winter riding
Discussion in 'UK Motorcycles' started by Chris Griffiths, Sep 26, 2004.
  1. anyone got any tips for riding bike in winter not so much riding tips but
    things to wear and things to do to bike
  2. Chris Griffiths
    AndrewR Guest
    1. Wear lots of layers.
    2. Soak the bike in WD40
    3. Take an adult literacy course
    HTH,
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Sep 26, 2004
  3. Chris Griffiths
    YTC#1 Guest
    Wear clothes :)
    Wear waterproofs
    Wash bike weekly
    Keep a watering can in garage and wash brakes daily
    YTC#1, Sep 26, 2004
  4. Chris Griffiths
    Sorby Guest
    Wear lots of thin layers rather than a couple of thick ones.
    If you haven't got heated grips or bar-muffs then try riding with your
    hands/fingers slightly outstretched (rather than clamped tightly round the
    bars) as this promotes circulation.
    A face-mask is a must to reduce misting/fogging on the inside of the visor.
    Smear the inside of the visor with the smallest amount of washing-up liquid
    as this helps to reduce misting/fogging too.
    It's quite tempting to wear one of this helmet 'skirts' that prevent cold
    air whipping up under your lid but this also prevents your hot breath from
    escaping and can increase visor misting/fogging.
    Sorby, Sep 26, 2004
  5. Chris Griffiths
    SteveH Guest
    See that thing with 4 wheels and a metal box?
    Use that.
    SteveH, Sep 26, 2004
  6. Chris Griffiths
    Smear a bit of fairy liquid on the inside of your goggles. Find scarf.
    Then post "HOW FUCKING HARD AM I?"
    sweller, Sep 26, 2004
  7. Chris Griffiths
    Seems about right. Clothes are a good idea too, Simon.
    Pip, Sep 26, 2004
  8. Chris Griffiths
    Mash Guest
    Buy a car. I've done 3 winters, commuting every day. I won't be doing
    that again.
    Mash, Sep 26, 2004
  9. Chris Griffiths
    Andy Hewitt Guest
    Wimp. I've done 10 now, and haven't regretted it either.
    Andy Hewitt, Sep 26, 2004
  10. Chris Griffiths
    Preston Kemp Guest
    For you: heated waistcoat & grips or gloves, goretex
    jacket/jeans/boots, double glazed visor. Forget all that layering &
    thick jumpers - electricity *rocks*.
    For the bike: either plaster it with Waxoyl & wash it in the spring, or
    hose it down with cold water after every ride on gritted roads. Or
    better still, buy a winter hack.
    Preston Kemp, Sep 26, 2004
  11. Chris Griffiths
    With the outer layer being something properly waterproof - GoreTex or
    similar - and armoured to taste.
    Waxoyl works as well and is cheaper. Neither does it wash off and you
    can certainly see where you've put it.
    Nothing to add to this one.
    Pip, Sep 26, 2004
  12. Chris Griffiths
    Molly Guest
    Please don't think I'm a safety Nazi but you shouldn't wear:
    T-Shirt
    Shorts
    Flip flops.
    Molly, Sep 26, 2004
  13. Chris Griffiths
    prawn Guest
    You will get a million conflicting theories here. Find out the hard way.
    HTH.
    prawn, Sep 26, 2004
  14. Chris Griffiths
    Mo Guest
    I'm beginning to think that too, but my rail commute is bloody
    awful and commuting by car through a large part of London ain't
    much fun either, even if it's a lot warmer and dryer. It's snow
    and ice that are a real test I find.
    Mo, Sep 26, 2004
  15. Chris Griffiths
    Ferger Guest
    Mash secured a place in history by writing:
    Poof
    Ferger, Sep 26, 2004
  16. Chris Griffiths
    Fr Jack Guest
    Just excercising his options, as I do for parts of the winter.
    I also tend not to go on pleasure rides in the winter...
    <to self>
    POOF!!
    </ts>
    Cheers!
    Fr Jack
    96 Tiger.
    FRJACK AT GMAIL DOT COM
    Fr Jack, Sep 26, 2004
  17. Chris Griffiths
    Preston Kemp Guest
    Given what you ride, I think you should change that to 'total, complete
    & utter poof!!' ;-p
  18. Chris Griffiths
    Catman Guest
    Let's be honest. You're looking at maybe 10-20 days max where that's an
    issue.
    www.cuore-sportivo.co.uk
    Catman, Sep 26, 2004
  19. Chris Griffiths
    Martin Guest
    Don't drink brandy to warm yourself prior to a ride, you will crash.
    A pair of old joggy bottoms can be hacked into two snoods and a pair of
    shorts.
    Arco sell a fantastic dayglo yellow waterproof jacket which will keep
    all bad weather out and make you look like a navvy.
    Get a fog city visor insert.
    Get a scott oiler.
    Get HG Pathan gloves.
    Get heated grips.
    Use redex if the bike doesn't have carb heaters, this reduces the
    effects of carb icing.
    Consider other means of transport.
    Martin:
    VTR1000 Firestorm
    Martin, Sep 26, 2004
  20. Chris Griffiths
    Martin says...
    Choose Cocal Cola, a big TV, CD Players. I chose life.
    Lozzo, Sep 26, 2004
