XS 500 Problems
Discussion in 'Motorcycle Technical Discussion' started by Ben Weech, Apr 15, 2005.
  1. Ben Weech
    Ben Weech Guest
    Hi all,
    I recently aquired a Yamaha XS500 to restore.. admittidly its my first
    'proper' bike (only had a honda C90 before)
    Its not in bad overall condition, I just cant get it to start. My
    thoughts are that the points are set badly, and maybe the cam timing
    is out. There is fuel getting through, and spark, and it will pop and
    bang a bit, but it wont catch.
    Does anybody know the procedure for setting the timing of the cams and
    the points? And any other tips as to why is wont start?
    Ben.
  2. as to why is wont start?
    Your motorcycle has what are called "constant vacuum" or "constant
    velocity carburetors", commonly known as "CV carbs"...
    CV carbs don't have a proper choke plate like a car's carburetor.
    Instead, they have a starting enrichener valve built into the side of
    each carb...
    When you lift the "choke" lever on the side of the carb, you are
    opening a little throttle valve in a port that bypasses the throttle
    butterfly...
    The starting enrichener sucks gasoline right out of the float bowl
    through its own starter jet, it doesn't use the idle set to get its
    fuel supply...
    But vacuum downstream of the throttle butterfly is very weak in a four
    stroke engine. The throttle butterfly has to be closed all the way.
    There should be a master idle knob between the two carbs. It may be on
    top of the carbs or underneath. Turn that knob all the way
    counterclockwise to close the throttle butterflies completely so you'll
    get more vacuum to suck starting fuel/air mixture into the engine...
    And, when you try to start the engine, avoid turning the throttle
    handle at all. If the idle fuel/air mixture has been set correctly, the
    engine should start without turning the throttle handle at all, and the
    idle speed shouldn't race up too high when you have the "choke" lever
    in the full ON position...
    If you get the engine to start, you can nurse the engine with the
    throttle to keep it running until it warms up, then set the master idle
    knob back to where the engine idles at the correct speed when it's
    warm...
    But, your idle jets might be dirty and plugged up. The starting
    enrichener needs the help of the idle jets to start the engine...
    If the engine still doesn't want to start, you're better off trying to
    hand choke it to get it running the first time. Just hold your hand
    over the carb inlets while trying to start the bike. You'll know you're
    sucking gas up out of the float bowls if your hand gets wet with
    gasoline...
    It's a lot of work to remove the carbs and clean out the jets if you
    find that they are too dirty to allow the engine to run right.
    I have described the process about 100 times at least, you can find it
    by googling up "kaybearjr@aol +cv carbs +idle jets"
    I recommend adding 2 or 3 ounces of Berryman's B-12 liquid ChemTool
    carburetor cleaner to a tankful of gas and running the engine to see if
    the idle jets will clean out. Avoid getting the engine really hot or
    using high RPM while you're doing this cleaning process, the alcohol
    and acetone in B-12 will wash the film of lubricating oil off the
    cylinder walls and you could scuff the cylinder bores...
    You can also get Berryman's B-12 carb cleaner in an aerosol canif you
    just have to remove the idle jets for cleaning...
    krusty kritter, Apr 16, 2005
