*wow* and *arse*
Discussion in 'UK Motorcycles' started by Doesnotcompute, Jan 22, 2005.
  1. Doesnotcompute
    I've had coils just die and do nothing or make a limp attempt but I've
    also had the misfiring then clearing (but that was on a banger - another
    coil fixed it).
    The wizened old mechanic I discussed it with felt that in his experience
    it was likely to be HT related and suggested the coils breaking down.
    I'll check the winding resistances but that's unlikely to prove anything.
    Main plan will be to set the ignition and, as you suggested, to check the
    wiring which is a bit 'birds nesty', bodged and tired looking; get
    everything to as good a base state as possible. Won't do any harm for
    the future anyway.
    The other suspicion is over fuelling. Whilst on the by-pass with it at
    about 110 the misfire will creep up the rev range (bear in mind this
    isn't a total ignition failure; it feels like a cylinder momentarily
    dropping out then coming back in, at worse two cylinders) backing the
    throttle off a touch will see a temporary improvement.
    Before I wreak bloody havoc on the FI I'll go through the ignition
    circuit to prove that good. That's today and tomorrow set aside then...
    I'd still be interested in other people's opinions.
    sweller, Jan 23, 2005
  2. Doesnotcompute
    dwb Guest
    "their place"?
    dwb, Jan 23, 2005
  3. I was there January to June 1987.
    Simon Atkinson, Jan 23, 2005
  4. Doesnotcompute
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    <> typed
    (Snip)
    The BlingMobile does something similar occasionally. In that case it's
    due to crap in the tank blocking the fuel tap.
    I'd pop the line off and ensure it's flowing well, and check the fuel
    filter (assuming it has one) before you go too deeply into the fuel
    system.
    Nigel Eaton, Jan 23, 2005
  5. Doesnotcompute
    Dan L Guest
    I didn't know you had a car, did I miss something?
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Jan 23, 2005
  6. Doesnotcompute
    Given the height the fuel from the return line attained when I stupidly
    turned the ignition on with the tank off I'd say that shouldn't be a
    problem.
    I can also see the fuel moving through the filter but I'll replace it as
    it looks elderly and I don't know its history.
  7. Doesnotcompute
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Me neither, but it does. Odd coves, engines.
  8. Doesnotcompute
    The local motor factors have a variety of shapes and sizes including
    something a similar size and with in/outlets like the ones on it. I
    can't see the fuel throughput (is there such a word?) being too much for
    one.
  9. Doesnotcompute
    sweller says...
    Is this the same 750 Turbo that had a coil break down in France, when
    Chanmp owned it?
    Lozzo, Jan 23, 2005
  10. Doesnotcompute
    Champ says...
    <Does happy dance>
    "My memory works, my memory works"
    Lozzo, Jan 23, 2005
  11. Doesnotcompute
    Does it? What did you remember?
    platypus, Jan 23, 2005
  12. Doesnotcompute
    platypus says...
    Eh?
    What you on about?
    Lozzo, Jan 23, 2005
  13. It was somewhere around Barstow, on the edge of the desert, when the
    Check and clean all low tension connectors to ignitor/coils/triggers.
    See how bloo yer spark is... over a 5 - 6mm gap, it should be a healthy
    bloo with maybe just a tinge of orange. If it's orangey looking, yer HT
    isn't very good. Possible coil fault.
    That Gordon Brown's a ****.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 23, 2005
  14. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "platypus"
    I'll bet he doesn't remember the penguin suit and the traffic warden.
    GS 850 x2 / SE 6a
  15. Doesnotcompute
    That was a penguin suit? I thought... Oh. Right.
  16. Doesnotcompute
    I appear to have sorted it. Well, I think I have...
    I was checking the timing and couldn't get the strobe to pick up properly
    on number 4 - intermittent, not a 'clean' series of flashes.
    Originally I thought it was the induction clamp playing up but it worked
    fine on the other 3 HT leads and when I revved it the slight missing
    coincided with the lack of strobe.
    Aha! Out with the stock of new silicone HT lead; unfortunately the O/D
    is too large for the coil but a manky bit of blue copper cored HT lead I
    had lying around fitted after I'd shorn it of the car ends.
    Took the turbo for a run - different bike - absolutely stomping. Still a
    bit fluffy and hesitant off a shut throttle at low speeds (sub 60mph).
    There was one episode of sputtery midrange misfire but it quickly cleared
    and I couldn't replicate it over the next 10 miles.
    Tomorrow I'll get some new HT lead and caps to replace the existing ones.
    Hopefully that'll be the matter sorted but something tells me it's all
    too simple.
    Other things of note: The fuel filter element is a nice black colour so
    that needs a replacement and I found two screws nestling behind the
    engine block. Where the **** have they come from? I've not undone them.
    http://www.sweller.dynalias.org/images/turbo-wtf.jpg [89Kb]
  17. Doesnotcompute
    See that thing with DFI on it? With the little holes on either side? Just
    a thought...
  18. Doesnotcompute
    Verdigris Guest
    The coils on my Tiger are going, it seems. Not too bad yet but on my way
    down to France last year, when it was pissing down all the way I seemed to
    be getting mild electric shocks in my right hand, increasing in strength
    and frequency when I wound it on in fear of missing the ferry.
    Verdigris, Jan 23, 2005
  19. Doesnotcompute
    They're 3mm screws, there are four of them - very nearly only three
    earlier today.
