Wtd: Moped of some description
Discussion in 'UK Motorcycles' started by JackH, Oct 10, 2008.
  1. JackH
    JackH Guest
    Doh... well spotted.
    Erm... VFRs... I can give them up any time I want to... honest.
    I've unfortunately been laid off from work this week.
    Looks like I won't be as lucky with the next role, as in, it won't be
    walking distance from here.
    So I've decided it's probably better to ruin a VFR over the winter than the
    R6, which will probably be tucked away once the salt is on the roads until
    the spring.
    Aside from anything else, the VFR is more likely to stay sunny side up when
    it gets a bit greasy out there.
    JackH, Oct 11, 2008
  2. JackH
    JackH Guest
    TIA
    JackH, Oct 11, 2008
  3. JackH
    Mate of mine had one of them in ... 1976. He was a hero because his
    Puch was faster than all the Fizzies - and he could outbrake them too.
    It met an unfortunate end one night when he was on the way down a slip
    road to join a dual carriageway - and met a prick driving a MKIII
    Cortina coming up. Said prick had missed the off slip, so flicked his
    lights off and screwed it round, then nailed it up the on slip. Puch
    impacted bonnet at an estimated combined 70mph, carving a vee nearly
    halfway up the bonnet. Rider went through the windscreen (not
    laminated then, of course) and all 6'3" of him ended up on the rear
    parcel shelf in a hell of a mess.
    Cortina and Puch went to the pound on one truck, inextricably linked.
    Pip, Oct 11, 2008
  4. JackH
    Oops, clumsy. Errr, sorry to hear that I mean.
    London again?
    Good plan, but if I were you I'd get a proper tourer instead.
    Timo Geusch, Oct 11, 2008
  5. JackH
    des Guest
    Heh ... karma at work.
    D.
    des, Oct 11, 2008
  6. JackH
    JackH Guest
    Blessed are the 'IT Centralisation'isti'...
    Hopefully nearer than that. Or maybe even further a field - depends on what
    turns up. :)
    FWIW, I'm pretty fed up with 'Managed Service' - AD / Exchange are something
    I've managed to get quite handy with, so may try and land something that
    focuses more on that than anything else.
    Yebbut... I *like* riding VFRs, and they do stupidly high miles with minimal
    maintenance.
    That, and I've got access to, quite literally, a shedload of spares for one,
    plus still have the Givi Wing Rack etc.
    Anyway, enough of that... the A8... given the start price, (and the fact I
    missed the end of the auction), CIHAGM? ;-)
    JackH, Oct 11, 2008
  7. JackH
    JackH Guest
    When I posted the above, I expected to see something along the lines above
    posted by you - you're nothing if not predictable.
    But anyway... with regards to karma, if you believe in this, then I think
    I'd be ever so slightly worried if I were you...
    JackH, Oct 11, 2008
  8. JackH
    Fair enough. Best all of us can hope for at the moment.
    While I think Exchange is a bad mail server, at least that skill should
    be in demand.
    Well, I do like them as well, but you get better weather protection from
    a full-on tourer. Helps in the winter etc.
    Good point.
    Is that a go that would involve beer tokens? :)
    Yesbut - someone's trying to come down next weekend to see it so I guess
    it would have to be tomorrow if you wanted to come over. I'm around all
    day, most likely stuck in the garage.
  9. JackH
    JackH Guest
    It is... just not on my doorstep going by initial forays out into the world
    of job-shites etc.
    If a Pan is anything to go by, then I'm not too fussed - I found that last
    VFR750 I used for punting back and forth to London ideal in terms of poke vs
    comfort vs manoeuvrability.
    Heated grips are my main 'must have' these days on anything I'm going to
    ride through winter, and I happen to have two sets of those sitting here...
    if I can remember where I've stashed them away.
    It will involve a PC processor fan if nothing else. ;-)
    Ok... I'll give you bell tomorrow AM.
    JackH, Oct 11, 2008
  10. JackH
    As usual then.
    Actually the Pan isn't that great when it comes to weather protection -
    both the K1100LT and the R1150RT are *much* better. I'd still say the
    1100LT wins but I'd like to try the 1200LT at one point because that
    looks even "better" in terms of weather protection. But with all the
    plastic they're a pain in the arse (read: expensive) to service.
    Heh. Sounds like my garage. Agree on the grips, though.
    Sounds like a plan then.
