winter riding
Discussion in 'UK Motorcycles' started by Chris Griffiths, Sep 26, 2004.
  1. Chris Griffiths
    tallbloke Guest
    No but Guzzi still sell a similar engine with the cylinders tilted up at a
    sensible angle. :)
    Spada. YKIMS
    tallbloke, Sep 28, 2004
    #41
  2. Chris Griffiths
    Catman Guest
    Softer. *much* softer. Reduce tyre pressure as well to increase the
    contact patch.
    www.cuore-sportivo.co.uk
    Catman, Sep 28, 2004
    #42
  3. Change the suspension oil for lighter grade, and lube the
    countersprocket.
    The Older Gentleman, Sep 28, 2004
    #43
  4. No problem I shall look into it. Just clicked on your URL and the bikes you
    used to own. I once owned a CD175 first bike a brought I was 13 at the time
    some bloke had it parked in his back garden for years, when I asked him how
    much he wanted he told me £40, I replied "I dont have that much", he then
    told me "what I should of said was I only have £20" so i asked my mum for
    £20 and went back to him he then sold it to me the police hated me and have
    ever since.
    Chris Griffiths, Sep 28, 2004
    #44
  5. What tyer pressure would I be looking at for a realy wet day
    #45
  6. Chris Griffiths
    Really wet? What, really pissing down or just your normal cats and
    dogs? If it is really honking it down you want to be down to about
    6psi in the front and perhaps 4 in the rear on a light bike like
    yours. This will allow a certain amount of squish, see, and as the
    tyre moves around on the rim it will heat up much better even if you
    have to ride quite slowly.
    Once the tyre gets hot enough to steam gently when you are stopped
    then you can be sure that the water will evaporate off it as it goes
    round, so you are effectively putting dry rubber down as you go along.
    If you aim your mirrors down a little you should be able to see the
    dry line of tarmac where you have just been - or look over your
    shoulder. This is the proper way to do it - if everybody did it
    properly like this then we would dry all of the roads all the time and
    we could ride a lot faster even in the rain.
    In snow, put your inner tubes over the outside of your tyres for extra
    grip - inner tubes are much softer rubber, see - just like wearing
    socks over slippery boots on ice.
    Pip, Sep 28, 2004
    #46
  7. Chris Griffiths
    Catman Guest
    Depends really. If it *really* wet, you want to up the pressure a *bit* to
    gain extra bouyancy, but I'd prolly look for about 1 atmosphere, 14 psi
    Of course, you need to adjust it daily to match your barometer.
    #47
  8. What about taking the wheels off get one of them big black rubber rings that
    get towed behind a speed boat and fix some sort of propelor to a shaft drive
    #48
  9. Chris Griffiths
    Elly Guest
    Ah, that's all very well, but you must also remember to calibrate your
    barometer on a daily basis.
    Go here for more details ...
    http://co-ops.nos.noaa.gov/publications/baroguidelines.pdf
    Alternatively consult a piece of seaweed or a pine cone, taking great
    care to ensure that the aformentioned are correctly aligned with the
    Greenwich meridian.
    Elly - a tired Pixie
    ZX9R-E1 - 'The bike made me do it!'
    Spike - FZ400 - firing on 3 cylinders
    MRO#32 ibW#25 BoTAFOT#46 BoTAFOF #46 GP#1 UKRMRM#00 TWA#3
    http://www.garagepixies.co.uk
    "Angel in the kitchen ... "
    elly at garagepixies dot co dot uk
    Elly, Sep 28, 2004
    #49
  10. Chris Griffiths
    Catman Guest
    Elly wrote:
    Oh, not this rubbish *again*
    We did all this last year and you still know you're wrong........
    #50
  11. Chris Griffiths
    Catman Guest
    Well, if you're not going to listen to the answers, why post the question?
    #51
  12. Chris Griffiths
    Pip wrote:
    This of course is why winter bikes, like the CG125, have inner tubes.
    Muck, Sep 28, 2004
    #52
  13. Chris Griffiths
    Owen Guest
    On Tue, 28 Sep 2004 21:03:20 GMT, "Chris Griffiths"
    snip
    Perhaps they are just good judges of character...?
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Sep 29, 2004
    #53
