Winter washing
Discussion in 'UK Motorcycles' started by Ferger, Nov 22, 2004.
  1. Ferger
    Ferger Guest
    Though general lethargy and slack-arsedness I seem to have failed to even
    hose the Sprint down since sometime mid-summer. So its fetching buttercup
    yellowness is now grimy in an 'it might as well be black' sort of way.
    I lubed the chain a couple of weeks back. I can be arsed to do that every
    now and then, but prolly not as often as I should. But a bit.
    But it's getting cold now, and I really have lost all motivation to do
    anything about it's crappy appearance, nor attempt to cosset it through the
    winter. That 'I need to ride a shiny bike with carefully WD-40'd metal bits
    proudly through the winter'feeling has long gone.
    So...how much does this really matter, in the general scheme of things?
    What else, in the opinion of the panel, should I keep an eye on? I mean,
    grime is protection in its own right isn't it?
  2. Ferger
    Ferger Guest
    Bear secured a place in history by writing:
    Aren't you bored with this yet?
  3. Ferger
    Ferger Guest
    It isn't. I've just been seeing Neil Young as 'Today's Music' for about 4
    weeks now, and I think you need to move on. There are other beat-combos out
    there.
  4. Ferger
    Keep an eye on all the important spinny whizzy bits, keep your light
    lenses clean. Lube your chain a lot more too.
    Muck, Nov 22, 2004
  5. Ferger
    Preston Kemp Guest
    The one thing I would do is pull out the brake pad retaining pins &
    copper grease them.
    Preston Kemp, Nov 22, 2004
  6. Ferger
    Ferger Guest
    I'd sincerely hope not. No, hang on, yes...this is UKRM, if I think your
    musical tastes are verging on stale, I'll say so, with gusto. Swot it's
    here for, expression of unasked for opinions etc
  7. Ferger
    Ferger Guest
    Preston Kemp secured a place in history by writing:
    I *knew* someone would say that, godammit. Far too much effort....
  8. Ferger
    Preston Kemp Guest
    Effort? You want *effort*? Try drilling out the eazi-out you snap off
    in the pin next time you have to change the pads - *that's* effort!
  9. Ferger
    Do what I did. Sell it and buy something tidy for the same money! ;)
    ogden, Nov 22, 2004
  10. Ferger
    Ferger Guest
    Nope, sorry. Got no idea what you're talking about....
  11. Ferger
    Preston Kemp Guest
    Wait until the spring. I guarantee someone will be asking how to remove
    their pad pins after they rounded the heads out. At around the same
    time, someone on one of the trailriding/enduro lists will be asking how
    to remove a seized swingarm bolt. And when they do, I'll be sat here
    with a smug look on my face, safe in the knowledge that my hour spent
    playing with a tub of copper grease in the autumn was an hour well
    spent :)
    Preston Kemp, Nov 23, 2004
  12. "Preston Kemp" <> came forth with the following
    in uk.rec.motorcycles
    This a standard thing to do on Kwaks[1] - in the summer
    [1] They don't seem to know what grease is or if it even exists
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    Mark Derbyshire, Nov 23, 2004
  13. Ferger
    Ferger Guest
    I hear the advice, I really do. I'd love to know exactly what I should be
    doing - but I will join the ranks of all those who cart their bikes to the
    nearest dealer and let them deal with it. Not because I don't want to do
    it myself, but because I have no clue where to start and no time to learn.
    I really don't like this state of affairs, it's not like I'm incompetent
    with this kind of thing, but that's how it is...
    Ferger, Nov 23, 2004
  14. Ferger
    Ferger Guest
    I reserve my right to be unamusing and/or unentertaining. Usenet
    prerogative. There'd be no-one here otherwise.
  15. Every Kwak I've owned the first thing I do is
    1) fit the baglux
    2) fit the optimizer leads
    3) fit the Ohlins
    4) strip and CG the wheel shafts and brake bits
    5) make a warrenty claim for the crap paint work :0)
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
  16. Ferger
    Preston Kemp Guest
    Same story with head bearings. I suppose the manufacturers must save a
    small fortune by skimping on the grease, but it can be a right PITA.
  17. Ferger
    Bear says...
    Utter bollocks. It gives people like me a good opportunity to be better
    than most of the so called clever people.
    Lozzo, Nov 23, 2004
  18. Ferger
    Verdigris Guest
    On Mon, 22 Nov 2004 16:35:31 +0000, Ferger wrote:
    Brakes. Anything that moves. Anything alloy. Headlight lenses.
    I recently had to replace my front brake calipers. One of them was very
    badly fucked and the only thing I can reasonably attribute it to is five
    winters' lack of washing.
    I'm not going to clean it really thoroughly, but I'm going to at least try
    to give it a good hose down every couple of weeks.
    Verdigris, Nov 23, 2004
  19. Up to a point, Lord Copper.
    Certainly not once they start chucking salt on the roads. Then you'll
    have un holy mess that will most certainly **** up just about every
    moving component that isn't inside the engine cases, as well as making
    anything chrome or alloy look very nasty.
    The Older Gentleman, Nov 23, 2004
  20. Fair comment - but earlier this summer I spent hours removing a seized
    swinging arm pivot and replacing the equally seized bushes - exactly the
    sort of thing Preston mentioned. Horrible job. Easy, but protracted and
    horrible.
    A dealer whould have charged something like 200 quid for the job. A bit
    of soapy water a few times in the bike's life[1], pulling out the s/arm
    bolt once every two or three years[2] for a re-grease, would have
    prevented it.
    [1] And not pointing a jet washer anywhere near things like swing arm
    pivots.
    [2] Takes two minutes, if done in situ. Find an old long bolt more or
    less the same diameter as the s/arm pivot - wheel spindles usually work
    - and use it to drift out the pivot. The wheel spindle occupies the
    place taken by the pivot and stops the whole back end from displacing,
    so you then just clean and grease the pivot, and push it back into
    place, displacing the spindle as you do.
