Well I finally got the XS engine out of the frame. My god it's heavy, the B&D workmate is straining to support the lump. Everything came apart easily. The two borked cam bearings fell to pieces but one inner race was cold welded on, it Dremell'd off though :o) Pistons, bores and rings all look good however the 5mm play in the cam bearings has had an impact. Left inlet valve looks a little hammered on top, the right slightly less so but still visible. They are not mushroomed though. Exhausts are fine. Does the Group think they would be ok or should they be replaced? I could post some pics. All the valves will come out anyway to be lapped and for the new stem oil seals. The screw tappet that bears on the left inlet valve is in poor shape and deffo needs replaced, the right looks fine but for such a small part it will get changed anyway. Here is the blind sider though. The front camchain tensioner blade rubber was detached from the alloy carrier and had slipped down. The carrier had seen a little contact from the chain at the top 10mm. Is this a known fault? it's a weird one and if they are scarce I guess it will need to be bonded back into place.
