XS650 custom
Discussion in 'Classic Motorbikes' started by Tom, Jul 1, 2004.
  1. Tom
    Tom Guest
    I have been offered a XS650 custom which has been stood for some time.
    The bike runs and sounds fine, it has no MOT abd brakes are binding, I
    guess due to fact it has not been used for a few years although you
    can push it about. There is very little if any rust, the bike was
    imported from USA early 1990's.
    There is a little oil on head around the exhaust manifold, I think
    this is coming from exhaust as it is blowing there on both sides (the
    pipes them selves are good).
    The battery is also dead.
    Does anyone have a guess at value?
    What would a brake service cost?
    Is there anything I should look out for?
    New to biking and will be first bike after DAS.
    Thanks
    Tom, Jul 1, 2004
  2. OK, it's a bit doggy, but the XS650 is a *cracking* bike with the best
    parallel twin engine ever built by any anufacturer *anywhere*.
    Fact.
    Value? Depends entirely on condition. The custom versions (and virtually
    all US imports are this type) are worth less than the straight
    roadsters, though.
    If in good clean running order, 1000-1400 quid. Bear in mind you can
    easily spend two grand in getting one to this sort of nick (check my
    home page - there's a pic on it of the last one I restored).
    Brake service? 30 quid if you DIY. Could be three to five times that if
    you let a dealer do it. It depends on how badly the brakes are corroded.
    Look-out points: the US versions used a different length of conroad and
    a different piston to achieve the same swept capacity as European
    versions. Strange but true. So UK rods and pistons may not be
    interchangeable. The Man Who Knows is Tony Hall of Halco Engineering,
    near Salisbury (do a web search or check the classic mags).
    For the rest - any smoking from the engine means the rings are shot, the
    gearbox is crunchy, the electric start *always* breaks, and it has two
    oil filters - one's a mesh screen in the sump, and the mesh breaks up.
    The Older Gentleman, Jul 1, 2004
  3. Tom
    JB Guest
    This may be a worrying issue or it may be trivial. Clean properly around the
    area. It may just be coming from tappet cover. (is it the square cover with
    4xM8 dome-nuts on it, not the triangle ones with 3xM6 dome-nuts?) it is
    likely just a gasket or O-ring. The later ones had O-rings which seemed to
    be worse than the older thick gaskets.
    Who cares. It's only a battery.
    For a mechanically sound XS650SE with the engine number beginning
    447-???????, about £400-£500. The later ones with the engine number
    beginning 3L1-???????, about £100 less.
    If it's got the later single disc, single piston floating caliper, you can
    get the rebuild kit forabout £16.00 from M&P. www.mandp.co.uk
    If it's an earlier one, fit a Lockheed/Girling caliper.
    Yes. Top end noise: there should not be much at all. Camchains are cheap and
    easy to fit, but the valves pit badly on the top of the valve stem if crap
    oil is used. Also the 2nd/3rd gears can suffer engagement-dog breakage. (you
    find out when changing the oil by removing *both* of the 27mm oil drain
    bolts. As they have magnets embedded in them, the rear-most one catches the
    broken gear bits!
    The earlier engines (447-????) are much better, as they also have an extra
    clutch plate (7 versus 6). You can modify them very heavily too.
    If you can get it cheap, do so. They handle like shit in the standard form,
    but there is lots you can do with an XS650.
    Check out http://www.halco.co.uk/halco.htm
    Tony Hall is *God* when it comes to these Yams. Trust him with your
    hard-earned cash and you will get a very nice bike indeed.
    HTH,
    JB
    JB, Jul 1, 2004
  4. You'll be damned lucky to pick up an XS that doesn't need mechanical
    work for that sort of dosh. That said, my neighbour's just found one.
    He's a builder/chippie and it was just sitting in the garden of some
    bloke he was doing work for. He got it for (I think) 250 quid, the lucky
    sod.
    Its a cosmetically challenged SE model (UK version) but sounds sweet.
    Needs new chrome, new paint, new exhausts, new tyres, brakes sorting
    out, etc etc but as a project bike, pretty fine. I reckon another
    500-600 quid would see it looking really good, and it would actually be
    worth a grand.
    I always thought the XS650 Custom looked good, but you really want the
    straight roadster one, especially the B (which is the only model I've
    ever owned, times three) with its double discs and early opposed-piston
    calipers.
    Another thing about the engines - they run very hot because they don't
    carry much oil (the earlier kickstart-only XS1 carried more oil, but the
    inclusion of an electric starter system occupied the space for the oil
    on later bikes) and you must use 20/50 oil in them, not 10/40.
    Electronic ignition is a good mod if only because of the extraordinary
    ignition, with the auto-advance on the right hand end of the camshaft
    and the points on the left, and a rod running right down the inside of
    the hollow cam (!) from one to t'other!
    And beware the oil feed pipe on the front of the block (the one that
    looks like a pushrod tunnel) as it's incredibly easy to overtighten the
    adaptor that screws into the cases and strip the thread in the cases.
    DAMHIKIJK,OK?
    The Older Gentleman, Jul 2, 2004
  5. Tom
    JB Guest
    I prefer buying a known 'dog'. Hence the price quoted above. At least you
    know the score is then.
    I too preferred the older B. Nicer looking bikes.
    On all mine (I've owned nine over the past 20 years!), I fitted the Halco
    oil cooler take-off kit and a good oil cooler.
    Ding. Pirhana ignition. That bloody advance and retard system was very
    susceptible to self destruct. The little circlips get worn and fall off and
    as a result, the points cam doesn't turn. This resulted in me thinking I had
    a snapped camchain once, and I ahd actually removed the whole engine and
    started strippingf it all dwon when I found the fault!
    Been there. Bought 3 engines with that fault/bodge. Not an easy place to TIG
    weld/tap/helicoil either.All things considered, I reckon it was indeed the finest parallel twin
    engine ever produced.
    JB
    JB, Jul 2, 2004
  6. Tom
    TDM 850!
    Ace, Jul 2, 2004
  7. Tom
    JB Guest
    Overcomplicated and ugly engine. Best kept hidden behind plastics. However
    it is indeed very powerful for a parallel twin. The XS650 engine is a nice
    looking lump and being a SOHC aircooled lump and is effectively bombproof
    (it takes boring and stroking to over 1150cc on standard mains/bigends etc),
    also has a cleaner design with less pipes and giblets hanging off it. Also
    maintenance is a piece of piss with the XS lump too. Ever done the valve
    clearances on a TDM?
    Personal choice though I suppose.
    JB
    JB, Jul 2, 2004
  8. Tom
    More a different way of judging, I think. To my mind, an engine is
    there for one thing only. What it looks like or how easy it is to
    maintain (I mean, what are dealers for, FFS?) are pretty much
    irrelevant to my way of thinking.
    Ace, Jul 2, 2004
  9. Tom
    JB Guest
    Again each to his own. I actually like looking at and appreciating the
    design of a bike in addition to actually riding it. The 'look' of an engine
    can add to (or detract from!) the appearance of a particular bike and make
    it stand out from the plastic-encased UJM clones (CBX1000 and Jota are two
    that immediately spring to mind). Also the maintenance/repair aspect is (for
    me at least) an integral part of the whole experience. I actually enjoy
    spannering. It is probably the best way for me to unwind after a day behind
    a CAD screen. I actually like buying an old dog and getting it running
    sweetly again at a sensible cost, runnig it for a few months then selling it
    and getting the next 'project'. For what it's worth, I've *never* lost money
    on any vehicle I've ever owned. Even if I could afford to pay dealers for
    working on my vehicles I still wouldn't, as many (IME) are incompetent at
    best, and not at all interested in the bike itself, only getting the job
    done in the quickest and cheapest way possible for them to maximise profit.
    Bike dealers are *much* better than car dealers from what I've seen though.
    Many times I have seen the results of missing or loose bolts, incorrectly
    used or no torque wrench used at all on fasteners, incorrect replacement
    parts used or incorrectly fitted, threads stripped, studs snapped etc...
    JB
    JB, Jul 2, 2004
  10. Tom
    On Thu, 1 Jul 2004 22:38:40 +0100,
    Hmmm. You do know that the length of the conrod doesn't affect the
    stroke, don't you? Do you mean that the throw on the crank is
    different?
    Champ, Jul 2, 2004
  11. Tom
    But the length of the conroad could do almost anything, depening on
    WTF it actually is.
    Ace, Jul 2, 2004
  12. Yes, I do. Sorry. Badly phrased. What it is is that the conrods are
    actually longer and the pistons shorter, believe it or not.
    So you can put US pistons on UK rods, but try UK pistons on US rods and
    they hit the valves.
    I know, I didn't believe it either. But ask Halco if you like.
  13. <AO-feckin'-L>
    I have lost money on a few bikes, but only ones I've kept for years &
    years. And you are *so* right about incompetent dealers.
  14. Fucking awful thing.
    The 900 might be better, mind.
  15. Tom
    Buzby Guest
    Visions of Lloyd Grossman
    Buzby, Jul 2, 2004
  16. Tom
    Fucking awful thing.[/QUOTE]
    Eh? The engine in the original 180deg job was universally acclaimed as
    being a modern day marvel. Smoothness and tractability were amazing.
    Well it's ten years newer, so it should be.
    Ace, Jul 2, 2004
  17. Tom
    That's not what a long rod is for.
    http://www.650motorcycles.com/RodAngle.html
    platypus, Jul 2, 2004
