XJ600 '91 monoshock linkeage broken.
Discussion in 'Motorbike Technical Discussion' started by René, Jun 9, 2005.
  1. René
    René Guest
    As the header suggests - while riding I was slowly lowered on the rear
    wheel while crusing on the highway. Rear wheel chafing the
    wheelarches.
    The xj600 is pre-diversion model.
    I found the monoshock hinge on the center stand was torn of and peeled
    back.
    Questions:
    - Any history of this bike doing that more often?
    - How to fix? re-welding seems poor idea as metal is too thin
    walled, amy weaken the rest of the frame as well IMHO, somebody did
    this?
    A new frame is way to costly, a second hand frame probably has the
    same potential weakness - also no budget to have all parts built over
    to a new frame.
    I am thinking of making a small subframe that connects to the
    engine-bearing 12mm bolt + footrest bolts, and runs parallel to the
    former centerstand bearing tube. (12mm bolt taking up most of the
    load. Force distribution seems sound.
    Only fitting the exhaust my require some fiddling...
    But not good to re-invent the wheel - opinions welcome.
    René, Jun 9, 2005
