Working up a head of steam
Discussion in 'UK Motorcycles' started by Mo, Feb 15, 2007.
  1. Mo
    Mo Guest
    First time I've noticed this but on the way in to work yesterday in
    the heavy rain, when I used the front brakes hard I could hear a
    distinct hissing from them presumably as the rain water boiled off
    them.
    I assume this because clearly the pads are going to sweep the actual
    contact area clear of water and so the only way water will boil off is
    if the heat generated is sufficient to raise the surrounding area of
    the disk to boiling point. Which I presume only happens under heavy
    braking.
    Mo, Feb 15, 2007
  2. Mo
    Moon Badger Guest
    Normal for drilled discs.
    Nope, they make that lovely zizzy hiss normally.
    Your pads virtually ride on the disc all the time, this keeps the majority
    of water off.
    Try it for yourself next time it pisses down. Ride for a mile then pull in
    at the side of the road without using the front brake. Now see how wet the
    discs are.
    Modern sintered pads. Marvellous invention.
    Moon Badger, Feb 15, 2007
  3. Mo
    Mo Guest
    I've only noticed it in the rain and it was tipping it down yesterday
    morning all the way in, but I have to say my hearing's not quite as
    good as it was. I blame be a helicopter passenger too often. Nowadays
    I'd sue.
    Which would be pointless without the equally marvellous modern tyres
    Mo, Feb 15, 2007
  4. Mo
    Moon Badger Guest
    I dunno if this is all urban myth or not, and I am certain in my own mind I
    read about it from a usually reliable source ( ie, NOT MCN ). Please
    correct me if I am wrong here.
    Drilled discs came about thanks to BMW when a test rider complained that
    brakes were 'letting off' when used hard. The issue turned out to be
    generation of gas at the pad surface as its surface temperature rose. Gas
    not being noted for its braking ability. By drilling holes in the disc, the
    gas had somewhere to go. This also helped with wet weather braking.
    Early motorcycle disc brakes, even up to the early Eighties were not always
    brilliant in the wet. Problem one was the disc material used, problem two
    was the pad material. The problem was in part addressed by using discs that
    actually wore out instead of stainless steel[1]so the surface was regularly
    sloughed off, the second was the adoption of better pad material that
    incorporated fine metal particles and strands, ie, sintered pads. These two
    developments gave us the brakes we know and love today. The rest is just
    refinition.
    Sadly, it took a few years for tyres to catch up. Catch up they did though.
    I'm sure my wet braking distance on the Bandit is shorter than the dry
    distance on the X7 on organic pads. On Goldfren sintered pads the Bandit
    still outbrakes it, but the difference is nowhere near as marked.
    I await the flaming.
    [1] I'm sure they are still basically stainless steel, just less stainless.
    My XJ discs never rusted even though it spent the last four years of its
    life stood out in the open, never moving, those discs never rusted at all.
    The Bandit gets a fine surface coat within a few days. The EBC Iron discs
    on my 600f rusted solid within two days.
  5. Mo
    BGN Guest
    My front brakes suddenly started doing that. Turns out that the LHS
    caliper was binding like a **** and had gone through the friction
    material and was grinding the metal pad sleve against the brake disc.
    However, I'm sure yours is fine...
    BGN, Feb 15, 2007
  6. Mo
    It may be urban myth, but I've heard it too, now that you mention it.
    Understatement alert! Ever ridden an XS750 in the wet? No need for ABS
    on those bikes.
    EBC Pro-lites are Almost-But-Not-Quite-Stainless. With EBC sintered
    pads they rust slightly all over, but mostly under the pads and the
    pad-shaped rust patch doesn't wear off. PITA they are when that
    happens.
    Pip Luscher, Feb 15, 2007
  7. Mo
    Beav Guest
    I see you're keeping on top of the bike maintenance thing Nick:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 15, 2007
  8. Mo
    BGN Guest
    Mr. Suzuki Mean Dealer sorted it out for me in return for pennies. My
    LHS front foot peg hanger should arrive tomorrow so that I can
    actually ride the effing thing again.
    BGN, Feb 15, 2007
  9. This is bollocks. I remember tests at the ime - some drilled discs even
    made wet weather braking *worse* because the holes acted a sreservoirs
    for the water. Kawasaki drilled early discs, in an assymetric pattern,
    and said it stopped squeal.
    Mostly true. Discs in the 1970s were horrendous in the wet - I had an
    SOHC Honda CB750 with discs at either end, and in cold wet weather you
    could count to two before the bloody things bit.
    Cast iron discs (as used on Italian bikes) seemed to work better. But
    yes, sintered pads solved the problem. Sintered pads work quite happily
    on old 1970s stainless steel discs, which never seem to wear out at all
    (possibly because the calipers were on the feeble side).
    The Older Gentleman, Feb 15, 2007
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    If you don't get yourself to WUNderland for the free "Bike Maintenance
    101" course very soon, I am going to get very, very shouty at you.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Feb 15, 2007
  11. Mo
    Wicked Uncle Nigel says...
    The offer is open here too, if you're away taking care of business in
    the colonies.
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    I'm a modern man, I don't mind buying tampons, but apparently they're
    not a proper Valentine's present
    Lozzo, Feb 15, 2007
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    I fear we are wasting electrons, Brother Lozzo.
  13. Mo
    Oh well, at least when it all goes tits up there's a nicely recovered
    seat on it to sell.
    Lozzo
    Lozzo, Feb 15, 2007
  14. Mo
    Ooh, is that the time - I have to be up early tomorrow to doss some
    more.
    Lozzo
    Lozzo, Feb 15, 2007
  15. Mo
    ginge Guest
    As opposed to him showing up, jamming screwdrivers in allen bolts, using
    mole grips on nuts, and you getting only mildly shouty?
    ginge, Feb 15, 2007
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, ginge
    No, then I'd laugh.
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, ginge
    Ah, but he wouldn't get access to my nuts, y'see.
    Certainly not on the first lesson.
  18. Mo
    Eiron Guest
    Can anyone remember when BMW introduced drilled discs?
    ISTR that Italian bikes had them in the late seventies and,
    according to Wikipedia, cars had them in the sixties.
    Eiron, Feb 16, 2007
  19. Mo
    The first Beemer with discs was the R90S from '73, drilled from '75.
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Feb 16, 2007
  20. Mo
    Mo Guest
    Cue joke about a Nissan Main Dealer and a certain S.A. president
    getting car parts delivered to his house.
    Mo, Feb 16, 2007
