So I found a good complete head for my sons Xr100. Question is, I can flycut the head to increase the compression a bit. How much do I take off to run the bike on 89-92 octane? Or if someone can give me the the correct compression ratio on this bike for the above octane range, and the bore & stroke, I can figure the flycut depth from there. any other suggestions before I jump off this cliff? This was the bike that jumped the timing chain, and bent a valve. Do I need to replace the chain too? I am replacing everything in the top end but the timing chain, so far. ca
