write-off follow-up question
Discussion in 'Australian Motorcycles' started by Manning, Aug 20, 2003.
  1. Manning
    Manning Guest
    If a vehicle gets written off by an insurance company (ie. a 'statutory
    write-off'), can it be repaired and re-registered, or is it only ever usable
    for parts?
    Manning
  2. Manning
    glitch1 Guest
    Until about a year ago things were a bit more grey-coloured, also adding
    shades of grey depending on which state you're in.
    Since then things have changed and there's a national act in force now.
    A stat. write-off has had it's Vin withdrawn and been put on the national
    register.
    It can NOT be re-registered. Parts only or track-use...
    IF you can find a replacement frame (the most common reason for a stat
    write-off is heavy frame damage), that frame MUST have an AUS VIN number
    stamped and plated to it and must have been REGISTERED PREVIOUSLY in AUS,
    you might be able to do a frame swap and register the bike again (under the
    Vin number of the replacement frame).
    In order to do that, you'll have to present the stat. written-off bike AS IS
    and with all paperwork as to it's registration history/ receipts/ current
    reg. details/ as well as the replacement frame with IT's set of paperwork to
    one of the Registration-Authority-approved vehicle engineers (call your
    Authority for addresses), who will have a look at the whole thing, then they
    can fill out a request form (to change frames) to be sent to the Reg.
    Authorities.
    If approved, you may go ahead with the swap.
    After the job is done, the bike has to be presented to the engineering guy
    again, signed off OK, (pay engineering mob between $200-400) then you have
    to present the bike with ALL receipts for parts used in the repair to
    another Regist. Authority approved mob for a (here in Vic) VIV-report (cost
    around $300).
    That report basically states that NO stolen parts were used in the repair.
    Then it's off for a RWC and finally for registration (which can ONLY be done
    with ALL those papers in hand).
    cheers
    pete
    glitch1, Aug 21, 2003
  3. Manning
    sharkey Guest
    Yeah, I did that with the CX.
    Maybe it's changed, but all I had to do was install all the shiny
    bits in the new frame, and go register it with the new frame's VIN.
    Maybe they've changed it a bit to prevent 'rebirthing'. Maybe they
    just don't care about CX650s!
    -----sharks
    sharkey, Aug 21, 2003
  4. Manning
    glitch1 Guest
    SNIP
    Yeah, they changed it for exactly that reason.
    pete
  5. Manning
    Nev.. Guest
    I don't think you can do that either. Victoria also has the two classes of
    write off also (statutory and repairable) and I think the register of
    statutory writeoffs is national. Vicroads sent me a copy of all the blurb
    after my bike was written off last year.
    Nev..
    '02 CBR1100XX #2
    Nev.., Aug 21, 2003
  6. Manning
    Theo Bekkers Guest
    "Rik Steenwinkel" wrote
    Well done!
    Theo
    Theo Bekkers, Aug 22, 2003
