WTD: GT380 switchgear
Discussion in 'Classic Motorbikes' started by Timo Geusch, Dec 31, 2003.
  1. Timo Geusch
    On the off-chance that someone's got the handlebar switchgear for one
    of these bikes gathering dust somewhere...
    Whoever put the Dunstall kit on the bike had an interesting way for
    sorting out the 'leccy bits so I intend to do it properly, but I guess
    the switchgear is knackered.
  2. GT380 switchgear was standard Suzuki pattern - the same as fitted to the
    GT125, GT185, GT250, GT550 and GT750 (except for the inclusion of an
    elecric start button on three of those models) so it should be easy to
    locate.
    The Older Gentleman, Dec 31, 2003
  3. Timo Geusch
    Bob Scott Guest
    I believe the same switches were fitted to most of the big laverdas
    except for them that got Lucas switches.
    I take it X7 switches won't do instead?
    Bob
    who's got X7 switches galore.
    Bob Scott, Dec 31, 2003
  4. Timo Geusch
    Rasman99 Guest
    Rasman99, Dec 31, 2003
  5. Timo Geusch
    Bob Scott was seen penning the following ode to ... whatever:
    TOG? Do you know if those would fit?
    Timo Geusch, Jan 1, 2004
  6. Timo Geusch
  7. They're a different pattern. They'd probably work, but they're probably
    not a straight plug-in replacement.
    The Older Gentleman, Jan 1, 2004
  8. Timo Geusch
    The Older Gentleman was seen penning the following ode to ... whatever:
    Fairy snuff. Anyway another lurker/poster had contacted me yesterday
    and he appears to have quite a lot of GT380 parts for sale, including
    the switchgear.
    Ohmygod, I can see this turning into another exorbitantly expensive
    "restoration". Especially because the seating position is a bit pants
    (original handlebars turned upside down and standard footrests) so I'd
    probably need rearsets and/or clipons.
    Arrrgh.
  9. Timo Geusch
    Jota bars
    YKIMS
    Hog, Jan 1, 2004
  10. Timo Geusch
    Hog said...
    I have a rusty pair here that will easily rechrome, I dunno what I'll be
    doing with them tbh.
    Lozzo, Jan 1, 2004
  11. Timo Geusch
    deadmail Guest
    Selling them to Timo?
    deadmail, Jan 1, 2004
  12. Timo Geusch
    said...
    I think donate would be more appropriate
    Lozzo, Jan 1, 2004
  13. Timo Geusch
    If Timo doesn't want them, I'd like to register my interest.
    ....please.
    sweller, Jan 1, 2004
  14. Timo Geusch
    sweller said...
    Noted, I'd be happy for either of you to have them.
    They are a touch scruffy, but either a rechrome or sandblast/powdercoat
    will make them good again. I think they'd suit either the GT380 or the
    Guzzi well.
    Lozzo, Jan 1, 2004
  15. Timo Geusch
    Lozzo was seen penning the following ode to ... whatever:
    *perk*
    I think I night just point the Suzuki your way so we can check if
    they'd fit.
    That is, if I make it that far...
    Timo Geusch, Jan 2, 2004
  16. The ones on Project Boxer are OK. Ideally, they'd be shortened a bit, I
    think, but I never got a tuit for that.
    Austin Shackles, Jan 2, 2004
  17. Timo Geusch
    Guest Guest
    FWIW, the left-hand ones are the tough ones to find, because they fail
    (too much headlamp current through weak switch contacts - overheat &
    melt).
    I've seen two sets come up on Ebay over Christmas - they're not that
    uncommon. If you have intact plastics (mainly the switch slider), the
    copper contacts can be made.
    I got my replacement set from Germany, also a set of forks(!). Done
    several purchases from there via eBay - guys have been great to deal
    with in every case, and postage hasn't been expensive.
    You're welcome to my old switches, but I'm not going to get to the
    wiring until the summer now.
    Incidentally, can anyone suggest what to do about split rubber boots on
    forks. I've two pretty good sets of forks now, both marred by split
    rubber - can it be glued or can pattern parts be had (suspect they're
    rocking horse droppings...)?
    Regards,
    Simonm.
    Guest, Jan 2, 2004
  18. Timo Geusch
    SpamTrapSeeSig was seen penning the following ode to ... whatever:
    Great, that would explain the "interesting" light circuit on
    mine. Time to buy a relay or five then...
    Mine are simply plain sh*te, but another ukrmcer has offered me a
    bunch of parts for it. Hope that those switches are at working...
    Timo Geusch, Jan 3, 2004
  19. Timo Geusch
    Guest Guest
    Pretty much the conclusion I came to as well. I haven't looked hard at
    the second one I've got yet (the original has crumbled), but I'm fairly
    certain you can nick bits from other contemporary bikes. I had a GP100
    for a while (but found it a home :) ) and the switches on that were very
    similar.
    It's the plastics that crumble/melt. If the actual sliders are OK, you
    may be in business.
    IMHO, Suzuki were in league with LPOD: the wiring gauge of the whole
    loom and the current capacity of the connectors are way under-spec.
    Whilst that doesn't help the illumination though it may have saved the
    switches!
    Regards,
    Simonm.
    Guest, Jan 3, 2004
  20. When you say "boots" do you mean the small rubber dust seals? because
    they're available anywhere, just about - one size fits all. If you mean
    fork gaiters, then pattern ones are equally easy to find. Dirt bike
    shops are the first place to look.
    The Older Gentleman, Jan 3, 2004
