WTF is wrong with my bike?
Discussion in 'UK Motorcycles' started by MattG, Nov 22, 2003.
  1. MattG
    MattG Guest
    The bike broke down some time ago, I say broke down, it started making some
    very unpleasant rattling noise from the engine. So recovery was arranged,
    bloke had a listen and pronounced "cam chain", which was kinda what I felt
    it might be.
    So, bike into the kitchen, and take a look.Cam chain is nice and tight, a
    little lateral movement but I can't pull it away from the cogs, which I
    imagine to be a good thing. Does this eliminate the cam chain as a source of
    the mystery noise, or do I need to do something else to it?
    If it's considered unlikely to be the cam chain, any suggestions on what to
    check next? Having just bought and installed a new boiler, I'm lacking the
    funds to "get a man in".
    MattG, Nov 22, 2003
  2. What bike is it?
    Could be the tensioner - sometimes they rattle when cold, and then
    decide to work and the rattle goes away.
    Might not be camchain or tensioner at all, in which case it often starts
    getting expensive.
    The Older Gentleman, Nov 22, 2003
  3. MattG
    petrolcan Guest
    My recent fuckwittedness on the Z400 was initially diagnosed as being
    camchain rattle, turned out to be the screw and locknut working
    loose. I ended up having a top end rebuild courtesy of Speedy Spic
    Engineering (tm).
    I know your bike has shims but when were they last checked?
    petrolcan, Nov 22, 2003
  4. MattG
    MattG Guest
    Oh yeah, ZX6-R G1
    The tensioner that's in is about 12 months old. I've got a new one here
    anyway, so I could bung that in and see if it helps.
    That's what I thought. Suggestions on what to look at next?
    MattG, Nov 22, 2003
  5. MattG
    MattG Guest
    About 12 months ago. I may as well take a look at them, since the bike is in
    bits across the kitchen floor.
    MattG, Nov 22, 2003
  6. Hmmmm... alternator drive, if that's chain....
    It depends where the noise is coming from. A camchain rattle sounds very
    different from a valve whose clearance is too big, if you've heard both
    sounds.
    FWIW, my money is on the tensioner. They changed the design of the ZX6
    tensioner from a ratchet type on the Fs toa Honda screw-in type (like a
    CBR600) on the G1 and it stuck and rattled (like a CBR600). They changed
    it back to a ratchet type on the G2, and all was well. The G2 type is a
    straight retro-fit to the G1. If you replaced the original tensioner
    with another exactly the same, this is almost certainly your problem.
    All G1s should have been converted under warranty, but.....
  7. MattG
    tallbloke Guest
    Clutch bearing: Does the rattle stop if you pull the clutch in? Is the
    clutch centre nut loose?
    Gearbox final drive bearing: has the chain been overtensioned?
    Compression: is it even across all cylinders? Possible stuck valve?
    Alternator rotor come loose: Check clearances.
    tallbloke, Nov 22, 2003
  8. MattG
    MattG Guest
    No, that's a direct drive (I think)
    I've not, so I'm guessing. I might as well check the valve clearances.
    The replacement was ratchet type one. The noise was first heard whilst the
    bike was warm (25 miles at a ton plus).
    So the next thing on the list is the valve clearances...
    MattG, Nov 22, 2003
  9. MattG
    MattG Guest
    No and dunno.
    Not as far as I know, but noise is present when in neutral or in gear.
    No idea. Will have to borrow a compression tester
    Worth a look.
    I'll check the valve clearances first, cos I reckon I can manage that by
    myself. After that I'll start my way down your list. Ta.
    MattG, Nov 22, 2003
