Wintering the Bike
Discussion in 'UK Motorcycles' started by Carolyn, Nov 10, 2003.
  1. Carolyn
    Carolyn Guest
    Anybody got tips for laying up the bike for the winter? I have a 2 month-old
    (well its `95 reg,but I only got it in August, after a 15-yr gap from riding
    2 wheels :) ) BabyBlade. Various people have said to drain the petrol/oil,
    smother it with vaseline, hook it up to a trickle charger, put it onto a
    middle stand (its on a side stand) to avoid the tyres `flatting`, yet others
    have said no need to do all this and there will be the odd nice day when I
    can take it out for a blast, that I only need to disconnect the battery if
    its garaged, and all I need to do is move the bike every now and then onto a
    different spot on the tyres.
    Its going into a friends garage once I make some room for it, rather than
    outside in my yard, under a breathable bike cover at the moment.
    Suggestions anyone?
    cheers
    Caz
    CBR400RR Red/white/purple
  2. Carolyn
    Wes Wells Guest
    Highly recommend a trickle charger. Also run the engine once every 10 days
    or so - if you roll it out the garage to do so then you should avoid any
    flat spots on the tyres. Key tip is don't let the battery go flat or the
    carbs dry out. Not sure that the rest of the precautions (vaseline etc) are
    really worthwhile if it's in a garage.
    Wes
    R1150RT
    CBR900RR
    Wes Wells, Nov 10, 2003
  3. Carolyn
    dwb Guest
    Except, as I discoverd the other day, you really need to *ride* the bike,
    not just leave it idling outside.[1]
    Then again, I do have an alarm.
    [1] it wouldn't start after being left alone for three weeks.
    dwb, Nov 10, 2003
  4. Carolyn
    Carolyn Guest
    Cheers, thanks for that. Seems a lot easier to do it that way.
    Roll on Spring when I can really learn about riding it...
    Anybody been on a BikeSafe course (think they are usually run by local
    police)
    and able to recommend it?
  5. Carolyn wrote
    Don't.
    steve auvache, Nov 10, 2003
  6. Eh? That's hardly likely for a winter lay-up
    Actually, better to dry them completely. I drain the carbs on the 400F,
    either by running it with the fuel off until it conks out completely, or
    my undoing the drain screws, which is a bit messier.
    Every so often I run it up, and then drain them again.
    The Older Gentleman, Nov 10, 2003
  7. Carolyn
    jsp Guest
    May I ask why?
    I know that you can end up with a residue, but wouldn't running the bike
    occasionally do away with this?
    John
    SV650
    Black it is
    and naked
    jsp, Nov 10, 2003
  8. Yes, it would. But with the British climate you never know whether
    you'll be able to take the bike out or not. Or you may be unable to run
    the thing because of other commitments, work and whatever.
  9. Carolyn
    Carolyn Guest
    sez u the hardened biker! Only having had it 2 months & still getting used
    to it & being on the road on 2 wheels etc (which is lots of fun-I had
    forgotten), I dont want to lose my confidence by going out in the wet or
    ice, so thought the best thing would be to look after it as much as I could
    over the winter months.. of course, if weather permits, I will be taking it
    out now & then. Some of you will probably say I should get the benefit of
    experiencing all kinds of riding scenarios, but I dont feel ready just yet.
    Thanks for all the advice guys, much appreciated!
    Caz
  10. While I can understand your reluctance there is always a first time for
    everything. Even if you build more miles next year you may still feel
    the same come next winter. I won't say it is a delight riding in the
    cold and wet - it isn't but neither is it so bad that it is impossible
    to do. Learning to read the road for winter weather conditions and
    finely balancing your controls do actually help to make you a better
    rider overall. Plus there are some nice winter days when a ride out in
    the crisp sunshine is well worth it. Finally you won't need to retrain
    yourself on how to ride come next March when all the Summer Bikers
    emerge from hibernation and then promptly wobble round corners at 10 mph
    or fall off :)
    Just my 2p worth.
    Paul Corfield, Nov 10, 2003
  11. Carolyn
    Colin Irvine Guest
    If you do that then you won't need to lay it up. Leave it connected to
    an Optimate or similar, and every couple of months take it out for a
    spin. Use both brakes hard a few times to free them. Keep the petrol
    tank nearly empty, and put a few litres of fresh petrol in at the
    start of each ride. Make sure the chain is well oiled.
    I've done this for a few winters, without probs.
    Colin Irvine, Nov 10, 2003
  12. Carolyn wrote
    Everybody is allowed to draw the line at ice and snow. The rest of the
    weather conditions should be looked upon as an opportunity to sharpen
    your biking skills.
    Half the speed, twice the fun.
  13. Carolyn
    Eddie Guest
    You'd be better off keeping it nearly full - less problems with
    condensation in the tank, corrosion, etc. (Unless you have a plastic
    tank, like wot I have, in which case it doesn't really matter.)
    Did you do the same with the GSXF?
    That might explain why it started leaking... ;^)
    Eddie, Nov 11, 2003
  14. Carolyn
    christofire Guest
    PFF. There's nothing like going for a blast with snow at the side of
    the road. The added "is there/isn't there black ice on this corner?"
    excitement is inimitable.
    christofire, Nov 11, 2003
  15. Carolyn
    There is something perversely enjoyable about silently sliding down the
    road at the same speed as your bike and both landing in a snow drift with
    a sort of "flump" noise.
    DAMHIK...yadda yadda
    sweller, Nov 11, 2003
  16. Carolyn
    Colin Irvine Guest
    Does enough air displace the petrol fumes for that to be a problem? I
    do what I do so that the petrol is pretty much replaced without having
    to ride a fair distance.
    I can't remember!
    Might it?
    Colin Irvine, Nov 11, 2003
  17. Carolyn
    Eddie Guest
    I believe it does, yes. What gets sucked into the tank as the petrol
    gets consumed?
    (When I used to drive tractors, I remember it being specified in one of
    the manuals that the tank should be filled every night, for exactly this
    reason.)
    I understand that - but if you're using it every now and then anyway, I
    don't think you'd have much problem with the fuel going off.
    It might. It developed a leak around the seam near the back of the tank,
    where the shape of the tank allows condensation to settle if the fuel
    level is too low.
    Eddie, Nov 11, 2003
  18. Carolyn
    Colin Irvine Guest
    Fair enough. I just sort of imagined petrol fumes gradually displacing
    the air.
    I may have to rethink, then. Having said that, I can't imagine many
    parts of a teapot not rusting.
  19. Carolyn
    Eddie Guest
    The (admittedly, after-market) exhaust hasn't.
    However, it did crack at one of the joins, and required welding. Just
    before MOT time, as well. Typical.
    Eddie, Nov 11, 2003
  20. Mild steel teapots are rare creatures indeed.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 11, 2003
