XR Starting Question
Discussion in 'Motorbike Technical Discussion' started by Rob Munach, Jan 27, 2004.
  1. Rob Munach
    Rob Munach Guest
    My old '83 XR200R always started first kick, hot or cold. My '99 XR200R
    is a PIA to start if the weather is cold, not so bad when the weather
    warm. Every other new XR200R that I have seen is also a PIA to start. Is
    this simply due to changes in the carburetors? Do you think that if I
    bought a used carb from an old XR that it would make it start like an
    OLD XR?
    FWIW, Mine has been re-jetted (XR's Only) and it made no difference.
    Thanks,
    Rob Munach
  2. Rob Munach
    Rob Munach Guest
    The idle mixture screw is available. I'll give it a shot.
    Thanks.
  3. Rob Munach
    Johnnie5 Guest
    yep guaranteed to start my XR280 after its been in the shed for 6 months
    gotta get the fuel into it
    I also Increase the idle speed as well which helps, then adjust when started
    Johnnie5, Jan 30, 2004
