XR75/80 into YZ80?
Discussion in 'Motorcycle Technical Discussion' started by Brian Watson, Aug 23, 2005.
  1. Brian Watson
    Brian Watson Guest
    I am considering a project - mainly for fun but I hope the end result
    will work. I have an 11 year-old son and I would like to get a bike for
    him. We live in town and he will not get to ride it often so I don't
    want to spend very much. I like the power characteristics of the old
    XR75/80s, but the have rubbish suspension. I can get a 1985 YZ80
    rolling frame cheap. I would hope I could pick up an old XR75 cheap. I
    have done a bit of research and found people like BBR that will do
    really nice conversions, but this is a bit beyond what I am looking at.
    I have access to welders, steel etc. and am capable of basic fabrication
    work. But, I am not planning to build a whole new frame :)
    Can anyone say if this will basically "fit", or am I off my rocker?
    Thanks,
    Brian
  2. Yes, you are insane. Anybody who fools around with motorbikes has to be
    nuts about them. Anybody who wants to get that deep into a motorbike
    that he wants to swap engine should be locked into his garage and told
    to "Go for it!"
    Drive chain tension and antisquat properties of the drive chain
    geometry are more important than the size of the XR75/80 motor, which
    is probably taller than the YZ80 motor. You can get a general idea of
    how tall the XR motor and YZ motor are from scaling off of drawings you
    may find on the web. I prefer drawings. Photographs can be very
    deceptive. If you find a photograph of a side view of the motobike in
    question and the tires look oval, you can use the height of the tires
    for a scaling reference instead of the wheelbase. I would rather use
    the wheelbase for a scaling reference, but cameras distort the view
    with their wide angle lenses.
    Once you have an idea of how much taller the XR motor is, you can
    decide whether to buy the roller.
    Don't worry about existing motor mount brackets, you will probably
    fabricate your own motor mounts.
    The first thing you need to do is locate where the center of the
    countershaft sprocket needs to be located vertically from the lower
    frame rails and how far forward it has to be from the center of the
    swing arm pivot.
    The top run of chain probably lays on top of the front of the swing arm
    with nobody on the bike, so you at least need to set the XR75/80 motor
    in the frame to have its weight compressing the springs. Then see how
    far the engine has to go forward to tension the chain to the minimum.
    Once you've located that position in space within the YZ80 frame, you
    can figure out where the top of the XR75/80's cylinder head will go and
    you can start planning motor mount brackets. If you have to alter a
    horizontal frame tube that braces the steering head to make room for
    the XR's head, you can install a bent tube in its place.
    (When Honda developed their 4-valve per cylinder CB-750F/900F/1100F
    models, the cylinder head was so tall they needed to not only bend the
    lower steering head brace, they had to design a removable lower side
    rail to get the taller engine in and out of the chassis...)
    Be sure that the YZ frame allows you to get at the valves to adjust
    them.
    And, check to see if the shifter pedal will hit the lower frame rails
    when you downshift.
    Otherwise, anything is possible, it's just a matter of how much
    modification you need to do and whether the quality of the work is up
    to motorbike standards.
    krusty kritter, Aug 23, 2005
  3. You must mean on really tight "motocross" tracks where the big bore
    bikes are too big and heavy to turn easily. Calvin Franks and Stu
    Peters brought motocross to California about 1969, and I was in the
    California Motocross Club, one of the first thousand members of a sport
    that went insane immediately...
    The whole idea of motocross is racing on natural terrain, whatever kind
    of terrain that might be. The natural terrain of southern California is
    deserts, rocky hills, sand dunes, cliffs(!), and dry sand washes with
    sloped walls you could ride on. The AMA desert clubs were doing
    something similar to what motocross was really supposed to be about
    when they ran "European Scrambles" in the desert.
    But Calvin and Stu had been to Europe and thought motocross should be
    about MUD, and that it should be a spectator sport where everything
    happened close to the onlookers, with mud, barrel turns, and unnatural
    built up jumps that squashed the suspension and bent the wheels on
    landing...
    And so the tight tracks like Indian Dunes and Saddleback Park were
    built and there were no 70 mile an hour straights where the big bikes
    would come into their own. Instead, the 125's were quicker because they
    didn't weigh anything and didn't dig ditches with their power.
    There were so many youngsters and even females wanting to try out the
    new sport of "motocross" as conceived by the entrepreneurs, they would
    have to run five or six divisions of juniors in every class, they
    didn't have time to run three 45-minute motos for each class, I was
    lucky to run in two three-lap races and get three laps of "practice" in
    on a Sunday race day...
    At that time, the motorbikes that I hated to have to race against were
    the CT-175 Yamahas. I was on a 250cc DT-1, and the CT-1's had shorter
    wheelbases, so they could get around the tight hairpins more easily...
  4. Brian Watson
    Brian Watson Guest
    That's what I had gathered from the reading I have done, and it's
    probably the level of work that is just beyond me. I'd really like it
    to slot into the existing cradle. I think I'll take krusty's advice
    here and see if I can find a few photos that look to be nice and square
    and do some scaling. The photo's I have seen of YZs this age look to
    have lots of open space up there but I understand it is a combination of
    countershaft position and space that I need.
    I don't want to go hot - remember this is for my 11 year old to learn
    on. But I would maybe warm it up a little as he gets used to it.
    My opinion there was formed by having an RM80T when all my mates had
    XR75s - just no comparison!!
    Yep - been there. Lots of cool little bikes!
    Yep again - I can see myself putting a few kilometres on this if I ever
    get around to doing it.
    Thanks,
    Brian
