Why is it so hard to find neutral?
Discussion in 'Motorbike Technical Discussion' started by Eat Dirt, Apr 24, 2008.
  1. Eat Dirt
    Eat Dirt Guest
    When shifting from 2nd into neutral, it usually ends up in 1st. Then
    when going from 1st into neutral, it ends up in 2nd. It seems that no
    matter how gentle I try to shift, it goes right past neutral. Why is
    this and what can I do to rectify the problem?
    I'm using 10-40 oil and just got the oil replaced, so i don't suppose
    it's slipping due to bad oil.
    The bike is a 83 Kawi GPz305 with 23,000 km that I'm restoring. Aside
    from this problem all gears seems to shift OK, although the clutch is
    nearing its end but still has some life left. Since this is a bike for
    the wife to learn to ride on, this is sure to prove to be a problem
    for her. Even I have a tough time finding neutral when coming to a
    stop, so I can just imagine the difficulty and frustration she'll have
    while learning to ride the thing. On a side note (and I'm not sure if
    this is relevant or just how the bike was designed) it doesn't shift
    into 2nd while stopped. It shifts fine when moving but never while the
    rear wheel isn't moving.
    If this is an easy fix (the neutral issue), can someone please post
    detailed instructions on what needs to be done? I have a service
    manual that I can refer to, if the work isn't too complicated and is
    something I can do on my own.
    Thanks
  2. Eat Dirt
    lugnut Guest
    There is no neutral at the bottom to keep you from
    accidentally being in neutral as you are slowing or braking
    in the vent you need to accelerate quickly. If the bike is
    moving, it should pretty much always be "in gear". If the
    neutral is at the bottom, you would always have to be
    counting shifts to be sure it is in gear. This may be a
    problem if you are distracted by the efforts to save your
    ass at the moment. If the Kaw is shifting down from second
    to first, it is as it should be. If it does not stop in
    neutral when shifting up from first with the bike stopped,
    it probably has a problem with the shifter detent. Key word
    here is "stopped". If the bike is rolling at all, it will
    upshift to second. In other word, it will not go into
    neutral if the wheels are moving - it must be completely
    stopped. If it is not working correctly it may be as simple
    as a weak detent spring. Don't know about the 305 but, most
    Kaws I have seen, you have to remove the sprocket cover, the
    sprocket and the trans cover to get at the shifting
    mechanism to see what is going on. Some aspects of the
    shifting mechanism are adjustable in some manner. In any
    case, the Kaw should not overshift into second if the bike
    is stopped.
    Lugnut
    lugnut, Apr 24, 2008
  3. Eat Dirt
    Sean_Q_ Guest
    If so then it would be more time-consuming, sometimes in a critical
    riding situation when every millisecond counts, to find 1st when
    downshifting.
    SQ
    Sean_Q_, Apr 24, 2008
  4. Eat Dirt
    Eat Dirt Guest
    Oh, so that's what that is. I find it incredible that this feature had
    been implemented some 25 years ago or longer. Truly amazing. Yeah,
    since that's the case I'm convinced that there is nothing wrong with
    my tranny, now that I understand what it's doing. What you describe
    makes absolute sense as it fits exactly with what my bike is doing.
    The best part is, the wife gets to learn the proper way, which will
    also facilitate things for her. It is my bad riding habit that prompts
    me to go into neutral before coming to a stop. A habit that the wife
    won't inherit thanks to this feature. This is my first Kawi, so the
    concept was unknown to me, although I have heard of it.
    Say what you will about Kawasaki. When it comes to sport bikes I find
    that there are only two serious players, Kawi and Suzuki. It seems to
    me that these are the most innovative, aggressive players and the
    others are conservative, follow the leader. Your opinion may differ,
    of course.
    Thanks for the clarification. I get to sleep in peace now.
  5. And between third and fourth, on mine. And between second and third. And
    between fifth and sixth. nd between first and third. And third and
    sixth. And fourth and fifth....
    You're not being very bright.
    Wrong again. Some years ago, everyone did it differently. Brit bikes -
    right foot shift. Early Laverdas - right foot shift. Jap bikes, left
    foot shift, and some (Suzuki) had a shaft that allowed you to swap from
    right to left. Early MV: right hand shift, one up, three down. My old
    Kawasaki H1: left foot, with neutral at the bottom, as you describe. My
    old Yamaha YB100: left foot shift, "all down", with neutral at the top.
    Someone sensibly decided standardisation was a Good Thing.
    The Older Gentleman, Apr 24, 2008
  6. Eat Dirt
    Vaughn Guest
    Yup.
    Gotta always be ready to cut and run.
    Horns, eye contact, reflective vests, flashing LED brake lights, and
    all the rest can help a little, but always be ready to cut and run.
    That is a rider's greatest strength for road safety.
    Vaughn, Apr 24, 2008
  7. Eat Dirt
    . Guest
    If you study the shifter detent mechanism in online parts fiches like
    www.bikebandit.com, you will probably find that there is a spring-
    loaded ball that drops into one of six or seven "valleys" in a star-
    shaped cam attached to the end of the shifter drum.
    Most star-shaped cams are symmetrical, the cam has to rotate the same
    number of degrees between any two gears or between first gear and
    neutral or second gear and neutral, but I have seen at least one Honda
    that did not have a symmetrical shifter detent cam.
    The symmetricality of the shifter cam results in the rider having to
    move the shifter lever a smaller distance to shift from any of the
    higher gears to the next lower or higher gear, but the rider has to
    remember to move the shift lever further when shifting from first to
    second or second to first.
    Most riders do not realize this simple fact of life about the shifter
    cam design, and they wind up in false neutrals when shifting, or they
    have problems finding true neutral.
    In order to get more precise gear detention, you can replace the
    compression spring with a stiffer spring found in a hardware store.
    More modern designs have done away with the compression spring-loaded
    detent ball and have replaced it with a spring-loaded roller on a
    pivoting arm. The roller drops into one of the valleys on the "star
    wheel".
    The spring on the later detent devices is a tension spring.
    Kawasaki has been using its own positive neutral finder for at least
    30 years now. The PNF consists of a 5/16ths steel ball which falls
    into a hole in a sleeve in second gear. The system is very reliable,
    only one rider has ever complained to thsi forum about getting stuck
    in first gear and being unable to shift to second because the PNF
    jammed.
    ., Apr 24, 2008
  8. Eat Dirt
    BryanUT Guest
    You are joking right?
    BryanUT, Apr 24, 2008
  9. Eat Dirt
    bsr3997 Guest
    Kawasaki used to have it that way. The feds told them they had to put
    it between 1st and 2nd as would everyone else. I still have an old
    Kawsaki tripple that I ride occasionally and can tell you that with
    neutral all the way down you must pay attention to what gear you are
    in or you will get a wakeup call when you downshift into neutral
    thinking you were going to get 1st.
    Bruce
    bsr3997, Apr 25, 2008
  10. Eat Dirt
    lugnut Guest
    Some of us have driven vehicles other than bikes. I've
    driven vehicles with as many as 30 forward speeds and 3
    separate shift levers ot use them. Whether you like it or
    not, you will in some way keep track of your gear positions
    or screw a 10K transmission.
    As far as the shift pattern goes, it was developed with
    input from numerous sources from around the world including
    bike riders and racers, the manufacturing industry, the SAE
    and many others. Politicians had little to do with
    developing the bike standards other than facilitating the
    regulatory aspects of it. Thanks to the "standard" you can
    move from almost any bike to another and know exactly where
    the basic controls are and how they work which goes a long
    ways toward promoting safe operation of the machines. When
    the change was made, there was a lot of bickering from old
    school bikers including myself protesting the change to what
    we perceived to be a Japanese way of doing things. At the
    time and for some time later, I was a fan of and owned
    several Triumphs of various vintage and configuration. I
    think as it turned out, they were just ahead of the curve at
    the time. I clearly remember my first couple of trips on a
    bike with the current standards like downshifting when I
    really wanted to brake or braking when I downshifted. Some
    habit just die slowly. Now, It doesn't really matter to me
    what bike I get on, it is not a problem. As far as the
    Indian suicide shift, that is what my '47 Indian Chief had
    on it along with a hand spark control and foot clutch and no
    throttle return spring (early form of cruise control). I
    love some of the old bikes as much as the next but, the new
    bikes are light years ahead of them in almost every aspect.
    Much of this is due to the "standards" enabling many more
    riders safely operate the machines and go from one to
    another easily.
    Lastly, we keep getting the same f**cked up politicians
    because noone can see anything wrong with their own
    politician. It's always the one from some other district
    that is the problem. I say put'em all on the street and
    let's start over. At least we'll spread the pork out a
    little bit!!
    Lugnut
    lugnut, Apr 25, 2008
  11. Eat Dirt
    lugnut Guest
    It's not a big deal for me either. Nowadays, it is less
    trouble than it was on one of my old Triumph Bonnies that
    had a neutral between every gear when I didn't want it and
    neber could find neutral when stopped in traffic. The
    standard did not eliminate some machines having that odd
    neutral between gears but, it does make it easier to find it
    every time if you are stopped. No big deal; the engineers
    figured out a way to comply with the standards and make it
    work pretty much every time to just let the machine handle
    the details. It works too well for the politicians or
    bureaucrats to have come up with it.
    Lugnut
  12. Eat Dirt
    Eat Dirt Guest
    On Apr 25, 9:41 am, "Blattus Slafaly ? (3) ¼ :)"
    Do yourself a favor: stay away from dirt bikes
    Eat Dirt, Apr 25, 2008
  13. Eat Dirt
    bsr3997 Guest
    Actually the early Kawasaki triples were kinda lacking in the brakes
    department. I can remember one time when I put my feet down trying to
    stop because it seemed like they had more effect!!!
    Bruce
    bsr3997, Apr 26, 2008
  14. Eat Dirt
    Who Me? Guest
    WELL, it certainly is not a bad thing............unlike quoting back 35
    lines and then adding only ONE.
    Trim your quotes, putz.
    Who Me?, Apr 26, 2008
  15. Eat Dirt
    Mike W. Guest
    Very good advice, but could I offer that instead of two feet, you'll find
    you have a system that works in more settings by putting your left foot
    down. At extremely slow speeds, you'll be using the friction zone and
    dragging the rear brake and by not disengaging from that brake, you're able
    to transition between a fully committed stop and the very slow motion
    regimes. On any sort of an incline, you'll be able to hold the bike in
    place while stopped as well. Police instructors teach this method because
    of the versatility it offers. Of course too, as one stops, you need to
    leave room for a quick departure without a lot of turning in case the car
    behind you comes in too hot.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    71 KG 100 (Hodaka-powered)
    Mike W., May 3, 2008
  16. Eat Dirt
    Mike W. Guest
    One situation where the counting method breaks down significantly is the
    emergency stop. You have a lot to manage, like traction, and as you stop
    and pump the shifter toward lower gears, it would be trivial to lose count.
    When I was riding (seemingly a past tense) and working police skills, I
    drilled on emergency stops on every single ride. I found during the few too
    many real emergency stops I've made that even extreme muscle memory did not
    give me (and perhaps this is only me) any intellectual bandwidth to process
    anything at these times. You want to land in first when you stop and be
    ready to ride out of the event if it has not completed unfolding by the
    time you scrub most of your speed.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
