WTD: Garage space for one bike over Chrimbo
Discussion in 'UK Motorcycles' started by Timo Geusch, Dec 14, 2003.
  1. Timo Geusch
    Oops. SWMBO has just expressed her extreme pleasure about the fact
    that the garage is so full, you couldn't swing a mouse in there. And
    that's with her pushbike residing in her bedroom, which pleased her
    even more.
    So, if anyone in reasonable distance[1] has enough space in his garage to
    provide temporary accomodation for either the Bimota or the Suzuki
    (preferably the former, I can leave the Suzuki outside under a cover;
    the alloy not gonna fur up any more) then could you please get in
    touch?
    Would need to drop the bike off between now an Thursday
    afternoon. Payment in $curry or $beverage, cash as last resort :).
    [1] From North Finchley, that is.
  2. Timo Geusch
    Timo Geusch said...
    Do I get to use it?
    Lozzo, Dec 14, 2003
  3. Timo Geusch
    Lozzo was seen penning the following ode to ... whatever:
    Well, I did offer you a go, didn't I?
    Under two conditions, yes:
    - It stays inside when it's wet outside. Too much untreated alloy for
    that. TBH, some of the alloy needs a polish already but I was
    planning to do that soon anyway.
    - You bend it, you buy me another one, 'cos you won't be able to find
    the parts...
  4. Timo Geusch
    SteveH Guest
    Not exactly local, but I'm sure I could manage it.
    SteveH, Dec 14, 2003
  5. Timo Geusch
    SteveH was seen penning the following ode to ... whatever:
    Cheers. An hour max to Milton Keynes, that should be
    manageable. Anyone know how often trains run from MK to London?
  6. Timo Geusch
    Timo Geusch said...
    I'll pass, I daren't in case it gets damaged
    Lozzo, Dec 14, 2003
  7. In uk.rec.motorcycles, Timo Geusch said:
    www.thetrainline.com
    Whinging Courier, Dec 14, 2003
  8. Timo Geusch
    SteveH Guest
    AFAIK it's every hour for an Inter-City. With 'local' trains in between.
    http://www.thetrainline.co.uk
  9. Timo Geusch
    SteveH Guest
    Forgot to add.... you've probably got a max. of 4-5 weeks before you'll
    have to recover it, as we'll be moving - and I assume picking it up from
    South Wales may be a bit of a PITA.....
  10. Timo Geusch
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Timo Geusch
    How temporary? If it's up to about a month then there's room for one
    here (IIRC you have my address). I could give you a lift to Hitchin
    station if that would help.
    Nigel Eaton, Dec 14, 2003
  11. Timo Geusch
    Nigel Eaton was seen penning the following ode to ... whatever:
    Until mid-January. SWMBO pushbike will wander back up to her room when
    she's back in Germany and she's here until 7/1.
  12. Timo Geusch
    As just mentioned in the post to Mr Eaton, I'll need to store it
    somewhere else until mid January. SWMBO is flying back to Germany on
    the 7th.
  13. Timo Geusch
    SteveH Guest
    No problem, then. We're still here until the last week of January by the
    looks of things.
    SteveH, Dec 15, 2003
  14. Timo Geusch
    Ben Blaney Guest
    No problem. I've got bags of room.
    Ben Blaney, Dec 15, 2003
  15. Timo Geusch
    Nigel Eaton Guest
    You seem to have plenty of choice. If you want to leave it here, you
    have my phone #, give me a call (I'm away tonight).
    Nigel Eaton, Dec 15, 2003
  16. Pssst! Lozzo - this is one of Timo's bikes. Mot even he gets to use it.
    Well, not for more than a few miles, anyway.
    The Older Gentleman, Dec 15, 2003
  17. On one of *your* bikes?
    <fx: sucks teeth and shakes head dubiously>
  18. Timo Geusch
    Catman Guest
    Harlow.
    Welcome if none of the others pan out. No real need to remove for a
    while either as long as you give me a hand to shift stuff as needed in
    order to squeeze it in
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    Ducati Monster 600 Metallic
    www.cuore-sportivo.co.uk
    Catman, Dec 15, 2003
  19. Timo Geusch
    JP Guest
    I can put it up in my garage - (alarmed etc) - plenty of room, free
    and keep it there as long as you like
    JP, Dec 15, 2003
  20. Timo Geusch
    Now we finally begin to see how JP actually sources his "free"
    bikes...
    Ace, Dec 15, 2003
