Why is my front brake dragging?
Discussion in 'UK Motorcycles' started by Rowland McDonnell, Feb 19, 2006.
  1. Hello to those who know me (I spy Andy Hewitt at least),
    I've got a D reg Honda VFR750FG (the first model year). It's very nice
    - approaching 100,000 miles and still running well, Hagon monoshock,
    taper roller head bearings, stainless steel braided brake lines, etc.
    But I have a problem. I've replaced the original front discs with
    pattern discs - solid, rather than semi-floating as Honda intended.
    I've had the front brake working fine with the new discs, but now it's
    dragging. It started dragging quite badly, probably due to winger crud
    and me not spraying the pistons regularly (rubber lube - I've found that
    WD40 beloved of many for this job destroys my dust seals rather
    quickly). So:
    I've had both calipers apart, cleaned them very thoroughly along with
    the pistons, replaced the seals, and put the whole lot back together
    with new pads with grease (high temperature waterproof grease or copper
    slip, depending on where) in the right places and DOT 4 fluid from
    Halfords (DOT 4 is what the master cylinder filler cap says to use) in
    the hydraulics. The brake pins are fairly new and checked to be still
    straight, as are the pad pins. The various rubber boots are sound. The
    caliper mounting brackets got cleaned too - including cleaning out the
    holes the brake pins go into.
    I've not given the master cylinder any dismantling this time around - it
    got stripped, cleaned, and the piston and seals replaced not all that
    long ago, and what on Earth could have gone wrong with it? (I know, I
    know - *something*'s wrong). I've got two bits of stainless braided
    brake line running directly from the master cylinder banjo bolt - one to
    each of the front calipers with no splitter (a previous owner did that).
    I've fitted a bleed nipple equipped banjo bolt to the front brake master
    cylinder and I use it after bleeding the calipers to squirt out any last
    bit of air that's trapped at the top of the hose runs.
    But the front brake still drags a touch - both calipers contribute a
    little. I can't see anything obviously wrong. The caliper mounting
    brackets seem to be undamaged, unbent, and (this was tricky to check -
    feeler gauges and a bugger to get 'em in it was, I can tell you) and
    also in the right place relative to the discs in the left to right
    sense.
    When I let go of the brake lever, I have a definite feeling that the
    brake's not letting go all the way - which is quite right, 'cos it's
    not. Despite a great deal of bleeding and the fact that the front brake
    is working very effectively, I have a feeling that there's still a bit
    of air in the system.
    Anyone got any ideas? Can a bit of air left in your front brake
    hydraulics cause this sort of thing? If so, how the blankety-blank do I
    get it out 'cos bleeding the brake over the course of three days hasn't
    sorted it. If not - well, could someone run down the things that can
    cause a hydraulic disc brake to drag so I can check 'em all?
    Cheers
    Rowland.
  2. Righto. I didn't see how it could be - but, well, one looks for straws
    to clutch, y'know?
    I know the very bit I need to grab - and now I know what it's for :)
    Excellent! I've got something definite to look for tomorrow - ta.
    Check for a spurt, and even if it looks okay to me, I'll check the lever
    movement and if that looks okay - well, it's time for a master cylinder
    strip and clean, I reckon.
    Cheers,
    Rowland.
  3. (good - as I said elsewhere, I didn't see how it could be)
    Okay... My front brake is, alas, still dragging.
    Since I last posted, I've had the master cylinder off the bike, *very*
    thoroughly cleaned, and put back on the bike with a master cylinder
    rebuild kit to replace piston, spring, and all the seals.
    The relief port is clear - before I put the master cylinder back on the
    bike, I looked through it and saw a clear hole (tricky to get light up
    the master cylinder bore to check this), then I sprayed brake cleaner
    through the port and it shot through into the master cylinder bore
    apparently unimpeded - I didn't try a probe on the grounds that I'm
    working with an aluminium alloy casting and I don't want to damage the
    inside of any holes. I kept things clean after I'd cleaned them.
    I can't say I can see much of a spurt of fluid coming out of the hole
    you mention when I operate the lever, but there seems to be something
    and I certainly got lots of bubbles coming out of both the holes when
    the air was pumping out.
    The brake lever seems to be the shape Honda intended, and looking at the
    operation of the brake lever against the master cylinder piston, I'd say
    that's all exactly as it should be - the bits that need greasing have
    had it, and there's no sign of the lever applying force against the
    master cylinder piston when you let it go. The front brake lever action
    feels different from what it did before I replaced the master cylinder
    bits - different, and now it feels as if it's working correctly (I'd
    cleaned and lubed the lever side of things before doing the calipers, so
    the difference in feel has nothing to do with that).
    But the front brake is still dragging.
    I'm baffled by this one. I've cleaned the calipers and the master
    cylinder pretty damned thoroughly, replaced all the seals, replaced the
    master cylinder piston and spring, checked I've got a clear relief port
    and correctly fitted brake lever, and I've still got a dragging front
    brake.
    Does anyone have any ideas? (He whimpered, pathetically.) The brake
    lines are routed such that they're not responsible for forcing the
    calipers somewhere they don't want to be.
    Could it be something slightly wrong with the mounting of the calipers?
    Rowland.
    (really clueless on this one)
    Rowland McDonnell, Feb 26, 2006
  4. VFR750FG - 1986 model. A pair of Nissin two piston sliding calipers
    each attached to an alloy bracket that bolts onto a fork leg.
    The left hand caliper has a mounting bracket that pivots at the top so
    that under braking, the bottom mount of the bracket presses up against
    *that* nobble set into the fork leg - which is the anti-dive actuator
    valve. I doubt any of that is relevant, but you never know. There's a
    needle roller bearing in the top pivot point which has been rusted solid
    the whole time I've had in the bike. It wasn't until I paid some
    attention to Mr Haynes that I saw there was supposed to be a bearing in
    there, and it took quite a bit of cleaning to make the fact obvious.
    But that knackered bearing didn't make the the brakes bind then, and I
    doubt it's doing it now. Why haven't I replaced it? It'll be a hell of
    a job to remove the old bearing cage, and I'll have to take the fork leg
    to someone with a hydraulic press to replace the equally knackered bush
    the roller cage runs in.
    Righto. I'm Mr Silly, I am. I've been using Silkolene RG2 racing
    grease 'cos it's waterproof and v. high temp.
    But Mr Haynes (now I've read *all* the brake section) says to use poly
    butyl cuprysl grease or high temperature silicone grease designed for
    brake applications.
    So that's something to try.
    Er, no?
    In my case, the seals do appear to be symmetrical. Mr Haynes doesn't
    say anything about fitting them one way or the other and there's nothing
    mentioning anything at all on the seal packets aside from `Honda' (as in
    Honda parts, not pattern - I've had an unhappy time with pattern seals
    in the past) and a part code and all that. But it's a thought, isn't
    it?
    Hmm. Well. I suppose it's down to Halfords for some grease buying,then
    off with the calipers and have a fiddle.
    I wouldn't mind if I could find something that was obviously wrong, and
    then fix it. But - well, maybe it is the grease. On the other hand,
    I've had the calipers not sticking before and I've long used the same
    grease on 'em.
    Cheers,
    Rowland.
  5. partially seized / sticky calliper pistons springs to mind , might need a
    strip down and rebuild or just freeing up cleaning etc
    its amazing how much crud gets around the callipers , if the bikes not been
    used for a while look for oxidation on the callipers and pistons / slides
    etc
    usually white in colour
    Steve Robinson, Feb 26, 2006
  6. Rowland McDonnell
    Eiron Guest
    I've seen calipers (and clutch baskets) that are sticky. Nothing to do with
    hydraulics
    but because the alloy case is worn away where the front edge of the brake pad's
    steel backing plate rubs on it. My car's brakes have a stainless steel strip
    to prevent this happening.
    Eiron, Feb 26, 2006
  7. Thanks for the thought, but, erm...
    The calipers have both been stripped and cleaned in the kitchen sink
    with careful attention paid to the dust seal grooves with our patented
    `cut up brillo pad and matchstick' method. (I did sort of mention this
    in my first post in the thread). Then they get dried on a radiator.
    The master cylinder got a similarly thorough cleaning - n matchstick,
    but I did clean up the brake fluid reservoir sight glass with wet-n-dry
    and some T-Cut. It still looks cracked (no actual leaks, but...) and
    yellowed, but you can see through now.
    Dunno about `amazing' - I mean, roads are pretty grubby places.
    What amazes me is that Honda didn't fit brakes with rubber boots over
    the pistons, as Suzuki does with a lot of its brakes. That `just stops
    the crud getting to where it can do harm' and all that.
    What I find reduces the rate at which the crud and corrosion gets to be
    a problemm is to spray rubber lube on the caliper pistons as often as I
    can be bothered (I'd like to do it every week, but guess what? After
    lubing the pistons, I use brake cleaner and clean cloth to get the
    excess rubber lube off the disc and pads). It doesn't destroy the seals
    like WD-40, and it does help keep things freed up.
    Cheers,
    Rowland.
    (used to cleaning crud off)
  8. Hmm. Righto. I'll look at things in that light too. What it seems,
    basically, is that `everything needs to be spot on including a bunch of
    fiddly stuff you wouldn't necessarily have thought of'.
    Argharghargh.
    Cheers!
    Rowland.
  9. That's the badger.
    Something similar, I'd guess - my 86 VFR's got pretty much the same
    arrangement as my very poorly and sadly neglected non-running '84
    VF500F2 (now *there's* a hooligan's motorcycle if ever there was one)
    and - IIRC - the mid-80s CBX1000 owned by the bloke at the tyre shop I
    use.
    (btw, VFs and VFRs are very different - a lot of the VFs had problems of
    some sort, while the VFRs were designed to deal with 'em. VF500F2s, for
    example (`Interceptor' in the US), had weak bottom ends and inadequate
    top end lube. VF400s were basically fine, except that they were hard to
    maintain correctly and mostly owned by young hooligans who rode 'em into
    the ground and didn't do the maintenace. I knew one such in the mid
    1980s. I forget the list of VF750 woes, but the VFR750 was the
    high-reliability design to overcome the reputation for awful reliability
    that the VFs had given Honda)
    (which is P+R Tyres, 4 Jamaica Street, Liverpool L1, 0151 707 1616 - I
    find them a very nice place to do business with if only because if they
    get something wrong (and who doesn't, from time to time?), they're dead
    good at sorting it out with no hassle. Used to be PR Tyres, but there's
    been a change 'cos the old owner was a bit too flaky - looked to me as
    if he was more interested in his rock band. And no, aside from buying
    tyres, I'm not connected to 'em at all - I just like the service and
    attitude I get.)
    What you'd expect, I expect ;-)
    Righto - that's a start. Now to find something similar here...
    Righto. What sort of asymmetry have your seals got? I've just looked
    at a new front brake hydraulic seal (I keep a set `in stock', just in
    case). I put it on a flat surface and checked it with a steel ruler -
    it looks to me as if all sides are square and I can't see any sign of
    asymmetry at all. Am I being stupid?
    (Honda part no. for the seal: 45209-166-006 if anyone cares.)
    If you can tell me what to look for and which way round are they
    supposed to go with the brakes you're used to, I could see if I could
    spot the same asymmetry and fit my seals the same way. After all, if
    I've got no guidance at all here and I've been fitting 'em any old way,
    it's hardly going to make things worse if I pick one way or another, is
    it? And if I make a log of what I'm doing and it doesn't work - well,
    I'll just try 'em the other way round next time. Two attempts max, and
    it'll be right, right?
    <grin> Yes... I shan't disagree with you on that point.
    (But it's a lot more use than the Clymer manual I had to get for my
    VF500. I'm told that modern Clymer manuals are pretty damned good and
    far superior to Haynes manuals - which are famously iffy and generally
    not very useful - but the Clymer VF500 manual is rotten.)
    Yes, I suppose it would. Urgh. But if there's no other way to find out
    which way round to fit the seals...
    (I've used a genuine Kawasaki manual - there was this KH250 to look
    after, and it was a Kawasaki manual or nothing. And could we understand
    what it was saying? Well, eventually, probably, using all our
    ingenuity, we worked out what we needed to. Probably. Mad, mad, *MAD*
    bike when my mate got it for £30 with no airbox and jetted up to suit
    the increased airflow. A power band as wide as a human hair but when it
    hit it - well, you went deaf for starters. If that's what the 250's
    like (when in mad mode - it calmed down a lot when he fitted an airbox),
    how could anyone ride the bigger triples?)
    Okay.
    One problem: the shops I could get to today (Sunday) didn't have any
    grease that matched the spec of what I need. Copper slip is all they
    had on offer - both Halfords and Motorworld. Well, I've got a tin of
    copper slip (hmm - two. One nearly empty, and an unused replacement).
    It seems my cupboards contain pretty much the entire range of greases
    one can buy at Halfords (and then some).
    They hadn't heard of anything other grease for brakes.
    (what a surprise: clueless shop staff in Halfords. I was once presented
    with a pack of fibre washers by a Halfords shop assistant when I asked
    if they had any copper sealing washers suitable for a hydraulic brake
    system - yes, I did specify exactly that, being used to Halfords bods
    being clueless)
    Does anyone have a suggestion as to where I might find some suitable
    grease for brakes?
    Sil-Glyde doesn't seem to be a brand that's available in the UK.
    I gather I need: poly butyl cuprysl (PBC) grease or high temperature
    silicone grease designed for brake applications.
    Somewhere that I can pick it up quickly would be good, 'cos I've either
    got to get my MOT done by Tuesday or SORN this beastie... (I've had more
    than one problem with it - and then I crashed and... Argh. Really - I
    mean, *BOTH* bloody brake lights switches have broken recently, and the
    rear one was a hydraulic switch I fitted about two years ago. Why me,
    oh Lord, why me?)
    Given that I can't find the right grease at the moment, I'm considering
    trying the brakes with spray-on silicone rubber lubricant on the brake
    pins/rubber bushes - not for more than a test ride or two in the dry,
    just to see if that frees it up.
    I've done some Web searching, and not been able to come up with much.
    <http://www.forthgear.co.uk/htm/accessories1.htm>
    Mentions some Würth silicone grease. Would that be the thing?
    I've searched the Web. Even Castrol doesn't seem to make either of the
    greases specified - Castrol Red Rubber Grease is one of their classic
    products
    <http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9002
    192&contentId=7002857>.
    It's vegetable based - not silicone or PBC - but apparently suitable for
    brakes:
    <http://129.35.64.91/bpglis/lubtds.nsf/technicaldata/DA9E707906915D4C802
    56C4E005B813F?OpenDocument>
    Anyone got any idea where I could track down what I need?
    I did find: <http://www.triumphspitfire.com/wirewheel.html>
    which is a US car magazine that apparently sells PBC grease via its
    spares organization. Not terribly useful for me.
    Yep to all points - thanks. I replaced the seals but not the bushes -
    they were all fairly new and look undamaged even internally, but I think
    I might be replacing them in any case. The slider pins were all
    replaced fairly recently - they're clean and uncorroded and checked for
    straightness as best I can without taking them off again (I *know* I've
    not done anything idiotic like ride off with my disc lock on since
    fitting 'em not long ago - I'm pretty damned certain that they can't
    have got bent).
    I think the drag probably is caused by something to do with the calipers
    not moving freely, so it's `replace all the bits you replace after
    cleaning and checking everything' time, isn't it?
    I've got stainless braided brake lines - I think the inner is PTFE
    (fitted by a previous owner - they're actually a little bit too long,
    but I'm pretty sure I've routed them to avoid this being a problem). I
    doubt this'll be the problem, but thanks for mentioning it. It's
    something to bear in mind that I wouldn't have considered.
    FWIW, the standard front brake line arrangement is `Single brake line
    from master cylinder to splitter mounted on the lower triple clamp, and
    two lines from there, one to each caliper'. I've got two lines running
    direct from the master cylinder, one to each caliper, and two spare
    threaded bolt holes on the lower triple clamp where a splitter used to
    be mounted.
    I think you're barking up the right tree there.
    It's just a tiny bit of residual drag - but it's definitely there, and
    it's enough to affect the handling and acceleration.
    (I doubt anyone would notice the acceleration effects unless they knew
    the feel of what the bike was supposed to do when you cracked open the
    throttle. I'm not worried about not having full thrust except that it
    means something's not right and needs fixing before I come a cropper due
    to poor maintenance).
    Righto - easy and effective. Ta.
    Cheers again,
    Rowland.
    (thinking `Sheesh! At least my old CZ had drum brakes that just worked
    if you kept 'em adjusted[1] and cleaned.')
    [1] I had a 1976 Model 476 Mark V deluxe (honest - and now *you* try
    telling the copper who'll pulled you over that's the model of the bike
    you ride when he's looking at a shabby Iron Curtain 125cc learner bike).
    One of the `deluxe' features was a twin leading shoe front brake. It
    was in fact damned good - saved my bacon many times.
    The other `deluxe' features? Indicators, alloy rims, and an oil pump.
    The paintwork was stonking quality. CZs had a lot of nice touches - as
    well as that unmistakable Iron Curtain mankiness. But more style than
    those bloody MZs, and better brakes, *AND* less starting trouble (hehehe
    - sorry, I can't help it. Your particular MZ might have been fine in
    that department - not all have been.)
  10. sorry never picked up your original post
  11. [snip]
    No worries - but, erm, isn't it available for reading at the start of
    this thread in your newsreader?
    Admittedly, the first two posts in this thread have expired from my
    local news spool (I was using a 7 day expiry on this newsgroup - I've
    just upped it to 14 days). But it's still on the news servers, isn't
    it? And the last time I heard about Outlook Express's handling of
    Usenet news, it didn't do auto expiry at all (okay, that was about, oh
    god, a decade ago, I think[1]).
    Rowland.
    (curious, not at all critical or anything)
    [1]
    It's all Macs here with a definite lack of any MS software. That's not
    out of careful avoidance but because I'd have to buy the stuff, which is
    rather expensive and not particularly useful for me, so I know nothing
    of OE from personal experience. The newsreader I use looks a bit like
    this:
    <http://www.fen-net.de/mac/macsoup.html>
    (I say a bit like that because that's the `classic' MacOS version, and
    the UI has gone all fancy-dancy MacOS X Aqua swish shiny stuff now.
    Stuff that the prophet Steve Jobs - high priest of the cult of Mac -
    thinks we ought to want to lick. Argharghargh. Someone ought to
    explain to these loons that it's just a bloody computer! It's just a
    tool! Anyway, the page I pointed at shows off the main reason I use
    this particular newsreader - the graphical thread display and explains
    quite a lot about it, but in German).
    Rowland McDonnell, Feb 27, 2006
  12. No blueyonders news servers can be a bit flaky sometimes
    Steve Robinson, Feb 27, 2006
  13. Ah - all is clear.
    Cheers
    Rowland.
  14. Gotcha - thanks. I'm pretty sure there's no such asymmetry on the seals
    I've got. I've looked and looked again with brighter lights and a steel
    ruler as a makeshift square and I can't see it. I'll have another look
    later, just to triple check. Right now I'm waiting for the Araldite to
    set - one of those blasted plastic piston caps dropped off. A 100W
    lightbulb in an Anglepoise under cover is providing heat...
    Before I'd got that far, I'd fiddled with the other caliper and
    concluded that the dragging probably is down to something up with the
    movement of the caliper pins in their slidey holes - one runs entirely
    in rubber, the other runs into a bore in the caliper mounting bracket
    with a rubber boot seal to the caliper (and the indicators are back on.
    The word `perpetrated' is appropriate to describe what I had to do in
    that case).
    Cheers,
    Rowland.
