentleman, Jun 30, 2006
  12. Hog
    Adrian Guest
    The Older Gentleman () gurgled happily,
    sounding much like they were saying :
    I suspect it's more that they're not particularly scrupulous about cleaning
    out the tankers between loads.
    Adrian, Jun 30, 2006
  13. Hog
    I expect that is it.
    Hog, Jun 30, 2006
  14. Hog
    So shall we start a book on the likely effects and the cause of the oil
    burning on the right pot now?
    As it is only one side, there is no exhaust balance pipe, I'm thinking
    it has to be either valve guide oil seals or rings/bore. Am I missing
    anything?
    Can anyone suggest a good sourse for XS rings and gaskets? my local
    supplier is closed for a fortnight.
    Hog, Jul 4, 2006
  15. Hog
    TOG Guest
    There's a good supplier in Germany. Google for Mike's XS 9in the USA)
    and it's linked from there.
    TOG, Jul 4, 2006
  16. Judging by the smoke, the SOBoxer is burning some oil on the right pot as
    well, must be catching. I suspect valve stem seals and valve guides on
    that. Got to bite the bullet and spring for some recon heads for it one
    day, and probably a set of rings and a bore hone at the same time. It's
    maxing out at about 85 these days, which is a bit under par as I've had 95
    on the clock before now.
    Austin Shackles, Jul 5, 2006
