will a PCV breather filter cause gasoline to build up in the oil?
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Sep 21, 2006.
  1. Hi all - 1984 KZ700, 9500 miles. I recently installed K&N pod filters
    along with a small breather filter for blowby gases. If I understand
    correctly, with the stock airbox, the blowby gases are routed into the
    airbox and then burned - but with this breather filter, are they just
    trapped in the crankcase?
    I noticed my oil level had increased significantly over the past month
    and the oil also smells like fuel.
  2. Masospaghetti
    B-12 Guest
    No, the fumes should pass through the filter, but some of the fumes
    will be cool enough to condense in the cloth and mesh part of the
    filter, making it oily.
    If you let the breather filter get all oily, the vapors will find
    another way out of the crankcase. The valve cover gaskets may weep, or
    oil may ooze past the o-ring on the starter and fill up the starter
    cavity.
    The K&N filter you describe is best used on the valve cover of a car
    engine, where the fumes can rise and the drips can fall back into the
    valve cover area.
    The K&N filter is not really designed to be used on a horizontal rubber
    hose.
    Ducati and Norton riders used to run a large diameter (about 1 inch)
    clear plastic
    tube from the crankcase breather all the way back past the tail light.
    Too bad if a rider was following closely, he might get some oil drops
    on his Snoopy googles.
    Googles? What are those? Who wears Snoopy googles when they ride?
    And, what is a "pudding bowl" helmet?
    Leaky or stuck float valve.
    B-12, Sep 22, 2006
  3. I figured it could be a bad float valve but my carb has an overflow
    tube, wouldn't excess gasoline go out the tube instead of down the carb?
    Masospaghetti, Sep 22, 2006
  4. Masospaghetti
    B-12 Guest
    It sounds like you believe the "overflow tube" is connected to a
    standpipe in the float bowl, a brass tube that acts like the overflow
    in a toilet water tank.
    If you somehow pressurized that tube which you think is an overflow
    tube, like, suppose you blew through the tube, where would the air
    pressure go, or would the airflow stop because there is actually a
    float bowl drain screw blocking flow?
    One would certainly *hope* that an overflow standpipe worked properly,
    but if the fuel level in the float bowls is high enough that a
    standpipe drained *some* of the extra flow, it's also possible that
    some of the flow would come out of the needlejet and flow down the
    carburetor throat and past the intake valves and piston rings and get
    into the crankcase.
    The fact that your oil smells like gasoline seems to point to plenty of
    gasoline getting past the float valve.
    B-12, Sep 22, 2006
  5. Masospaghetti
    John Johnson Guest
    Is your carb overflow blocked?
    Later,
    John
    John Johnson, Sep 22, 2006
  6. I don't think so. if I leave my petcock on prime too long I begin to see
    gasoline come out of the tubes.
    Masospaghetti, Sep 23, 2006
  7. Thats definitely true. I guess my real question was, should I get rid of
    this K&N breather filter and just route the breather hose somewhere...is
    the K&N filter causing any harm, or does it do any good...the bike is
    finally running pretty good and is infinitely easier to service with the
    pod filters so I would much rather leave them on instead of reverting to
    the stock airbox.
    Thanks
  8. Masospaghetti
    B-12 Guest
    The K&N breather filter is really supposed to be mounted vertically,
    not sideways.
    If you cannot find a convenient place (1) to mount the K&N breather
    filter in the vertical position so condensed oil fumes can run back
    down into the valve cover or crankcase, just run a tube back to the low
    pressure area around the license plate.
    (1) By convenient, I mean a place where you can easily get to the
    filter for cleaning it, without removing the gas tank or anything
    that's a pain in the butt to get in and out.
    B-12, Sep 23, 2006
  9. Ok, thanks. The breather filter is pretty close to vertical right now
    (its slightly sideways because the hose isn't completely straight).
    Guess i'll look into the carbs.
    Masospaghetti, Sep 24, 2006
