Working up a head of steam
Discussion in 'UK Motorcycles' started by Mo, Feb 15, 2007.
  1. Mo
    BGN Guest
    Will see you next month.
    BGN, Feb 16, 2007
  2. Mo
    Moon Badger Guest
    http://en.wikipedia.org/wiki/Disk_brake
    Quite why I have the idea that BMW bikes were involved I'm not sure.
    BTDT. Sometimes I miss the white knuckle sensation. No, I'm lying, I don't
    miss it at all.
    Moon Badger, Feb 16, 2007
  3. Mo
    mb Guest
    ...and less disc braking surface, innit.
    mb, Feb 16, 2007
  4. Mo
    mb Guest
    Ah yes, I remember slowly and majestically gliding to a halt on me ole XS.
    mb, Feb 16, 2007
  5. Mo
    mb says...
    A CB250RS in the dry was just as bad, my old one is still sporting the
    same organic brake pads it came with, at least 50,000 miles later, and
    they hadn't worn at all. The disc showed absolutely no sign of wear or
    rust either. Braking made almost no difference to decelleration, simply
    shutting the throttle off on its own was just as effective.
    Lozzo, Feb 16, 2007
  6. Mo
    This is bollocks. I remember tests at the ime - some drilled discs even
    made wet weather braking *worse* because the holes acted a sreservoirs
    for the water. Kawasaki drilled early discs, in an assymetric pattern,
    and said it stopped squeal.
    [/QUOTE]
    Early drilled discs were shit until manufacturers started to make
    ventilated discs (drilled for venting rather than cast) or slot the
    discs running away from the drilled holes to the periphery of the
    disc.
    The theory was that steam build up from the water boiling could push
    the pads away but the venting or slots would clear the steam. The idea
    actually worked but caliper development made the whole concept
    redundant.
    I worked for a small company who (at the time) were developing brake
    systems for a couple of 250 & 350 GP teams and I used to get to try
    them out. I rode around for an entire winter with an 'in-house' front
    brake set up on my almost new gpz550 and our stuff was a lot better
    than the original Kawasaki kit.
    Andy Bonwick, Feb 17, 2007
  7. Mo
    I wouldn't bother offering if I were you. It seems as if Nick could
    have sorted out his mechanical failings by now if he wanted to so he
    probably prefers to chuck the bike at a shop. I don't blame him, I can
    do most jobs on bikes but a lot of the time I'd sooner just throw it
    at a dealer and let them take the strain.
