Why the K1100 didn't pop a fuse
Discussion in 'UK Motorcycles' started by The Older Gentleman, May 5, 2011.
  1. The Older Gentleman
    rick Guest
    Don't they have that then? Alright, try going to Specsavers :p
    rick, May 6, 2011
  2. The Older Gentleman
    TOG@Toil Guest
    TOG@Toil, May 6, 2011
  3. The Older Gentleman
    Wiring for the indicators.
    CT, May 6, 2011
  4. The Older Gentleman
    Jim Guest
    Probably either bridleway or a restricted byway?
    Jim, May 6, 2011
  5. The Older Gentleman
    It's a wire with special smoke vents, as I believe you discovered.
    Krusty, May 6, 2011
  6. The Older Gentleman
    "Route under construction, will be applicable in future models".
    Pip, May 6, 2011
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, "TOG@Toil"
    Fusible link?
    Wicked Uncle Nigel, May 6, 2011
  8. The Older Gentleman
    TOG@Toil Guest
    Ho fucking ho.
    What's the latest on the scrawped GTR, by the way?
  9. The Older Gentleman
    Steve Guest
    Steve, May 6, 2011
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, "TOG@Toil"
    The what now?
  11. The Older Gentleman
    Colin Irvine Guest
    Colin Irvine, May 6, 2011
  12. The Older Gentleman
    Nod and smile. He thinks you're Colin.
    Pip, May 6, 2011
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    OIC. And the ZZR is a GTR.
    Poor old sod, it must be awful.
  14. The Older Gentleman
    TOG@Toil Guest
  15. The Older Gentleman
    Colin Irvine Guest
  16. The Older Gentleman
    The bike wouldn't run if the dotted line connections weren't made as they
    are all 12V feeds or ground connections.
    They appear to be "virtual connections" rather than those made by a wire on
    that actual route, just to give "clarity" on how items are powered. Look at
    the Br wires, connected to a ground point. These don't need to be
    physically connected to the *same* ground point, just anywhere on the frame
    or engine. The person who drew the diagram seems to like having dotted
    lines rather than more ground symbols. It's an odd style and not a
    convention that I've seen used a lot.
    wessie, May 7, 2011
  17. The Older Gentleman
    Mark Olson Guest
    As someone who is responsible for creating accurate schematics which describe
    the true physical interconnections of circuits, I would just like to say that
    this is the sort of thing that makes my blood boil. When you are trying to
    diagnose a subtle behavior/problem in a circuit, 'simplifying' the circuit by
    virtualizing earth (or any other signal/power node) connections is doing the
    user of the schematic no favors at all, especially when the return path part
    of the circuit is what you are trying to figure out.
    Jesus H Christ that makes me mad.
    Mark Olson, May 7, 2011
  18. Fuckin' A.
    I've come across that, too. Makes me want to strangle the dozy fucker
    who set it out.
    Grimly Curmudgeon, May 7, 2011
  19. I don't see what the fuss is all about. It's a part of the tool kit and
    the better technicians are those who demonstrate with consummate ease
    their betterness by making best use of what is always inadequate.
    Strangling, if a slowish death that can be played with is required, is
    best reserved for the **** who designed that particular piece of shit in
    the first place not the wannabe artist who can't sell his work on the open
    market and opts for a career as a technical designer and persists in his
    wrongly help opinions of his own genius by making abstract
    representational drawings of what they think it should have been.
    steve auvache, May 7, 2011
  20. The Older Gentleman
    Colin Irvine Guest
    Bike back, looks like new. Happy bunny.
    Colin Irvine, May 19, 2011
