Wrestling the beast.
Discussion in 'UK Motorcycles' started by deadmail, Oct 28, 2007.
  1. deadmail
    deadmail Guest
    So, as I've pointed out elsewhere I need to do about 1500 miles over a
    long weekend on the outfit (essentially a 206 mile day followed by a 400
    mile day, followed by a 200 mile day and then in reverse a few days
    later).
    So... yesterdays 300 miles were fine but towards the end my shoulders
    wee tired. On a flat, level road the outfit is pretty neutral. Add in
    some camber etc. and it starts to pull slightly, actually on reflection
    it could also be the impact of weight in the sidecar. This over an
    extended period is rather wearing.
    I can piss about with adjusting the sidecar when weighted but I wonder
    what else.
    I've got a front tyre to fit to the bike which has a flat profile, I
    guess this should help. I'm also wondering about a steering damper;
    would this make any difference? To be honest it's not flapping about so
    I'm not massively worried about the damper for er. damping reasons.
    Comments?
  2. deadmail
    I think I may have to service the MZ (snorky bike) before I go.
    Sidecar alignment is the key. Get it right and a lot of the problems
    will be less of a problem. IYSWIM.
    sweller, Oct 28, 2007
  3. deadmail
    Knowing SFA about outfits (but that doesn't usually stop anybody) I'd
    say that is your answer. A bit more toe-in on the chair would improve
    it, I'd think - perhaps a bit more uprightness wrt the bike may help
    too. As long as it doesn't pull to the right on a flat road, natch,
    nor scrub tyres.
    I'm assuming the bike has conventional steering rather than leading
    link forks, right?
    Try the tyre, suck it and see, dear. If it isn't flapping then a
    damper is only going to confuse the issue.
    Upper body workouts might help.
    Pip, Oct 28, 2007
  4. deadmail
    ts Guest
    If adjusted for camber, would it then behave differently when on
    continental European roads, i.e. right side of the road?
    ts, Oct 28, 2007
  5. Add or remove Camber Shims as necessary, of course.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Oct 28, 2007
  6. Petrol and matches - kill it before it kills you.
    GS850x2 XS650 SE6a
  7. deadmail
    Toe-in affects pull, and lean also affects it. The first thing to do would
    be to measure how much toe-in you currently have, just to be sure it's not
    ludicrously off, or even toeing out.
    The other thing you'll want to think about is adjusting it on the other
    side, for the wrong-way camber.
    Do you want me to have a fiddle with it?
    At some speed, it will probably flap a bit. So long as it's not your
    cruising speed, you should be okay.
    platypus, Oct 28, 2007
  8. deadmail
    deadmail Guest
    Oh, it's toe-ing in to the middle of the velorex instructions (about
    5/8" at a point 'about a foot in front of the front wheel') and it's
    leaning out also to their instructions (about 1/8 to 1/4").
    I'll see what the MOT says and once they're happy I'll start fucking
    about! The problem is that I didn't notice the fatigue until about 50
    miles into the journey. We'll see.
    Oh, the flapping's at low speeds.
  9. deadmail
    deadmail Guest
    It's been completely 're-hung'. I've remade three of the mounting
    points/mounting bars so now it's leaning out rather than in.
  10. deadmail
    Does it pull towards the gutter at normal cruising speed? Would you be
    relaxed about taking a hand off the bars?
    Is it severe, or just a bit of a wibble?
  11. deadmail
    deadmail Guest
    a hand or both hands? One hand no problem, both hands no. But it
    depends on the road condition; which I guess is the camber.
    Would you be comfortable with both hands off the bars on your outfit?
    To be honest it's not that noticeable since I've fecked about with it.
    deadmail, Oct 29, 2007
  12. deadmail
    It sounds like it's pretty well set up. If I was going to recommend
    anything, it would be a hair more toe-in, and possibly a hair less lean-out.
    (I'm assuming that it wants to go towards the gutter.)
    Yes, if I had a throttle lock of some sort.
    If it takes 50 miles to be an issue, there's nothing fundamentally wrong.
    I'm taking it that this is 50 miles on motorway-type roads.
    platypus, Oct 29, 2007
  13. deadmail
    deadmail Guest
    You know, it varies, again depending on road camber but for the most
    part when I noticed it, it was pulling towards the gutter.
    Yes. And, to be honest it was really only during the second 150 mile
    stint that my shoulder started to complain. This could have been due to
    the vetter fairing in the sidecar... or the added weight from the bag of
    cement.
  14. deadmail
    If this is a Watsonian/Squire the adjustments are made with telescopic arms
    and clamps?
    It should be easy to have markings and readjust for British/Continental
    driving?
    Hog, Oct 29, 2007
  15. deadmail
    To be fair though, that could mean either a) his outfit is really well
    set-up *OR* b) he's dumb enough to try anything, regardless.[/QUOTE]
    Or both.
  16. deadmail
    Is the bag of cement in the front or back of the chair?
    It's not very fast, mind, and you can't control direction by wobbling your
    arse about like a bike, but if it was going along on the flat, it would just
    keep on keeping on, and not suddenly depart into a runaway wobble or flat
    spin. For instance, remember Sweller's runaway chariot.
    Adding ballast to the chair will slightly emphasise the left/right power
    on/off thing for the sake of keeping it down on lefthanders. The chair on
    the Ural is pretty heavy and has a car battery in the boot. I don't have
    anything else as ballast.
  17. deadmail
    deadmail Guest
    Front; in front of the sidecar wheel.
    Anyway, at the moment it's a moot point 'cos the MOT didn't like the
    suspension. Any of it.
    I'd hoped that they would have turned a blind eye but they want some
    damping in the forks, a lack of oil coming out of the rear shocks and
    the sidecar shock to not fowl the mounting bracketry. I think they're
    just being fussy; I've got to ride the effing thing...
    *sigh* I suspect the sidecar shock is going to be tricky.
  18. deadmail
    I suspect it may drive a bit better once you've sorted that lot out.
  19. deadmail
    A trip to Flitwick MOT Inc?
    Hog, Oct 29, 2007
  20. deadmail
    deadmail Guest
    No, I suspect that I will either need to source another shock or extend
    the shock 'arm' somehow; "mr arm, meet mr angle grinder and mr arc
    welder...".
