Why H-beam rods?
Discussion in 'Motorcycle Technical Discussion' started by Things that make you go hmmmmm..., Dec 11, 2006.
  1. If the problem was static loading, I could design an I-beam rod myself
    and order an extrusion from a catalog.
    The horizontally-disposed, simply-suported center-loaded beam that you
    describe has been illustrated hundreds of times in strength of
    materials texts.
    If you work in a high rise building, your weight is probably being
    supported by a horizontally-disposed I-beam attached to
    vertically-disposed I-beams that resist the wind.
    However, the connecting rod's supports are definitely NOT simple, both
    ends are moving constantly, so the I-beam or H-beam is exposed to
    cyclical bending loads as the piston thrusts against the cylinder
    walls, then tension and compression loads as the crankshaft starts and
    stops motion at the ends of the stroke.
    As I mentioned previously, the tension loads are the most severe
    problem for the connecting rod designer.
    As I thought about the subject further, I realized that the H-beam is
    somewhat similar to a thin-walled gothic cathedral in concept.
    The architects wanted to build cathedrals as high as possible, while
    having as much open space inside as possible. They also wanted to
    reduce the amount of stone to the minimum required.
    High winds in a storm would actually cause the tiled roof of the
    cathedral to move side to side and the solution to keep the cathedral
    from falling down was the masonry flying buttress, which is loaded in
    compression.
    The small end of the connecting rod is "seeing' loads similar to what
    the roof of the cathedral experiences, and the two side caps are like
    buttresses.
    The central part of the rod is like the main structure of the building.
    It would be bending backwards as the crankshaft turned, if not for the
    bracing of the buttresses.
    The forward buttress would be loaded in tension, the trailing buttress
    in compression on the down stroke, then the loads would reverse on the
    upstroke.
    Things that make you go hmmmmm..., Dec 20, 2006
  2. Things that make you go hmmmmm...
    James Clark Guest
    Short version . . .
    H-beam rods are stiffer than I-beam.
    That's why Udo had to use production rods in his high-output BMW airheads.
    Factory rods will flex with the crankshaft.
    Carrillo rods will saw it in half.
    James Clark, Dec 20, 2006
  3. Things that make you go hmmmmm...
    Timberwoof Guest
    Where do the bending loads on the connecting rods come from? The ends
    are pivots.
    Timberwoof, Dec 20, 2006
  4. For the same weight of of the same alloy with the same forging or
    hardening processes applied, occupying approximately the same operating
    space, that is probably true.
    Hopefully, not much flexing is going on with a more modern design. The
    airhead was originally designed as an aircraft engine in the 'teens of
    the last century, and has since seen yeoman automobile and motorcycle
    service.
    If the crankshaft breaks or if the rod breaks?
    There are older technologies which don't adapt well to more modern
    technologies. A fan of wooden ships once told me about a failed attempt
    to replace an oaken mast with an aluminum extrusion. He said that 17th
    century ship technology worked just fine if you stuck with 17th cntury
    materials.
  5. You are correct that bending loads do not come from the piston pushing
    against the side of the cylinder due to the angle of the rod. Because
    of the pivoting action those forces go straight from the wristpin to
    the crank journal.
    To see the bending loads take a rubber hose or something else that will
    bend without much force. Hold one end and let it dangle vertically.
    Keeping that end stationary grab the bottom end and shake it back and
    forth. The inertia of the hose will have the mid section lagging
    behind the motion of the end. When you reverse the direction of the
    end the mid section will keep going till it flops to the other side and
    gets dragged back. Look at the direction the big end of the rod is
    traveling at TDC and BDC. The H beam is better suited to take these
    loads.
    As for the tension and compression loads, the reason a rod is more
    likely to break when under tension is in a big part due to the fact
    that the acceleration forces on the piston are greater at TDC than BDC.
    To see why picture a rod just a bit longer than the crank throw. When
    the crank is 90 degrees ATDC the piston is near the bottom of its
    stroke. During the next 180 degrees it hardly moves. In the next 180
    degrees it has to go all the way to TDC and back. My gut feeling is
    that the rods work equally as well in tension, but the H would be
    better in compression since any bend in the rod would weaken it under
    compression.
    Bruce
    Bruce Richmond, Dec 20, 2006
