WinXP SP2 oddity?
Discussion in 'UK Motorcycles' started by Richard Sterry, Sep 1, 2004.
  1. Is it me?
    After upgrading to WinXP SP2, I find that quite a few links within ng
    postings don't work - just get the old "This page cannot be displayed" bit,
    and the Address field in the resulting OE6 window is blank. However, cutting
    and pasting the same link URL into the Address field works, as does clicking
    on the very self-same link in someone's reply posting. I'm not sure, but it
    usually seems to be the first occurrence of that link in a thread that
    fails, but sometimes it works if I try again later. It isn't as simple as
    whether or not there are leading ">" on the same line.
    Under the "Please try the following" heading, it says...
    "Open the s: home page, and then look for links..." (The "s:" is
    underlined.)
    Seems like the URL is getting truncated/replaced by just "s:". Just can't
    figure it out!
    Anyone else seem this?
  2. Richard Sterry
    Richard Sterry wrote in
    This is your problem:
    X-Newsreader: Microsoft Outlook Express 6.00.2900.2180
    Go to http://xnews.newsguy.com/ and use a proper client
    wessie, Sep 1, 2004
  3. You can guess what happened when I clicked on that link!
    Rick F650GS/R1150GS
    Richard Sterry, Sep 2, 2004
  4. Ditto with the browser.
    You could do a lot worse than paying a visit to www.mozilla.org
    Whinging Courier, Sep 2, 2004
  5. Aha, just had a thought - OE QuoteFix appears to be the guilty party.
    Rick
  6. Richard Sterry
    antonye Guest
    No. It royally fucked my internet connection, so I've
    since uninstalled it. Damn Windows Firewall kept turning
    itself back on, even though I'd set it to off as I already
    run ZoneAlarm. Plus it didn't like Norton either, and kept
    moaning that I'd turned off auto-download of updates.
    One reboot later and it just wouldn't connect to t'internet
    at all, even though the other machines (non SP2'ed) could
    get out fine.
    antonye, Sep 2, 2004
  7. Richard Sterry
    Catman Guest
    I've just seen it this morning, on my SP2 machine.
    Thing is I wasn't clicking a link, I typed an IP in the address bar
    directly.......
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (two off)
    www.cuore-sportivo.co.uk
    Catman, Sep 2, 2004
  8. Richard Sterry
    Veggie Dave Guest
    SP2 seems to have broken more things than it's fixed. It's just the same
    with a number of images based programs which it's completely fucked
    up...
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    Extreme Racing http://www.veggie-dave.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Sep 2, 2004
  9. Richard Sterry
    Ben Guest
    Wonder if it's got an "I've got a fucking hardware firewall, you twat"
    setting?
    My new laptop should rock up next week and out of habit I always patch
    them up to the eyeballs. Given it'll be a clean install I don't
    anticipate too many problems.
    Ben, Sep 2, 2004
  10. Richard Sterry
    Catman Guest
    OTW mine seems fine, with the 'firewall' locked to 'off'
    Catman, Sep 2, 2004
  11. Richard Sterry
    Catman Guest
    'off' works OK for me. It's not exaclty an intuitive firewall to
    configure. Pretty typically heavy handed approach IMHO.
    Catman, Sep 2, 2004
  12. Oh dear. I haven't found anything that does work so far, but the cause of my
    problem was definitely OE Quotefix. Uninstalling it fixed the problem,
    reinstalling made the problem return. Pity. An email to the author(s) is in
    order, I think.
    Rick
  13. Richard Sterry
    Catman Guest
    I bet the issue recurrs.
    Catman, Sep 2, 2004
  14. Richard Sterry
    antonye Guest
    Same here, but it was having none of it!
  15. I downloaded and installed SP2 the other day on my laptop. No problems
    at all. I disabled the firewall(ICS) in the services and set auto-
    updates to manual and everything's hunky dory.
  16. Richard Sterry
    Ben wrote in
    Yes. Turn off the firewall and tick the box to say just that(ish). If you
    just turn off the firewall then you get a nag flag in the toolbar every
    time you boot up.
    Only problem I've had so far is with P2P. The standard TCPIP.sys file only
    allows 10 concurrent connections. Shareazaa didn't like this. It's covered
    in the help forum available from the Sharezaa drop down menus.
    wessie, Sep 2, 2004
  17. I did of course mean "I haven't found anything that DOESN'T work so far,"...
    Duh
    Rick
  18. Richard Sterry
    Catman Guest
    I feel the first version is more likely ;)
    Catman, Sep 2, 2004
  19. Richard Sterry
    antonye Guest
    Now try running the Network Setup Wizard and see
    what happens...
  20. Richard Sterry
    antonye wrote in
    Why? Everything is working fine. Call me old fashioned but I try to do
    things manually rather than run a wizard that takes eons.
    wessie, Sep 2, 2004
