Windows/Office problem
Discussion in 'UK Motorcycles' started by The Older Gentleman, Dec 1, 2005.
  1. The Older Gentleman
    Daz Guest
    The moment you acknowledge someone as an expert they cease to be one.
    Daz, Dec 2, 2005
    #41
  2. The Older Gentleman
    Daz Guest
    On 2 Dec 2005 10:20:53 GMT, "Krusty" <>
    wrote:
    What makes you think display drivers would have an effect on a copy
    and paste operation?
    Daz, Dec 2, 2005
    #42
  3. The Older Gentleman
    simonk Guest
    I've got a DVD of OSX Tiger for Intel, if you like ...
    simonk, Dec 2, 2005
    #43
  4. The Older Gentleman
    Because it's not just a simple paste, it's Word trying to render it to
    display as a web page. As it works fine when pasting as plain text, it
    could be the rendering that's causing the problem.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '96 Tiger '79 Fantic 250
    Krusty, Dec 2, 2005
    #44
  5. OpenOffice - it's free, can read MS Office documents (and save as them
    too).
    Available for Windows, Linux, Solaris etc etc (not sure about Mac)
    http://www.openoffice.org/
    Alternatively tell her to visit the MS Office update website (use
    Windows Update, click on the Office Update link at the top of the page)
    to get the latest updates
    Phil.
    Phil Launchbury, Dec 2, 2005
    #45
  6. The Older Gentleman
    Daz Guest
    On 2 Dec 2005 10:40:01 GMT, "Krusty" <>
    wrote:
    Which to me would point heavily towards IE not a TP driver. Ferger's
    provided a link to the fix anyway although MS don't specifically name
    the culprit.
    Daz, Dec 2, 2005
    #46
  7. Actually it is. The codebase is identical. The setup is different but
    the underlying programs are identical.
    XP-Home also is missing some bits that XP-Pro does (domain
    authentication yada yada yada) but the code is still there - just
    disabled.
    Phil
    #47
  8. How do you think the system knows which bits in memory to cut and
    paste?
    The other thing worth checking is the printer driver - I have seen some
    bizarre problems in Word caused by the printer in use at the time -
    change the default printer and the problem goes away!
    Phil
    #48
  9. The Older Gentleman
    simonk Guest
    Hmm, don't think so - sounds like an OLE problem to me. Windows is having
    trouble creating an embedded object in Word containing the pasted-in content
    from the browser. The web page could contain all-sorts of shite (Flash,
    applets, invisible graphic elements, Javascripts, DHTML)
    All of this stuff just looks like bitmaps to the graphics card, irrespective
    of the application window it's contained in, so I'd be surprised if the
    problem lay there.
    simonk, Dec 2, 2005
    #49
  10. The Older Gentleman
    Ben Guest
    And if you ever want to not look like a prat to a client who uses MS
    Office use MS Office to create the document rather than Open Office.
    It's a good office suit, no doubt about that. But you _cannot_
    guarantee that your OO document will look the same in MSO.
    Ben, Dec 2, 2005
    #50
  11. The Older Gentleman
    <reads thread>
    Ah yes, so he did.
    <bookmarks link ready for next week's 2003 install>
    Krusty.
    Krusty, Dec 2, 2005
    #51
  12. Well if he'd said he had a _director_ on the verge of tears, I'd have
    answered differently. Particularly if said director was a bloke.
    Soylent Green, Dec 2, 2005
    #52
  13. Same holds for different versions of MS Office - I have a number of
    documents created in Office 2003 (and saved in O2k format) that look
    quite different when viewed in O2k..
    Moral of the story - use PDFs..
    Phil.
    #53
  14. The Older Gentleman
    Daz Guest
    On Fri, 2 Dec 2005 10:51:10 +0000, Phil Launchbury
    Given that Word uses the IE rendering engine and they'll both sit
    within one of two processes my point was it's unlikely to be a TP
    driver.
    <snip>
    Daz, Dec 2, 2005
    #54
  15. The Older Gentleman
    ginge Guest
    It's noting to do with the screen driver... it's to do with DDE.
    ginge, Dec 2, 2005
    #55
  16. The Older Gentleman
    mb Guest
    Is that anything like Office XP then? The "upgrade" and "full" versions
    were exactly the same, it was just the CD key that made the difference.
    mb, Dec 2, 2005
    #56
  17. The Older Gentleman
    Ben Guest
    PDF is great for when you want someone to see exactly what you see.
    It's not too crash hot if you're collaborating on a document though.
    Ben, Dec 2, 2005
    #57
  18. The Older Gentleman
    MattG Guest
    Don't forget fuckwitted users.
    I've had some huge problems with windows, the vast majority were caused
    by me. The remainder by dodgy bits of software or knackered hardware.
    On the machine that I *use*, rather than the one I **** about with,
    I've not had a single problem. Ever.
    MattG, Dec 2, 2005
    #58
  19. MattG wrote
    I haven't, well not with the latest stuff anyway.
    AOL
    steve auvache, Dec 2, 2005
    #59
  20. Steady on chap, doing anything vigorously at your time of life is
    risky.
    Work in progress
    Off to see the wizard.
    Sometimes it's good to be bad.
    Work in progress, Dec 2, 2005
    #60
