WTB: 600cc 4cyl engine
Discussion in 'Australian Motorcycles' started by fulliautomatix, May 19, 2005.
  1. Engine wanted for university project; 600cc 4cyl in good condition, 92 -
    current preferred CBR, FZR etc
    Don't need carbs, exhaust, radiator or external electrics
    anyone got one for sale?
    Also wanted, K100 or other bike injectors
    38-40mm throttle body, TPS, MAP sensor
  2. fulliautomatix
    sharkey Guest
    Someone's going Formula SAE!
    -----sharks
    sharkey, May 19, 2005
  3. fulliautomatix
    IK Guest
    I've got a Kawasaki ZX-6R-G ('98-'99) engine of indeterminate condition
    on a bench in the garage. It's missing the starter motor, the generator
    (both the rotor/flywheel), and the timing sensor wheel.
    Only prob, from your perspective, it's in Canberra.
    IK, May 19, 2005
  4. fulliautomatix
    Marty H Guest
    put back in the bike...he can ride it home
    glad to help
    mh
    Marty H, May 19, 2005
  5. kewl...emmechisit?
    is it likely to require major repair?
    leading to new thread 'anyone got a starter and alternator for
    ZX-6R-G ('98-'99)'
    fulliautomatix, May 20, 2005
  6. fulliautomatix
    IK Guest
    (thinks)
    (cue unintelligible mealy-mouthed sound)
    To tell you the truth, I really have no idea... last motor I saw bought
    from a wrecker was a Bandit 1200 unit and that went for, ummm, $2500, I
    think. On the same day, a carbed ZX-636 motor went for, again, I think,
    four grand and a bit, which I thought was a bit rude.
    Big got an exchange donk for the Spada for, ermmm, $850, wunnit?
    I sold the one out of my R1, complete with fist-sized hole in the bottom
    crankcase, for $750...
    ....going on that, plus the fact that the only complete four-cylinder
    bike engines on Ebay atm are an ex-Japan Busa unit for $2500 and a
    seemingly literal boat anchor of a Z1000 one which is up to $232 at last
    update...
    I dunno. How's something similar to the $750 I got for the R1 engine sound?
    Well, it came with a tub of bits; waterpump, oil cooler, camchain
    tensioner, generator, timing, clutch and possibly sprocket covers, some
    clean-looking valves, both inlet and exhaust, a similar number of valve
    springs of indeterminate condition, plus what's pretty much a full set
    of very clearly used big end shells and a couple of pistons with
    carbon-blackened crowns. This could mean that they've either got most of
    the way through a rebuild, or that they barely started, before going
    "Meh, **** it".
    I've had a look under the cam cover, and there's nothing missing there.
    Ultimately, if you're going racing with a secondhand engine, you'll want
    to pull it down right off the bat as a matter of course, and ZX6's don't
    have much of a rep for being hand grenades, anyway.
    Big-end shells, pistons and rings aren't that pricy, and the G-model
    engine still had steel-sleeved cylinders, so even in the unlikely event
    of there being a scored bore, there'd be no NiCaSil replating to pay out
    of your arse for.
    If you're still interested, you might've just given me an excuse to tear
    it down, check the cylinders, the valve faces, big and little-end
    play, the state of the hardening on the gear clusters and dogs. I could
    always ship it up to you in bits.
    Don't quote me on this precisely, but, having both a 6R and a 9R in the
    garage[1], I'd be almost certain they use a common "recent-model Kwaka"
    starter motor, so that opens your choice a bit.
    [1]And, boy, doesn't that feel good to type. :)
    IK, May 20, 2005
  7. If only someone on this newsgroup was a self-proclaimed expert on '90s
    Japanese 600s.....
    Perhaps even someone who piked on the Unaugural...
    Postman Pat
    Pat Heslewood, May 20, 2005
  8. (cue unintelligible mealy-mouthed sound)
    OOG?
    yer...bit thin on the ground all over
    a generator too?
    so in the best of worlds....
    wow!!...u'd do all that? good O
    That would entertain Melinda no end!
    http://www.usq.edu.au/motorsport/members.htm
    YeeeeHaaar!!
  9. Someone's going Formula SAE!
    Are indeed!
    I see you know about fuel injecting bikes?
  10. fulliautomatix
    IK Guest
    No, unfortunately... good point. Completely forgot about the missing gen
    and starter... subtract about $150 from that asking price.
    IK, May 20, 2005
  11. fulliautomatix
    sharkey Guest
    Not, it is fair to say, in a professional or
    ever-actually-getting-it-working capacity.
    -----sharks
    sharkey, May 21, 2005
  12. fulliautomatix
    Jules Guest
    Noticed this in the trader:
    HONDA CBR600 2001, F4i race motor, ECond, high comp pistons, HRC cams,
    complete motor & gearbox, $1800, (0412)531821, (03) 97353958 lilydale More
    Jules, May 21, 2005
  13. Not, it is fair to say, in a professional or
    O...were you making your own computer?
    I am using the Adaptronic;
    http://www.adaptronic.com.au/
    fulliautomatix, May 21, 2005
  14. fulliautomatix
    sharkey Guest
    A MegaSquirt variant, most likely. I'm still mucking around
    with the throttle body setup.
    I'll have a look when I sober up.
    -----sharks
