Winter Kit
Discussion in 'UK Motorcycles' started by catman, Oct 21, 2006.
  1. catman
    catman Guest
    Wuss ;)
    Makes sense
    www.cuore-sportivo.co.uk
    catman, Oct 22, 2006
  2. catman
    deadmail Guest
    You really need them if you don't want to wear winter gloves and carry
    multiple pairs.
    Even on the BMW K series (which has a fantastic fairing whatever Lozzo
    says; ignore him anyway his mind's been rotted by sniffing silkolene 2T
    fumes) your gloves will get wet. Bar muffs, once you're used to them
    are a fantastic piece of kit, they keep your hands dry and out of the
    wind. Admittedly they aren't the most stylish of things but one of my
    sets (er... I have three...) says "Oxford Sports" so that's added 10mph
    to the bike. However if you're looking at stuff for commuting in shitty
    weather you'll need bar muffs, with a 50+ mile commute I'd also suggest
    heated grips- it's the setup I've been using for about four years and it
    really helps a lot.
    Privillege of leadership and all that. Someone commented that my
    default answer recently to any question has been "tell them to go ****
    themselves"... I think this proves that watching TV is bad for immature
    minds- I've been catching up on The Sopranos.
    deadmail, Oct 22, 2006
  3. catman
    deadmail Guest
    This I don't do. With the weather as unpredictable as it is at the
    moment I need to have the thermal liners in my trousers. This causes a
    problem 'cos whilst I'm (naturally) svelte enough to fit my suit
    underneath it'll get all crumpled and sweaty, not the way to treat
    decent piece of tailoring.
    I'd not recommend wearing anything apart from jeans under bike gear. I
    don't even do that tbh.
    Past commuting over the winter was horrible (CB250RS, GPZ600, ZXR750,
    GT750, naked K100) until I discovered bikes with good fairings (K100RT).
    The amount of difference it makes is really unbelievable.
  4. catman
    deadmail Guest
    You'll also be uncomfortable, sweat like a pig and stink.
  5. catman
    Chris Guest
    Seconded. Keep the core warm and your extremities look after themselves,
    more or less. Mind you, it's a complete bastard when you break the wires
    from the bike so it stops working in subzero conditions with 30 miles to
    go.... Trust me. :-7
    EXO2 heated waistcoat.
    Also think about what you wear under your gear. Usual outdoor rules
    apply - lots of thin, wicking layers are better than a few thick layers.
    Merino wool is top notch (eg 'Smartwool' products) and IME outperforms
    any articial fibre I've tried.
    Put it this way, wearing two Smartwool baselayers, an EXO2, an EDZ
    windproof layer to keep the draughts out and leathers over the top I was
    only frozen off a 50 mile commute when the air temperature dropped below
    -3 degC. Heated gloves/grips/bar muffs would have probably let me carry
    on in more extreme conditions but I couldn't be arsed for the sake of a
    few days.
    Chris, Oct 22, 2006
  6. catman
    deadmail Guest
    Heh. I would. And I'd be *most* surprised if I was the first.
  7. catman
    deadmail Guest
    Wuss. Decent fairing and a half decent jacket.
    When it's really cold I'll wear thermal socks and thermal 'long johns'
    under my riding gear.
    Electrically heated stuff (beyond grips) I've never bothered with.
    T-Shirt, Shirt. That's it. Long Johns and Thermal socks in Jan/Feb
    maybe.
    Hmm, balaclava and 'tube' over neck.
    "Couldn't be arsed"? You're advising exotic undergarments, multiple
    layers, heated gear blah-blah-blah and you can't be arsed spending about
    100 quid and a couple of hours fitting heated grips and bar muffs?
    There's nowt as odd as (other) folk.
  8. catman
    SteveH Guest
    Trouble is that putting all that lot on and taking it off again more
    often than not negates any advantage in taking the bike.
    SteveH, Oct 22, 2006
  9. catman
    DanTXD Guest
    Unless the winter kit was for wearing whilst waiting for the AA ;-)?
    DanTXD, Oct 22, 2006
  10. catman
    SteveH Guest
  11. catman
    deadmail Guest
    (SteveH) wrote in message
    For me, it's about making the journey reliable.
    If I drive on a good day it'll take me 50 minutes, on a bad 2 hours. If
    I ride you need to shut the motorway to vary my time by more than about
    15 minutes more than the 50 minute mark.
  12. catman
    Yeah Burnt is wrong about this. My leathers are pretty warm with the
    winter liner zipped in. With the HG pvc jacket over the top it's great,
    warmer than the Halvarsson was, and it will be more waterproof than any
    Gortex job. I actually find it less bulky. I have better crash
    protection. Leave the pvc over the leather when you take it off and it's
    no hassle putting it on. You put the leather inside the glove and pull
    the pvc over which stops any possible water ingress.
    Have Gerbing heated gloves and I'm thinking about replacing the jacket
    liner with a heated waistcoat. It wouldn't be necessary for your
    commute, I'm thinking 6 hour mid winter rides. I don't sweat inside
    them, but admittedly I'm not the sweaty type.
    Dainese Assuan gloves are THE warmest dryest 4 finger gloves you will
    find. Very comfortable too.
    www.londongatwickdainese.co.uk/motorcycle_fra.html
    I've been through more bike clothing than god to arrive at these deep
    and meaningful conclusions. Has anyone else bought and discarded a
    Halversson in the quest for perfection?
    Hog, Oct 22, 2006
  13. catman
    Tim Guest
    A trip to Snow & Rock for something warm underneath too.
    Tim, Oct 22, 2006
  14. catman
    Chris Guest
    Bugger. I've been rumbled :)
    'course, you had it easy.
    I used to commute wearing just a pair of shorts and T-shirt in -10
    degrees from John O'Groats to Lands End every day, leaving an hour
    before I went to bed having eaten a handful of hot gravel. And when I
    got to work each day I had to throw myself into a vat of boiling water
    just to warm up enough to be able to type.
    Just try telling that to the kids today.
    Chris, Oct 22, 2006
  15. catman
    "In either case, the death would be blamed on the enemy, and, due to the
    dead man's unpopularity, no one would contradict the cover story"
    http://en.wikipedia.org/wiki/Frag_(military)
    Haha. A Franco-German conspiracy?
    wessie, Oct 22, 2006
  16. catman
    Fair enough - I tend to wear jeans-like garments in this case so they
    don't tend to crumple that badly.
    Indeed. Commuting on the Pan was a lot better than on the GS and I
    believe the K100RT/K1100RT fairing is even better.
    Timo Geusch, Oct 22, 2006
  17. catman
    Donald Guest
    After 4 years sterling service I've decided to replace my Voyager jacket
    and was very dismayed to find it's been replaced.
    I phoned them up and the replacements for the Voyager are the rather gay
    sounding "Cruise" for GORE-TEX and "Journey" for Sheltex liner.
    http://www.hein-gericke.com/uk/product_info.php/cPath/1_15_7/products_id/2078
    http://www.hein-gericke.com/uk/product_info.php/cPath/1_15_7/products_id/2054
    I will be visiting the shop this afternoon to check them out.
    I just use the one set of textile jacket and pants. I've found them to
    be fine until recently when the outer gets waterlogged. The gore-tex
    inner still keeps me dry but it's just not as good as the water just
    slewing off.
    For boots I use a set with a Sheltex inner, again after four years I'm
    starting to get a leak at the toe of one of them. So a replacement
    goretex or Sheltex is due now that the wet weather is becoming more
    regular.
    Donald, Oct 22, 2006
  18. catman
    deadmail Guest
    Well, my experience is different from yours. I'm firmly of the opinion
    that Cordura/Goretex (or one of the copies) is far supperior to leathers
    with a waterproof layer.
    It's not just warmth and 'sweat containing', it's also the fact that
    having a nylon oversuit flapping around in the wind is fucking
    irritating plus it's a pita to get into.
    Still, YM obviously varies; note I've the good manners not to say you're
    "wrong" even though I clearly don't think you're right (in oh, so, many
    ways.)
  19. catman
    deadmail Guest
    That could quite easily be the case with me...
  20. catman
    catman Guest
    Nothing new, then ;)
